> MazdaSpeed 3 - How-To's
Like Tree20Likes
Closed Thread
 Old 03-08-2010, 11:21 AM   #1
Neutral  :  +5 score
Default How-To clean your 1st Gen Mazdaspeed 3 EGR
EDIT: This is for people who want to retain the EGR. You can block it off and clear the CEL through AccessPort if you want. I elected not to, as I do not have an AccessPort.
I got a P0401 CEL at 51K miles on my 2007 Speed 3 the other day after 2 or 3 days of slow starts, where it would crank a while before firing up. Guy at Advanced who read the code said EGR was clogged, a $430 part from the dealer. Having owned a Protege 5, I knew what a stuck EGR was like, and how it can be cleaned, but no how-to posted yet for the Speed3 apparently. I read a few threads online, and here especially, so I am posting here first to share. This is how I did it. Feel free to do it differently if you feel like it. This is probably not the only way to do it. It is just how I did it. Don't like it? Well, sorry I guess. A 10 and 8mm deep and shallow socket, pliers, a 22mm wrench, flat blade and Philips screwdrivers, Brake Parts cleaner, and some coolant will be needed. Oh,and a person with skinny fingers.
1st, it is not that hard to do if you know a little bit on working on our cars already.
1st, where is the EGR. It is here:
Now what to do. To start, remove your OEM TMIC, battery and battery box. Also remove your turbo inlet pipe. loosen the top on the coolant overflow tank. Put a rag in the turbo.
The EGR is the silver thing with the black plastic on top. The pipe with 2 bolts coming out to the left of it is the EGR pipe.
There is a hose coming out of the back of the EGR, held on with a clamp. Pull the clamp back, disconnect the hose from the EGR, and let the coolant drain. You will lose a quart or so, the overflow will be empty.
Remove the 2 bolts holding the EGR on, and pull it out. Here is the EGR with the gasket on it. You cannot see it, but there is carbon inside, Nasty, but comes out easy.
Now go up tho the front to the throttle body. You may make a mess if you have not already removed the coolant lines from the throttle body like I did. If you did not, do it now.
Remove the throttle body by taking out the 4 bolts:
Remove the 2 bolts holding the back part of the EGR pipe on
Now use that 22mm wrench, loosen the bolt holding the front part of the EGR pipe now visible:
[IMG]https://i.imgur.com/JBCcJP3l.jpg/IMG]
remove the pipe:
Admire the nice pile of carbon in front of the pipe.
Feel free to blow compressed air through the pipe while it is removed. If clogged, use a coat hanger or something, and get out as much as you can. You might need to take it to a mechanic to get it dipped in parts cleaner if you do not have it.
Skipped pics, but remove the 4 screws holding the plastic top of the EGR valve. Don't strip or break them. They are as a strong as Dollar Tree trash bags.
There is a plunger. It is stuck. spray with brake cleaner on the holes, until clean, Scrape out carbon if needed.
Then reinstall everything. I ran a Seafoam treatment, and now it runs great, and CEL is gone.
The end.
If this has helped you, and you are not VIP, please donate $10 to the forum. This how-to just saved you $430 from buying a new EGR. Click HERE to donate.
Update 5-24-2011
1) Every 4th drive, the CEL will go off. So if it goes away, it will prolly comeback soon.
2) I have also found a way to check for clogged EGR versus clogged pipe.
Take the 4 screws off the top and remove it, (you might need to remove some electrical connectors) and be careful not to lose the metal gasket. Push down on the plunger for the EGR. See if it sticks at all. Sticky=EGR cleaning too. Hotdog town a hallway, then try cleaning the pipe itself. It might save some time. Not exactly how true this is, but it worked recently for me. pipe was clogged again, EGR was not sticky. Saved a lot of time/mess.
[/SIZE]
rfinkle2, keridil and EcuaGfox like this.
Raider is offline
The Following 145 Users Say Thank You to Raider For This Useful Post:
802MS3 (03-09-2010), Addikted To Boost (03-09-2010), AJ713 (07-28-2010), anavrinIV (01-11-2012), ASHMS3 (02-04-2013), atlasfiver (04-19-2010), Awesomesauce (11-19-2012), AZSPEED3 (07-30-2010), Benny71 (09-23-2012), bertrand_CX_7 (12-23-2011), bioevolve (03-15-2010), Blackspeed (03-08-2010), BolvangaR (03-09-2010), Boosted Beluga (10-17-2011), bozzben (05-07-2011), breakfstincluded (10-16-2011), Brokeswagon (06-11-2013), CaptainCode (04-18-2014), Cataphract_40 (01-17-2011), Cheapspeed (04-13-2013), Ckmazdaspeed3 (12-20-2010), Constantin (03-25-2012), Dahouse702 (08-28-2011), DaleNixon (07-30-2010), danesti (03-09-2010), dantes5823 (01-14-2012), Dash08 (05-04-2010), dead-zone (10-03-2012), derp_ms6 (05-16-2014), deuce_WI (09-12-2011), Dezine (01-25-2016), djthom (03-08-2010), dkapetansky (09-18-2011), Docnox (03-15-2010), Domino81 (10-12-2011), Easter Bunny (09-05-2011), eljefe62 (01-15-2013), England15j (11-19-2012), f-castrillo (04-25-2012), Fatpig78 (09-27-2013), Ferdball (05-06-2011), Ferg (09-09-2011), Figgz_MS6 (03-23-2015), flyrevs2 (03-10-2010), Fobio (03-09-2010), Grumpyjap (06-15-2012), gtarman77787 (08-02-2010), hank25 (01-14-2012), Hank3 (04-21-2010), i8urgti (04-23-2011), Ingle (01-06-2012), jabeel00 (12-03-2015), JacksonMS30 (02-26-2011), jax ms3gt (01-06-2011), jdub0802 (06-29-2012), jmustang68 (10-29-2012), JNR5005 (07-24-2011), johnheer (12-15-2012), jracer (01-12-2011), jtspells (06-19-2011), karl-hungus (03-09-2010), keridil (09-10-2012), keychain12 (04-25-2014), Kfunk (02-15-2013), kgb (03-28-2010), kilik2 (03-11-2010), kpsoerensen (01-20-2012), kpuser1 (12-22-2011), KusteLokal (05-14-2011), kylec_2003 (10-10-2012), labikesrcool (08-02-2010), liljae8 (01-10-2015), LTHorn (02-09-2012), M$3ChoquiM$3 (02-07-2011), m249saw (03-18-2012), madvillain (03-10-2010), magicka (05-17-2013), Manny3 (05-14-2011), massiespeed3 (02-12-2011), MATT DAMOND (03-10-2010), maxcaprez (10-22-2012), mazdapunk87 (03-28-2010), Mazdarune (03-21-2012), meelo88 (05-22-2011), MGM_GT3 (05-16-2010), Micha (04-08-2012), midoritora (01-05-2012), Mistersix (05-14-2011), Mizzle (08-03-2013), Monotonous ONE (04-12-2011), MS3 Ventura (03-28-2010), ms3blackmica (11-20-2012), MS3MYK (05-28-2012), MS6FL (06-04-2011), neotide87 (05-31-2012), neverone99 (08-02-2010), Night Wolf (02-10-2011), Nliiitend1 (06-13-2013), nofel (12-30-2012), NoRegrets (07-22-2012), nycMS3 (07-08-2013), nyghtryder (03-20-2010), onelove221 (09-02-2011), paradigmshift (04-06-2011), ponny135 (02-04-2012), radbrad (06-16-2011), randino69 (01-27-2013), RAR (03-27-2012), rfinkle2 (02-11-2016), rfomzr (03-13-2010), rghispanic88 (12-26-2011), Rich990 (05-22-2013), rolanblack (06-15-2012), Sacrilicious (03-09-2010), silversurfer3 (03-08-2010), simply_pandora (11-23-2012), SKiZ0TT (09-09-2011), SLOWHATCH (08-28-2011), soccerballz (04-23-2010), speed23 (02-11-2011), Speed3eak (06-19-2011), SPEEDRAC3R (05-17-2013), spike589 (03-30-2010), spoolin00 (05-30-2011), taf0422 (01-09-2011), tddvrrn (03-17-2012), The Nut (03-21-2015), Tommy (05-22-2011), TopazM3 (03-17-2010), txmedic512 (10-14-2015), UCHAUJ00 (11-06-2019), Vansquish (03-17-2016), WAHBAM (07-23-2011), wankular (11-22-2010), warlockfan92 (12-30-2012), warlord (07-08-2011), WhiteNoise (07-17-2011), whos_MS3 (07-24-2011), xdm88 (03-03-2011), xfeejayx (04-17-2011), xtasy (05-17-2011), zpele (07-07-2011), Zpuhalla (10-15-2013), zxhoya (05-02-2013)
 Old 03-08-2010, 11:29 AM   #2
silversurfer3's Avatar
Posts: 618   (View Stats)
silversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond repute
Groaned at 26 Times in 11 Posts
How many miles have you put on it since then???
Great write up btw
Rota wheel whore #1
MOdS list
shaved with a razor moldings (EDGE cream)~de-BaGEd FTW~
painted StoCk wheels secret color ~ rattl;e caned RooF~ jdm painted brake conversion~ clear tint ~ light weight black hood and trunk with wing option ~ japanese amber side markers/ running lights ~ tw0 light weight car seats ~ shifter weight reduction ~ stock recaros with red stitching ~ mp3 mazda stereo
for sale: ms3 transmission second gear is worn out. Perfect if you want to Upgrade it or if you don't want to have any down time if you're trans is messed up!
PM me with offers
silversurfer3 is offline
 Old 03-08-2010, 11:31 AM   #3
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
take a pair of vise grips to the tube and pinch it!!!
the end.
rodrigo is offline
The Following 5 Users Say Thank You to rodrigo For This Useful Post:
jkowalski (10-23-2012), mroclimbr (07-07-2011), rigor (12-03-2010), SLOWHATCH (07-22-2013), tenzo (12-21-2014)
 Old 03-08-2010, 11:34 AM   #4
A whopping 86. I just did it yesterday. The EGR was truly stuck, not moving. Got it to move a little before it was sprayed down with cleaner. We did not stop cleaning until it was not sticking at all. Was moving freely upon reinstall.
Originally Posted by Lenny127 View Post
take a pair of vise grips to the tube and pinch it!! the end.
I edited the 1st post. This is for those who want to retain the EGR.
Last edited by Raider; 03-08-2010 at 11:34 AM. Reason: MSF Database - Automerged Doublepost
Raider is offline
 Old 03-09-2010, 07:09 PM   #5
zfreebird's Avatar
Posts: 44   (View Stats)
zfreebird has a spectacular aura aboutzfreebird has a spectacular aura about
Great write up. Glad you did it and not me...haha.
zfreebird is offline
 Old 03-09-2010, 07:24 PM   #6
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i have a really stupid question.
if one (yours truly) has egr blocked off, would i still benefit from cleaning egr valve?
phillyb is offline
 Old 03-09-2010, 07:48 PM   #7
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
did you regularly seafoam her previously?
karl-hungus is offline
 Old 03-10-2010, 12:15 AM   #8
phillyb's Avatar
Groans: 1,940
47k
seafoamed once
phillyb is offline
 Old 03-10-2010, 01:09 AM   #9
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
agreed!!!!
about the really stupid part, nub.
rodrigo is offline
 Old 03-10-2010, 06:46 AM   #10
I never Seafoamed it before. Had 2 cans waiting for 6 months, just did not get around to it. zfreebird, it is actually very easy to do, just takes an hour or so. Well worth it.
300 miles, no CEL yet.
I did some research for Phillyb. If the EGR is blocked off, try using muffler bearing lube on it as well. That is only for those with it blocked off, It is NOT for those with the EGR in use.
Raider is offline
chadeckler (04-01-2010), karl-hungus (03-10-2010), rodrigo (03-10-2010)
 Old 03-10-2010, 07:09 AM   #11
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
noob question: If you do the egr blockoff and get the cel, then clear it with the AP will the cel keep coming back ? I don't mind clearing something once but if I gotta do it everyday, forget it. Thanks
By the way OP, excellent write up !!!!!
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline
 Old 03-10-2010, 07:16 AM   #12
nice 80's jacket
tbcota25 likes this.
superskaterxes is offline
The Following 11 Users Say Thank You to superskaterxes For This Useful Post:
Ckmazdaspeed3 (12-20-2010), DaleNixon (07-30-2010), jmhinkle (03-09-2011), karl-hungus (03-10-2010), KevMS6 (03-05-2012), labikesrcool (08-02-2010), NoTraction (06-24-2012), N|njutsu55 (03-10-2010), Raider (03-13-2010), Tech/Sales@EM (05-06-2011), TheProYodler (01-30-2016)
 Old 03-12-2010, 04:23 PM   #13
i <3 bitches's Avatar
Posts: 57   (View Stats)
i <3 bitches has much to be proud ofi <3 bitches has much to be proud ofi <3 bitches has much to be proud ofi <3 bitches has much to be proud ofi <3 bitches has much to be proud ofi <3 bitches has much to be proud ofi <3 bitches has much to be proud ofi <3 bitches has much to be proud ofi <3 bitches has much to be proud of
great post! a friend with a MS6 got this code, and i told him that his EGR was prolly clogged. i think he has 80k+ miles on his car... as these cars get older, this will be more of a problem. i will point him to this thread. thanks!
would it be wise to seafoam first to try to remove some of that buildup?
Last edited by i <3 bitches; 03-12-2010 at 04:23 PM. Reason: MSF Database - Automerged Doublepost
i <3 bitches is offline
 Old 03-13-2010, 06:01 AM   #14
As for the jacket, spot on. He also has an original Airborne Express delivery jacket, too. Was cold, and did not want to ruin anything new.
And flyrevs, ATR permanently removes the code.
Raider is offline
 Old 03-14-2010, 01:54 PM   #15
nukechemist's Avatar
Posts: 64   (View Stats)
nukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond reputenukechemist has a reputation beyond repute
nice 80's jacket
First thing I noticed when the pic came up.
nukechemist is offline
 Old 03-14-2010, 01:58 PM   #16
It is a Charlotte Hornets jacket, actually.
Raider is offline
 Old 03-15-2010, 09:34 AM   #17
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
Thanks, I need to do this in the near future. I continually get this CEL too.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline
 Old 03-16-2010, 12:52 PM   #18
shpankey's Avatar
Posts: 496   (View Stats)
I did this a few weeks back. It really is an easy job. I could do the whole thing in under half an hour really. Good writeup. Anyone w/ high mileage should definitely consider this. It will help with rough idling too.
09 Speed 3 GT
shpankey is offline
The Following User Says Thank You to shpankey For This Useful Post:
Docnox (03-16-2010)
 Old 03-19-2010, 04:02 PM   #19
SpdFreak's Avatar
Posts: 364   (View Stats)
SpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the world
Can the EGR pipe on the side of the throttle body (flare fitting side) be removed without removing the throttle body? I'm willing to spend money on a specialty tool to get to it.
DIY: Sea Foam
SpdFreak is offline
 Old 03-19-2010, 04:47 PM   #20
shpankey's Avatar
I didn't even mess with the pipe. Just cleaned the EGR and made sure the plunger moved up and down freely.
09 Speed 3 GT
shpankey is offline
 Old 03-19-2010, 05:43 PM   #21
NCZ13's Avatar
Posts: 1,268   (View Stats)
Wow, that is so much more work than doing it on the protege5. That sucks.
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
NCZ13 is offline
 Old 03-19-2010, 07:44 PM   #22
I did it on my Protege5. This is way easier, imo. Mainly because I did not have to fight the EGR bolts. That sucked.
As for taking the pipe off, I am not sure, maybe from underneath with a powered slim wrench of some sort, I doubt it. Honestly, the throttle body removal was 2 minutes.
The only reason I did take it off was because I have heard of at least 1 person with a clogged EGR pipe. Mine did have some loose stuff in it, and where it mounted there was a literal pile of carbon.
Raider is offline
 Old 03-20-2010, 05:41 AM   #23
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
I've done it before with a pair of vice grips at an angle, channel locks would work too.
But honestly, as ^ that dude said, taking off the TB only takes a few mins.
If you do it w/o removing the TB, you'll jack up the threads on the EGR bolt, and you'll be wasting more time trying to get it out. If you want to save time, take off the TB.
Current Fail:
MATT DAMOND is offline
The Following User Says Thank You to MATT DAMOND For This Useful Post:
Raider (03-20-2010)
 Old 03-20-2010, 06:28 AM   #24
I forgot about how shitty the EGR pipe threads were until you mentioned that. I had a hell of a time on my Protege getting the EGR pipe threaded into a header. Thought it was right nope, needed a new pipe.
Raider is offline
 Old 03-28-2010, 05:38 PM   #25
mazdapunk87's Avatar
Posts: 109   (View Stats)
mazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant futuremazdapunk87 has a brilliant future
very awesome write up OP ! , i will need to do this in the near future on mine !
mazdapunk87 is offline
 Old 03-29-2010, 10:37 AM   #26
dallasms3gt's Avatar
Posts: 665   (View Stats)
dallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond repute
Thanks for the writeup, I just got the CEL Sunday, and will have to do this process this week.
For informational purposes for anyone reading this in the future. Up until the CEL, I did notice each time I cranked the car, the Idle remained High until it got really warm. Typically, the Idle is high when initially cranking, and then settles down very quickly.
CPE-SRI - HKS-SSQV - CPE-MM - TWM SB - Cobb AP
Cobb FMIC - Cobb CBE - DP
18x8 +48 HP Design 235/40/18 BFG Riken, H&R Springs
dallasms3gt is offline
 Old 03-29-2010, 11:43 AM   #27
I did not get that symptom, but i only had it clogged for 2 days. I am about 1000 miles since cleaning, maybe more. No CEL.
Raider is offline
 Old 04-19-2010, 10:53 AM   #28
atlasfiver's Avatar
Posts: 25   (View Stats)
atlasfiver has much to be proud ofatlasfiver has much to be proud ofatlasfiver has much to be proud ofatlasfiver has much to be proud ofatlasfiver has much to be proud ofatlasfiver has much to be proud ofatlasfiver has much to be proud ofatlasfiver has much to be proud ofatlasfiver has much to be proud ofatlasfiver has much to be proud of
Thanks for the write up. Took this on last weekend after a P0401 search came up with your "How To..." Still no CEL after a weeks worth of driving.
My EGR did not appear to be stuck closed after 39K miles but was somewhat sticky. I used the suggested brake cleaner and an aluminum paddle applicator to remove gunk. The tube wasn't clogged but received some attention too.
I like the pressed in orifice idea and will look for updates to see if that mod continues to allow some flow without the CEL and causes no problems for the EGR valve. The amount of wet gunk noted at the end of the tube and in the IM is disappointing. I imagine the backside of the TB looks similar. I used a 22mm crowfoot and extension to loosen the tube's compression nut so I didn't remove the throttle body.
I want to install a catch can but I need 20 posts to PM the guy selling kits. <sigh>
Mini rant: Why is every electrical connector on this vehicle designed differently? You almost have to nearly reverse engineer each one to disconnect it!
Thanks for reading, 4 posts to go.
atlasfiver is offline
The Following User Says Thank You to atlasfiver For This Useful Post:
Raider (04-19-2010)
 Old 04-19-2010, 11:10 AM   #29
I doubt I have 100 posts yet. But I threw some $ at the forum, I got VIP which allowed access to a shit-ton more than those without it see.
Glad it worked!
Raider is offline
 Old 04-23-2010, 05:37 PM   #30
soccerballz's Avatar
Posts: 596   (View Stats)
soccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the world
Awesome write up. Unfortunately I am at 27k and I am starting to get this code. I heard the only bad thing that would happen if I just kept clearing the code would be not passing emissions, which I dont have anyways. Is this true?
08' Black Mica MS3
Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight.
Sponsored by NATOR VA
soccerballz is offline
 Old 04-23-2010, 06:29 PM   #31
My car was taking a long time to fire up. Lots of cranking.I got one guy on my CX-7 forum who got the same code and his car will not run at all it is so clogged. Just fix the problem is my advice. I wrote the how to for a reason!
Raider is offline
 Old 04-24-2010, 12:07 AM   #32
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
now my egr is off i should just pull the egr valve thing off and block that off too. weight savings of like 1lb. haha.
also that check valve on that line (4) in the picture - i had to replace that line because the stock line wouldn't fit onto the connector whoosh put on the manifold and couldn't take the valve off the hardline. what can i replace it with - do i need to?
xcoldricex is offline
 Old 05-19-2010, 09:59 AM   #33
div2's Avatar
Posts: 273   (View Stats)
div2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the world
Groans: 57
I started getting the code over 6000 miles ago. I switched from Kroger 93 octane to BP 93. After a couple of tanks of BP the CEL disappeared and hasn't returned; I'm currently at 59K.
Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts
Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II
Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs
Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust
div2 is offline
 Old 05-19-2010, 10:25 AM   #34
might be coincidence, just having a blockage come loose and can breathe. Next time it happens, try even taking the EGR pipe off for a look.
Raider is offline
 Old 05-19-2010, 11:26 AM   #35
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
I've been getting the code, off and on, for about 5k miles now. I think I clean this sucker on saturday.
Zoomspeed3 likes this.
ChrisK is offline
 Old 05-19-2010, 10:30 PM   #36
div2's Avatar
Groans: 57
That's the plan...
div2 is offline
 Old 05-20-2010, 04:38 PM   #37
Snappy's Avatar
Posts: 12   (View Stats)
Snappy has a spectacular aura aboutSnappy has a spectacular aura about
Nice story.
Everyone lived hapily ever after, and cost ya ziltch to boot.
Snappy is offline
 Old 05-25-2010, 12:03 PM   #38
ms_3's Avatar
Posts: 374   (View Stats)
ms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the world
good write up and pics
ms_3 is offline
The Following User Says Thank You to ms_3 For This Useful Post:
Raider (07-17-2010)
 Old 07-30-2010, 12:48 PM   #39
RichB's Avatar
Posts: 510   (View Stats)
RichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the world
There are coolant lines going to the throttle body? If you drained it from the EGR side already will fluid still come out from the TB lines?
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is offline
 Old 07-30-2010, 02:04 PM   #40
Neutral  :  -1 score
Not sure. I bypassed mine. They have it so the people who live where it snows, do not have stuck throttle bodies in the winter.
I would to the rear of the motor first, then the tb. It will not be much thought, is my guess.
Last edited by Raider; 07-30-2010 at 02:04 PM. Reason: MSF Database - Automerged Doublepost
Raider is offline
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-clean-your-1st-gen-mazdaspeed-3-a-50596/
After refueling, Passat is slow to start and temporarily running roughly : MechanicAdvice This thread Refback 07-28-2015 08:18 AM
Help Needed Please Cold Start issues ? Mazda MPS Owners Club This thread Refback 06-01-2015 01:22 PM
To throw or not to throw CEL - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-05-2015 02:37 AM
I broke the testpipe/downpipe bolts on my 2010 Mazdaspeed 3 last night. Need some advice. : cars This thread Refback 10-25-2014 07:32 PM
Help Needed Please Cold Start issues This thread Refback 06-16-2014 05:44 PM
Óêðàèíñêèé Ìàçäà Êëóá :: MazdaClub.UA > Ìàçäà 3 1.6ÀÒ_Ïðè ðàçãîíå îùóùàåòñÿ ïîòåðÿ ìîùíîñòè This thread Refback 08-22-2013 04:05 AM
Ìàçäà 3 1.6ÀÒ_Ïðè ðàçãîíå îùóùàåòñÿ ïîòåðÿ ìîùíîñòè - Óêðàèíñêèé Ìàçäà Êëóá :: MazdaClub.UA This thread Refback 08-19-2013 06:00 AM
bastion72 comments on And this, gentlemen, is why EGR valves are literally Hitler. This thread Refback 06-28-2013 06:53 PM
And this, gentlemen, is why EGR valves are literally Hitler. : Justrolledintotheshop This thread Refback 06-27-2013 07:30 AM
EGR valve - 07 MS6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 05-22-2013 11:14 AM
Advice requested regarding a smoking 2008 CX7 : mazda This thread Refback 01-29-2013 03:15 PM
Check engine light code P0401 (EGR) - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-10-2013 02:58 PM
Mazda3 - Éteint au arrêt. - Mazda 3 Quebec This thread Refback 12-18-2012 02:42 PM
Sprawd? silnika ?wiat?a kod P0401 (EGR) - Mazda3 forum: # 1 Mazda 3 Forum This thread Refback 12-16-2012 09:24 AM
Probleme mazdaspeed3 - Mazda 3 Quebec This thread Refback 12-06-2012 05:27 AM
Cold Start problems on a stock MPS6 This thread Pingback 10-30-2012 11:36 PM
Check engine light code P0401 (EGR) - Mazda3Forums.com This thread Refback 09-03-2012 03:57 PM
EGR valve needs cleaning! - DFW Mazdas This thread Refback 06-14-2012 01:15 PM
AnandTech Forums for Mobile Devices - I want to know more about EGR valve CEL This thread Refback 03-28-2012 09:51 AM
What Did You Do To Your MAZDASPEED3 Today - Page 24 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 03-20-2012 12:25 PM
????? ?????????. ??????? ? ???? ??????. This thread Refback 02-13-2012 12:56 PM
I want to know more about EGR valve CEL - AnandTech Forums This thread Refback 12-07-2011 03:31 PM
Mazda MPS Owners Club • View topic - Help Needed Please Cold Start issues This thread Refback 10-18-2011 05:53 PM
Rough Idle possible EGR? This thread Refback 09-16-2011 08:27 PM
2 issues with my Mazdaspeed 6 - DFW Mazdas This thread Refback 08-21-2011 12:17 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 08-08-2011 10:37 AM
I want to know more about EGR valve CEL - AnandTech Forums This thread Refback 06-07-2011 02:42 PM
EGR Valve.... - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Pingback 04-14-2011 05:02 PM
check engine light on and off...code p0401 - DFW Mazdas This thread Refback 04-01-2011 08:42 PM
hi - AZMC - Arizona Mazda Club This thread Refback 03-18-2011 03:29 PM
mazdaspeed3 egr valve - Zuula Search This thread Refback 04-08-2010 07:05 PM
Mazdaspeed CAI filter- how to clean? red07 MazdaSpeed 3 - Engine, Transmission & Driveline 13 08-15-2012 02:24 PM
how to: clean up oil from your driveway phillyb MazdaSpeed 3 - How-To's 26 11-04-2009 02:06 PM
Page generated in 0.62417 seconds with 45 queries
