| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
(Thread Starter) | Neutral : +5 score I got a P0401 CEL at 51K miles on my 2007 Speed 3 the other day after 2 or 3 days of slow starts, where it would crank a while before firing up. Guy at Advanced who read the code said EGR was clogged, a $430 part from the dealer. Having owned a Protege 5, I knew what a stuck EGR was like, and how it can be cleaned, but no how-to posted yet for the Speed3 apparently. I read a few threads online, and here especially, so I am posting here first to share. This is how I did it. Feel free to do it differently if you feel like it. This is probably not the only way to do it. It is just how I did it. Don't like it? Well, sorry I guess. A 10 and 8mm deep and shallow socket, pliers, a 22mm wrench, flat blade and Philips screwdrivers, Brake Parts cleaner, and some coolant will be needed. Oh,and a person with skinny fingers. 1st, it is not that hard to do if you know a little bit on working on our cars already. 1st, where is the EGR. It is here: Now what to do. To start, remove your OEM TMIC, battery and battery box. Also remove your turbo inlet pipe. loosen the top on the coolant overflow tank. Put a rag in the turbo. The EGR is the silver thing with the black plastic on top. The pipe with 2 bolts coming out to the left of it is the EGR pipe. There is a hose coming out of the back of the EGR, held on with a clamp. Pull the clamp back, disconnect the hose from the EGR, and let the coolant drain. You will lose a quart or so, the overflow will be empty. Remove the 2 bolts holding the EGR on, and pull it out. Here is the EGR with the gasket on it. You cannot see it, but there is carbon inside, Nasty, but comes out easy. Now go up tho the front to the throttle body. You may make a mess if you have not already removed the coolant lines from the throttle body like I did. If you did not, do it now. Remove the throttle body by taking out the 4 bolts: Remove the 2 bolts holding the back part of the EGR pipe on Now use that 22mm wrench, loosen the bolt holding the front part of the EGR pipe now visible: [IMG]https://i.imgur.com/JBCcJP3l.jpg/IMG] remove the pipe: Admire the nice pile of carbon in front of the pipe. ![]() Feel free to blow compressed air through the pipe while it is removed. If clogged, use a coat hanger or something, and get out as much as you can. You might need to take it to a mechanic to get it dipped in parts cleaner if you do not have it. Skipped pics, but remove the 4 screws holding the plastic top of the EGR valve. Don't strip or break them. They are as a strong as Dollar Tree trash bags. There is a plunger. It is stuck. spray with brake cleaner on the holes, until clean, Scrape out carbon if needed. Then reinstall everything. I ran a Seafoam treatment, and now it runs great, and CEL is gone. The end. If this has helped you, and you are not VIP, please donate $10 to the forum. This how-to just saved you $430 from buying a new EGR. Click HERE to donate. Update 5-24-2011 1) Every 4th drive, the CEL will go off. So if it goes away, it will prolly comeback soon. 2) I have also found a way to check for clogged EGR versus clogged pipe. Take the 4 screws off the top and remove it, (you might need to remove some electrical connectors) and be careful not to lose the metal gasket. Push down on the plunger for the EGR. See if it sticks at all. Sticky=EGR cleaning too. Hotdog town a hallway, then try cleaning the pipe itself. It might save some time. Not exactly how true this is, but it worked recently for me. pipe was clogged again, EGR was not sticky. Saved a lot of time/mess. [/SIZE] Last edited by MS3Shadow; 03-17-2016 at 10:03 AM. |
| The Following 145 Users Say Thank You to Raider For This Useful Post: | 802MS3 (03-09-2010), Addikted To Boost (03-09-2010), AJ713 (07-28-2010), anavrinIV (01-11-2012), ASHMS3 (02-04-2013), atlasfiver (04-19-2010), Awesomesauce (11-19-2012), AZSPEED3 (07-30-2010), Benny71 (09-23-2012), bertrand_CX_7 (12-23-2011), bioevolve (03-15-2010), Blackspeed (03-08-2010), BolvangaR (03-09-2010), Boosted Beluga (10-17-2011), bozzben (05-07-2011), breakfstincluded (10-16-2011), Brokeswagon (06-11-2013), CaptainCode (04-18-2014), Cataphract_40 (01-17-2011), Cheapspeed (04-13-2013), Ckmazdaspeed3 (12-20-2010), Constantin (03-25-2012), Dahouse702 (08-28-2011), DaleNixon (07-30-2010), danesti (03-09-2010), dantes5823 (01-14-2012), Dash08 (05-04-2010), dead-zone (10-03-2012), derp_ms6 (05-16-2014), deuce_WI (09-12-2011), Dezine (01-25-2016), djthom (03-08-2010), dkapetansky (09-18-2011), Docnox (03-15-2010), Domino81 (10-12-2011), Easter Bunny (09-05-2011), eljefe62 (01-15-2013), England15j (11-19-2012), f-castrillo (04-25-2012), Fatpig78 (09-27-2013), Ferdball (05-06-2011), Ferg (09-09-2011), Figgz_MS6 (03-23-2015), flyrevs2 (03-10-2010), Fobio (03-09-2010), Grumpyjap (06-15-2012), gtarman77787 (08-02-2010), hank25 (01-14-2012), Hank3 (04-21-2010), i8urgti (04-23-2011), Ingle (01-06-2012), jabeel00 (12-03-2015), JacksonMS30 (02-26-2011), jax ms3gt (01-06-2011), jdub0802 (06-29-2012), jmustang68 (10-29-2012), JNR5005 (07-24-2011), johnheer (12-15-2012), jracer (01-12-2011), jtspells (06-19-2011), karl-hungus (03-09-2010), keridil (09-10-2012), keychain12 (04-25-2014), Kfunk (02-15-2013), kgb (03-28-2010), kilik2 (03-11-2010), kpsoerensen (01-20-2012), kpuser1 (12-22-2011), KusteLokal (05-14-2011), kylec_2003 (10-10-2012), labikesrcool (08-02-2010), liljae8 (01-10-2015), LTHorn (02-09-2012), M$3ChoquiM$3 (02-07-2011), m249saw (03-18-2012), madvillain (03-10-2010), magicka (05-17-2013), Manny3 (05-14-2011), massiespeed3 (02-12-2011), MATT DAMOND (03-10-2010), maxcaprez (10-22-2012), mazdapunk87 (03-28-2010), Mazdarune (03-21-2012), meelo88 (05-22-2011), MGM_GT3 (05-16-2010), Micha (04-08-2012), midoritora (01-05-2012), Mistersix (05-14-2011), Mizzle (08-03-2013), Monotonous ONE (04-12-2011), MS3 Ventura (03-28-2010), ms3blackmica (11-20-2012), MS3MYK (05-28-2012), MS6FL (06-04-2011), neotide87 (05-31-2012), neverone99 (08-02-2010), Night Wolf (02-10-2011), Nliiitend1 (06-13-2013), nofel (12-30-2012), NoRegrets (07-22-2012), nycMS3 (07-08-2013), nyghtryder (03-20-2010), onelove221 (09-02-2011), paradigmshift (04-06-2011), ponny135 (02-04-2012), radbrad (06-16-2011), randino69 (01-27-2013), RAR (03-27-2012), rfinkle2 (02-11-2016), rfomzr (03-13-2010), rghispanic88 (12-26-2011), Rich990 (05-22-2013), rolanblack (06-15-2012), Sacrilicious (03-09-2010), silversurfer3 (03-08-2010), simply_pandora (11-23-2012), SKiZ0TT (09-09-2011), SLOWHATCH (08-28-2011), soccerballz (04-23-2010), speed23 (02-11-2011), Speed3eak (06-19-2011), SPEEDRAC3R (05-17-2013), spike589 (03-30-2010), spoolin00 (05-30-2011), taf0422 (01-09-2011), tddvrrn (03-17-2012), The Nut (03-21-2015), Tommy (05-22-2011), TopazM3 (03-17-2010), txmedic512 (10-14-2015), UCHAUJ00 (11-06-2019), Vansquish (03-17-2016), WAHBAM (07-23-2011), wankular (11-22-2010), warlockfan92 (12-30-2012), warlord (07-08-2011), WhiteNoise (07-17-2011), whos_MS3 (07-24-2011), xdm88 (03-03-2011), xfeejayx (04-17-2011), xtasy (05-17-2011), zpele (07-07-2011), Zpuhalla (10-15-2013), zxhoya (05-02-2013) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 141
Groaned at 26 Times in 11 Posts
| Not Ranked : 0 score How many miles have you put on it since then??? Great write up btw
__________________ Rota wheel whore #1 MOdS list shaved with a razor moldings (EDGE cream)~de-BaGEd FTW~ painted StoCk wheels secret color ~ rattl;e caned RooF~ jdm painted brake conversion~ clear tint ~ light weight black hood and trunk with wing option ~ japanese amber side markers/ running lights ~ tw0 light weight car seats ~ shifter weight reduction ~ stock recaros with red stitching ~ mp3 mazda stereo for sale: ms3 transmission second gear is worn out. Perfect if you want to Upgrade it or if you don't want to have any down time if you're trans is messed up! PM me with offers |
Groans: 356
| Not Ranked : 0 score take a pair of vise grips to the tube and pinch it!!! the end.
(Thread Starter) | Not Ranked : 0 score A whopping 86. I just did it yesterday. The EGR was truly stuck, not moving. Got it to move a little before it was sprayed down with cleaner. We did not stop cleaning until it was not sticking at all. Was moving freely upon reinstall. I edited the 1st post. This is for those who want to retain the EGR. Last edited by Raider; 03-08-2010 at 11:34 AM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Aug 2008 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score Great write up. Glad you did it and not me...haha. |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score i have a really stupid question. if one (yours truly) has egr blocked off, would i still benefit from cleaning egr valve? |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score did you regularly seafoam her previously?
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
Groans: 1,940
| Not Ranked : 0 score 47k seafoamed once |
Groans: 356
about the really stupid part, nub.
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE | |
(Thread Starter) | Not Ranked : 0 score I never Seafoamed it before. Had 2 cans waiting for 6 months, just did not get around to it. zfreebird, it is actually very easy to do, just takes an hour or so. Well worth it. 300 miles, no CEL yet. I did some research for Phillyb. If the EGR is blocked off, try using muffler bearing lube on it as well. That is only for those with it blocked off, It is NOT for those with the EGR in use. |
| The Following 3 Users Say Thank You to Raider For This Useful Post: |
![]() Join Date: May 2009
Rep Power: 371 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score noob question: If you do the egr blockoff and get the cel, then clear it with the AP will the cel keep coming back ? I don't mind clearing something once but if I gotta do it everyday, forget it. Thanks By the way OP, excellent write up !!!!!
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
| Not Ranked : 0 score nice 80's jacket
| The Following 11 Users Say Thank You to superskaterxes For This Useful Post: | Ckmazdaspeed3 (12-20-2010), DaleNixon (07-30-2010), jmhinkle (03-09-2011), karl-hungus (03-10-2010), KevMS6 (03-05-2012), labikesrcool (08-02-2010), NoTraction (06-24-2012), N|njutsu55 (03-10-2010), Raider (03-13-2010), Tech/Sales@EM (05-06-2011), TheProYodler (01-30-2016) |
| Banned ![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score great post! a friend with a MS6 got this code, and i told him that his EGR was prolly clogged. i think he has 80k+ miles on his car... as these cars get older, this will be more of a problem. i will point him to this thread. thanks! would it be wise to seafoam first to try to remove some of that buildup? Last edited by i <3 bitches; 03-12-2010 at 04:23 PM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score As for the jacket, spot on. He also has an original Airborne Express delivery jacket, too. Was cold, and did not want to ruin anything new. And flyrevs, ATR permanently removes the code. Last edited by Raider; 04-14-2015 at 01:25 PM. |
![]() Join Date: Sep 2009 Location: Plymouth, MA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score |
(Thread Starter) | Not Ranked : 0 score It is a Charlotte Hornets jacket, actually. |
| The Following User Says Thank You to Raider For This Useful Post: | DaleNixon (07-30-2010) |
![]() Join Date: Sep 2008 Location: CT/NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
Groans: 35
| Not Ranked : 0 score Thanks, I need to do this in the near future. I continually get this CEL too.
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install |
![]() Join Date: Dec 2009 Location: Middle Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score I did this a few weeks back. It really is an easy job. I could do the whole thing in under half an hour really. Good writeup. Anyone w/ high mileage should definitely consider this. It will help with rough idling too.
__________________ 09 Speed 3 GT |
| The Following User Says Thank You to shpankey For This Useful Post: | Docnox (03-16-2010) |
![]() Join Date: Mar 2008 Location: Hudson Valley, NY
Rep Power: 246 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Can the EGR pipe on the side of the throttle body (flare fitting side) be removed without removing the throttle body? I'm willing to spend money on a specialty tool to get to it.
__________________ DIY: Sea Foam |
| Not Ranked : 0 score I didn't even mess with the pipe. Just cleaned the EGR and made sure the plunger moved up and down freely.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 546
| Not Ranked : 0 score Wow, that is so much more work than doing it on the protege5. That sucks.
__________________ 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforum.org/forum/foru...ler-you-58361/ |
(Thread Starter) | Not Ranked : 0 score I did it on my Protege5. This is way easier, imo. Mainly because I did not have to fight the EGR bolts. That sucked. As for taking the pipe off, I am not sure, maybe from underneath with a powered slim wrench of some sort, I doubt it. Honestly, the throttle body removal was 2 minutes. The only reason I did take it off was because I have heard of at least 1 person with a clogged EGR pipe. Mine did have some loose stuff in it, and where it mounted there was a literal pile of carbon. |
| I have candy in my van ![]() Join Date: Apr 2009 Location: Chicago, IL
Rep Power: 2810 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,091
Groans: 70
But honestly, as ^ that dude said, taking off the TB only takes a few mins. If you do it w/o removing the TB, you'll jack up the threads on the EGR bolt, and you'll be wasting more time trying to get it out. If you want to save time, take off the TB.
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project | |
| The Following User Says Thank You to MATT DAMOND For This Useful Post: | Raider (03-20-2010) |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I forgot about how shitty the EGR pipe threads were until you mentioned that. I had a hell of a time on my Protege getting the EGR pipe threaded into a header. Thought it was right nope, needed a new pipe. |
![]() | | #25 | ![]() |
![]() Join Date: Mar 2010 Location: san antonio,tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 107
| Not Ranked : 0 score very awesome write up OP ! , i will need to do this in the near future on mine ! |
![]() | | #26 | ![]() |
![]() Join Date: May 2008 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score Thanks for the writeup, I just got the CEL Sunday, and will have to do this process this week. For informational purposes for anyone reading this in the future. Up until the CEL, I did notice each time I cranked the car, the Idle remained High until it got really warm. Typically, the Idle is high when initially cranking, and then settles down very quickly.
__________________ [SIGPIC][/SIGPIC] CPE-SRI - HKS-SSQV - CPE-MM - TWM SB - Cobb AP Cobb FMIC - Cobb CBE - DP 18x8 +48 HP Design 235/40/18 BFG Riken, H&R Springs |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score I did not get that symptom, but i only had it clogged for 2 days. I am about 1000 miles since cleaning, maybe more. No CEL. |
![]() | | #28 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Thanks for the write up. Took this on last weekend after a P0401 search came up with your "How To..." Still no CEL after a weeks worth of driving. My EGR did not appear to be stuck closed after 39K miles but was somewhat sticky. I used the suggested brake cleaner and an aluminum paddle applicator to remove gunk. The tube wasn't clogged but received some attention too. I like the pressed in orifice idea and will look for updates to see if that mod continues to allow some flow without the CEL and causes no problems for the EGR valve. The amount of wet gunk noted at the end of the tube and in the IM is disappointing. I imagine the backside of the TB looks similar. I used a 22mm crowfoot and extension to loosen the tube's compression nut so I didn't remove the throttle body. I want to install a catch can but I need 20 posts to PM the guy selling kits. <sigh> Mini rant: Why is every electrical connector on this vehicle designed differently? You almost have to nearly reverse engineer each one to disconnect it! Thanks for reading, 4 posts to go. |
| The Following User Says Thank You to atlasfiver For This Useful Post: | Raider (04-19-2010) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score I doubt I have 100 posts yet. But I threw some $ at the forum, I got VIP which allowed access to a shit-ton more than those without it see. Glad it worked! |
![]() | | #30 | ![]() |
![]() Join Date: Aug 2009 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
| Not Ranked : 0 score Awesome write up. Unfortunately I am at 27k and I am starting to get this code. I heard the only bad thing that would happen if I just kept clearing the code would be not passing emissions, which I dont have anyways. Is this true?
__________________ 08' Black Mica MS3 Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight. Sponsored by NATOR VA |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score My car was taking a long time to fire up. Lots of cranking.I got one guy on my CX-7 forum who got the same code and his car will not run at all it is so clogged. Just fix the problem is my advice. I wrote the how to for a reason! |
![]() | | #32 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score now my egr is off i should just pull the egr valve thing off and block that off too. weight savings of like 1lb. haha. also that check valve on that line (4) in the picture - i had to replace that line because the stock line wouldn't fit onto the connector whoosh put on the manifold and couldn't take the valve off the hardline. what can i replace it with - do i need to? |
![]() | | #33 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
Groans: 57
| Not Ranked : 0 score I started getting the code over 6000 miles ago. I switched from Kroger 93 octane to BP 93. After a couple of tanks of BP the CEL disappeared and hasn't returned; I'm currently at 59K.
__________________ Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score might be coincidence, just having a blockage come loose and can breathe. Next time it happens, try even taking the EGR pipe off for a look. |
![]() | | #35 | ![]() |
![]() Join Date: Apr 2008 Location: MS
Rep Power: 845 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Groans: 56
| Not Ranked : 0 score I've been getting the code, off and on, for about 5k miles now. I think I clean this sucker on saturday. |
![]() | | #36 | ![]() |
Groans: 57
| Not Ranked : 0 score That's the plan...
![]() | | #37 | ![]() |
![]() Join Date: Jul 2008 Location: Toronto
Rep Power: 0 ![]() ![]() Thanks: 85
| Not Ranked : 0 score Nice story. Everyone lived hapily ever after, and cost ya ziltch to boot. |
![]() | | #38 | ![]() |
![]() Join Date: Apr 2010 Location: Schaumburg, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 325
| Not Ranked : 0 score good write up and pics |
| The Following User Says Thank You to ms_3 For This Useful Post: | Raider (07-17-2010) |
![]() | | #39 | ![]() |
![]() Join Date: Oct 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
| Not Ranked : 0 score There are coolant lines going to the throttle body? If you drained it from the EGR side already will fluid still come out from the TB lines?
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT |
![]() | | #40 | ![]() |
(Thread Starter) | Neutral : -1 score Not sure. I bypassed mine. They have it so the people who live where it snows, do not have stuck throttle bodies in the winter. I would to the rear of the motor first, then the tb. It will not be much thought, is my guess. Last edited by Raider; 07-30-2010 at 02:04 PM. Reason: MSF Database - Automerged Doublepost |
| Mazdaspeed CAI filter- how to clean? | red07 | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 08-15-2012 02:24 PM |
| how to: clean up oil from your driveway | phillyb | MazdaSpeed 3 - How-To's | 26 | 11-04-2009 02:06 PM |
