MAZDASPEED Protegé
> MSP - ECU Computer Tuning
  • 1 Post By djuosnteisn
 Old 06-24-2010, 09:37 PM   #1
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Brian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the world
Default Haltech Standalone Sprint 500
Haltech has released it's PS500 ECU.
It is a trimmed down version on the SP1000 ECU that I use.
It is looking like a very good entry level ECU.
If that's the case, it might be worth looking at.
It will be able to do Full Sequential and Full Direct Coil On Plug (8 Outputs)
The best part is the Cost, USB Support and the new software.
Brian MP5T is offline   Reply With Quote
 Old 06-24-2010, 09:51 PM   #2
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Yeah, not bad a price at all. Tc3 should be in this neighborhood, and DI friendly lol.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 06-24-2010, 10:06 PM   #3
Brian MP5T's Avatar
I gotta say that I do not work for them or care what EMS a person chooses for their car.
I have had great luck and support, but that could be said about most companies.
There are some guys on the Haltech forum that are trying to figure out the 2.3L and the DISI.
Exciting times..
 Old 01-01-2011, 11:27 AM   #4
Brian MP5T's Avatar
I wanted to update this..
I am installing this in a Protege for a friend of mine.. Kyle..
I have already created a map for his that is similar to mine, but because the SP500 is a 16x16 Map and the PS1000 is a 32x32, it took a bit of time.
I'll post up results which I am sure will be positive.
 Old 01-10-2011, 12:54 PM   #5
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
hmm haltech f10x haz left me a bad taste in my mouth. i willz never go bax
 Old 01-11-2011, 12:21 PM   #6
Brian MP5T's Avatar
The FX10 is a piece of junk compared to the SPORT/SPRINT series.
 Old 02-16-2011, 03:36 AM   #7
SwirlFX's Avatar
Posts: 5   (View Stats)
SwirlFX has a spectacular aura aboutSwirlFX has a spectacular aura aboutSwirlFX has a spectacular aura about
How well did this project work out?
SwirlFX is offline   Reply With Quote
 Old 02-16-2011, 10:16 AM   #8
Brian MP5T's Avatar
Flawlessly.
As usual, being a "Trail Breaker" requires 5 times the install because there are no notes and no solutions.
We had his running in under 10 Hours and the install even looked pretty.
 Old 02-17-2011, 04:43 PM   #9
Captain
Pics? Vids? Anything?
chooza143 likes this.
www.permtuning.com
 Old 02-17-2011, 09:54 PM   #10
Brian MP5T's Avatar
It's Winter... You would like a video of a parked car in a garage?
If you would like more information on the actual mechanical install there is a thread for that... and I will gladly answer any questions or even figure out how to make it work for you.
Haltech Standalone ECU
 Old 04-10-2011, 03:02 PM   #11
Brian MP5T's Avatar
This is a Map for the Sprint500.
1. It Will in no way operate an FS engine unless it has a modified trigger.
2. It is made to operate with 550cc Subaru Pink (STI) injectors.
3. It is made to Run a Direct Coil On Plug (One Coil Per Cylinder)
4. It is made to Run Full Sequential Injection.
5. It must have a Crank Position Sensor AND Modified Cam Position Sensor
6. It Will not let you switch back to ECU Control (Because of the Modified Cam Gear)
 Old 08-04-2013, 12:01 PM   #12
Alejo_NIN's Avatar
Posts: 1,700   (View Stats)
Alejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the world
Groans: 88
Groaned at 186 Times in 83 Posts
super late, but is the sprint500 a full stand alone or does it still requiere the stock eCU to be in place?
radonelement.com
Alejo_NIN is offline   Reply With Quote
 Old 08-04-2013, 01:23 PM   #13
Brian MP5T's Avatar
It can do both.
The Following User Says Thank You to Brian MP5T For This Useful Post:
Alejo_NIN (08-04-2013)
Haltech Standalone ECU Brian MP5T MSP - ECU Computer Tuning 14 06-19-2012 02:44 PM
Sprint Booster jallways 2010 MS3 - ECU Computer Tuning 12 05-15-2010 03:59 PM
Sprint Booster? bioevolve MazdaSpeed 3/6 - ECU Computer Tuning 6 12-23-2009 03:13 PM
Standalone ECU subparpunk03 MazdaSpeed 3/6 - ECU Computer Tuning 28 03-08-2009 04:51 PM
Page generated in 0.33360 seconds with 25 queries
