> MazdaSpeed 3 - How-To's
Like Tree4Likes
 Old 04-20-2008, 11:46 AM   #1
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Default How To: Ignition coil spring stretch mod
Remove ignition coil:
Pull apart to reveal the coil spring:
Stretch the two smaller sections of coils by ~1/4-1/2'' each.
Put back together. You will now have more contact force on both ends, which some people have found to help.
It is really that easy.
sarm1084 likes this.
The Following 20 Users Say Thank You to cld12pk2go For This Useful Post:
3Gee Tee (10-11-2012), ak_spray (01-03-2012), Awal (06-03-2015), AZSPEED3 (02-04-2012), Crossbow (04-21-2008), Docnox (11-28-2011), DR_ (05-08-2009), flashfrenzy (04-20-2008), JacksonMS30 (08-04-2010), knarfies (05-15-2012), MS3G35 (05-30-2012), Nataphen (05-17-2011), Plimmer (02-20-2015), sarm1084 (04-24-2018), scorpiorc10 (02-05-2012), SLOWHATCH (02-04-2012), Tomas (08-03-2013), toprock (08-03-2009), uncorked11 (02-04-2012), WetzMS3 (01-20-2015)
 Old 04-20-2008, 12:25 PM   #2
dadasracecar's Avatar
Posts: 741   (View Stats)
dadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the world
I stretched mine at least two inches more than that.
2008 BMW 335i 6MT black on black
www.p3performance.net
dadasracecar is offline   Reply With Quote
The Following User Says Thank You to dadasracecar For This Useful Post:
stevenfever (04-29-2013)
 Old 04-20-2008, 12:27 PM   #3
Eth/Meth Junkie
cld12pk2go's Avatar
I have never seen the actual distance specified before. It will be interesting to see how much other people stretch theirs...
I did this mod because I had spark blowout after installing my PG manifold above ~13 PSI.
Turns out that I had evidently altered the gap on one plug to ~0.055'' when I checked the gaps to assure they were all ~0.030'' during the manifold install.
I don't know how the hell I did that, but evidently I did.
Setting all my gaps to 0.029-0.030'' coupled with the coil spring stretch mod eliminated the spark blowout. However, I am 99% sure my issue was related to the fat ass gap on that one plug.
 Old 08-10-2009, 07:33 PM   #4
devils10's Avatar
Posts: 149   (View Stats)
devils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud of
Groaned at 45 Times in 24 Posts
Neutral  :  -1 score
interesting
devils10 is offline   Reply With Quote
The Following User Says NO Thank You to devils10 For This Un-useful Post:
 Old 04-20-2008, 12:26 PM   #5
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Ha i stretched the middle part of mine. Think that hurts any?
 Old 04-20-2008, 12:29 PM   #6
Eth/Meth Junkie
cld12pk2go's Avatar
I thought about that, but that will just make the middle part kink up in its zone without applying additional force to the two ends.
Or at least that was what I was thinking while doing the mod.
 Old 11-21-2008, 10:32 PM   #7
kopf's Avatar
Posts: 327   (View Stats)
kopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the world
What does this do exactly? What are you trying to fix or prevent with this mod?
kopf is offline   Reply With Quote
The Following User Says Thank You to kopf For This Useful Post:
phillyb (04-23-2009)
The Following User Says NO Thank You to kopf For This Un-useful Post:
 Old 08-03-2009, 09:42 PM   #8
turbochris700's Avatar
Posts: 90   (View Stats)
turbochris700 is a splendid one to beholdturbochris700 is a splendid one to beholdturbochris700 is a splendid one to beholdturbochris700 is a splendid one to beholdturbochris700 is a splendid one to beholdturbochris700 is a splendid one to beholdturbochris700 is a splendid one to behold
+1
See my old race car's video's on my MySpace page at http://www.myspace.com/chris4g63
turbochris700 is offline   Reply With Quote
 Old 07-13-2009, 01:17 AM   #9
steven88's Avatar
Posts: 773   (View Stats)
Groaned at 9 Times in 5 Posts
anybody else stretch their springs further than OP pictured above?
steven88 is offline   Reply With Quote
 Old 08-04-2009, 04:29 AM   #10
Eth/Meth Junkie
cld12pk2go's Avatar
Preventing spark blowout via producing a better electrical connection.
 Old 01-12-2010, 09:36 AM   #11
Bonafide_Spd3's Avatar
Posts: 344   (View Stats)
Bonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond reputeBonafide_Spd3 has a reputation beyond repute
This is interesting. I'm suprised nobody else has mentioned anything about this
2007 Cosmic Blue Speed3
[ MS CAI w/Straightener] [Cobb AP] [ RPMC TI ] [ FORGE BPV ] [ SU RP ] [ PG FMIC ] [Denso Plugs] [Trz MM] [ TWM SS&Bushings ] [ Greddy TT ] [ Defi Boost Gauge ]
Not going to install-Weapon R catch can. Piss on doing that install
Bonafide_Spd3 is offline   Reply With Quote
 Old 05-12-2010, 07:55 AM   #12
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
im gunna do this
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
 Old 05-12-2010, 08:07 AM   #13
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
replace that coil spring with a copper or silver spring and see what you get.....
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 05-12-2010, 03:46 PM   #14
Eth/Meth Junkie
cld12pk2go's Avatar
Neutral  :  -1 score
Damn, it is difficult to believe I started this thread over 2 years ago...
What a weak ass car I had back then...
ak_spray (01-03-2012), karl-hungus (05-12-2010)
 Old 12-18-2010, 09:06 PM   #15
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
I just did this mod and messed up on two, I stretched them from the middle part, any consequences from that?
 Old 12-19-2010, 10:43 AM   #16
Eth/Meth Junkie
cld12pk2go's Avatar
As long as you can get it back together and it runs, then you are probably fine.
 Old 12-19-2010, 10:55 AM   #17
the spring went in fine and the car starts/idles normal. Should I be ok? I know Darksun mentioned he also stretched it from the middle.
 Old 12-19-2010, 01:13 PM   #18
IM A SCAMMER
BlackMS6's Avatar
Posts: 63   (View Stats)
BlackMS6 is just really niceBlackMS6 is just really niceBlackMS6 is just really niceBlackMS6 is just really nice
You'll be fine... it wont harm anything
BlackMS6 is offline   Reply With Quote
 Old 05-17-2011, 07:01 PM   #19
Nataphen's Avatar
Posts: 2,704   (View Stats)
I just remembered to do this since I'm changing plugs for the first time right now. I wanted to make sure that I knew how to pull the coil packs apart without breaking them, LOL. Thanks for the pics.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
 Old 05-17-2011, 08:20 PM   #20
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
i did it last week
its really easy to not break the springs...just dont be a fucking idiot
MHHC5280 (03-07-2014)
 Old 05-17-2011, 09:26 PM   #21
Nataphen's Avatar
Did it. With the new ITV22 plugs@.028 and stretched coils, I logged 0.0 KR on three 0-100 pulls with hard launches while FFS on all shifts. Guess it's time to advance timing some more.
13 5.0
Wife's 13 Focus ST
The Following 2 Users Say Thank You to Nataphen For This Useful Post:
DingoDave (10-31-2011), manelscout4life (05-17-2011)
 Old 02-04-2012, 04:41 PM   #22
mysleeper6's Avatar
Posts: 204   (View Stats)
mysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the world
Changed plugs and did this. I found it helpful to use a flathead screwdriver to seperate the two halves of the coil. They were easier to pull apart that way.
mysleeper6 is offline   Reply With Quote
 Old 02-04-2012, 05:19 PM   #23
blue_train's Avatar
Posts: 61   (View Stats)
blue_train is just really niceblue_train is just really niceblue_train is just really niceblue_train is just really niceblue_train is just really nice
Groaned at 9 Times in 4 Posts
sorry to revive this, but where is the ignition coil located?
no0b question, bare with me
blue_train is offline   Reply With Quote
The Following User Says NO Thank You to blue_train For This Un-useful Post:
Don06speed6 (02-04-2012)
 Old 02-04-2012, 08:03 PM   #24
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Underneath the top mount intercooler.
The Following User Says Thank You to SLOWHATCH For This Useful Post:
 Old 02-04-2012, 07:18 PM   #25
mysleeper6's Avatar
They sit directly on top of your spark plugs.
The Following User Says Thank You to mysleeper6 For This Useful Post:
 Old 05-09-2012, 07:07 PM   #26
midlifecamry's Avatar
Posts: 14   (View Stats)
midlifecamry is a jewel in the roughmidlifecamry is a jewel in the roughmidlifecamry is a jewel in the rough
Default This may have completely solved my stutter/hesitation issue
My 2006 MS6 (Cobb Stage 1) has always had stutter/hesitation issues. Colder plugs helped, replacing the plugs when worn/fouled helped, but there was never a time when WOT, even above 3K rpm, didn't present the prospect of epic fail instead of epic acceleration.
I recently stretched my coil pack springs by approximately 1 inch (shame on Mazda and FoMoCo who actually makes the coils for such a horrific/cheap design). Granted, I also replaced my plugs with NGK LTR7IX-11 (one step colder, equivalent to the Denso ITV22).
I can't emphasize enough the dramatic difference in performance. It's been two weeks and the car relentlessly surges forward in any gear, even at lower RPMs. I have been unable to reproduce the hesitation problem in any gear at any reasonable combination of RPM or speed.
To recap, here is what I think helped, in no particular order:
o stretching the coil pack springs. Do your stretching from the ends, and when you're done, roll them over a flat surface to make sure they aren't cockeyed, especially at the spark plug end. They should be centered in the boot.
o switching to the NGK plugs. The NGKs have a solid tip where they contact the coil pack spring. The Denso's don't. Their design is more like a "collar" around the electrode which doesn't leave a flat surface for the spring to make contact.
o gapping the plugs. I bought a high quality feeler gauge and set the gap to .30. It was *not* correct out of the box. Maybe the Densos are, but I would recommend checking regardless of brand.
I hope this helps someone. The difference is seriously not subtle at all. I finally feel like I can enjoy this car.
rfinkle2 and Bill6639 like this.
midlifecamry is offline   Reply With Quote
The Following 4 Users Say Thank You to midlifecamry For This Useful Post:
Brennan (05-15-2012), jm211 (10-18-2012), MikeyLikes (06-09-2013), MS3G35 (05-30-2012)
 Old 05-09-2012, 07:43 PM   #27
btstarcher's Avatar
Posts: 4,852   (View Stats)
I might be trying this. Subbing.
SnailTune in progress
 Old 05-09-2012, 07:58 PM   #28
m4tic's Avatar
Posts: 4,928   (View Stats)
I just stuck copper rods in my coil packs, tossed the springs
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 05-09-2012, 08:29 PM   #29
Effing brilliant. What did you use for materials? And did you cut the rods to a specific length? Or are you just messing with me? ;-)
The Following User Says Thank You to midlifecamry For This Useful Post:
SLOWHATCH (05-09-2012)
 Old 05-10-2012, 12:15 AM   #30
m4tic's Avatar
Home depot racing, #4 AWG bare copper. About 2-3/8" each.
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 05-15-2012, 03:28 PM   #31
PakmanMS3's Avatar
Posts: 2   (View Stats)
PakmanMS3 is an unknown quantity at this point
What plugs did you use with this set up?
PakmanMS3 is offline   Reply With Quote
 Old 05-10-2012, 05:01 AM   #32
Eth/Meth Junkie
cld12pk2go's Avatar
Still helping people after 4+ years...this must be a good thread.
The Following 7 Users Say Thank You to cld12pk2go For This Useful Post:
DingoDave (05-10-2012), jscape83 (07-23-2012), MHHC5280 (03-07-2014), redmnsterut (05-15-2012), silentwolf8 (05-30-2012), span (10-13-2013), thehead (06-23-2012)
 Old 05-15-2012, 03:42 PM   #33
m4tic's Avatar
Cheap ass autolite xp iridiums xp5263
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 05-15-2012, 04:07 PM   #34
Thanks m4tic for the Home Depot Racing tip.
I have to agree, fancy, expensive plugs are kinda bunk. I think the best approach is to replace whatever you're using on a yearly basis. Direct injection, contrary to what the manufacturers claim, is dirty and prone to carbon buildup.
fwiw, I used NGK (6510) LTR7IX-11, and I still think the solid tip where the coil spring pack makes contact is a plus. They cost about $7.50 per plug. But I bet a $4 Autolite would work just as well.
Also, an update -- it's been close to two weeks and I still can't get this engine to misbehave even if I abuse it with WOT at lower rpms. This has never been the case in the past when I replaced plugs, so I have to believe the real issue is with proper contact between the coil pack spring and the plugs.
And again, I think proper gapping is key. This time around, I checked/adjusted the gap to .30, which I'd never done in the past.
DingoDave (05-15-2012)
 Old 05-15-2012, 07:51 PM   #35
memin's Avatar
Posts: 994   (View Stats)
be carefull with the zoom, zoom, BOOM
 Old 05-15-2012, 07:42 PM   #36
PakmanMS3's Avatar
What about getting the Denso IV22 the step colder ones would you have to get longer copper rods because they are shorter. and is the NGK step colder ones the same length as the stock ones?
 Old 06-11-2012, 01:14 PM   #37
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
I might try this out tonight. Even with the NGK 1 step colder plugs gapped to .028, I am getting more knock than I would like. I wonder if using multi strand 4 guage stereo wire would be more effective than 2-3/8" #4 AWG bare copper since there is more surface area.
Pickles Tune in progress
 Old 06-14-2012, 05:48 PM   #38
m4tic's Avatar
Home Depot Racing #4 AWG bare copper
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 06-14-2012, 06:38 PM   #39
himurax13's Avatar
Groans: 255
Hmm, I did the mod and I didn't notice any difference in my logs.
 Old 06-14-2012, 08:24 PM   #40
m4tic's Avatar
it's not an hp mod... It's more for consistency.
2017 Daytona 392
2007 MS6 w/ Cheez
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-ignition-coil-spring-stretch-mod-4577/
mx5cartalk.com ? View topic - Coil pack spring stretch mod. This thread Refback 11-02-2015 02:47 AM
Inconsistant KR after plug swap This thread Pingback 06-03-2015 04:53 AM
COP issues - Ford F150 Forum - Community of Ford Truck Fans This thread Refback 02-15-2015 09:18 AM
RaZeR's 6er MPS - Seite 12 This thread Refback 05-25-2014 10:20 PM
Hesitation Issue - Possible Fix? (spring stretch) - Maxima Forums This thread Refback 04-22-2014 02:03 PM
her heart is healthy... - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-18-2014 05:54 AM
Stretching Coil Packs - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-18-2013 05:13 PM
redlinegti.com ? View topic - Suzuki Sport coils This thread Refback 06-21-2013 01:02 AM
maintenance question : mazda This thread Refback 04-14-2013 06:49 AM
2012 Mazda 3/Mazdaspeed 3 Forums - 2012 MS3 Misfire P0300 Code This thread Refback 02-05-2013 05:25 PM
2012 Mazda 3/Mazdaspeed 3 Forums - E3 spark plugs This thread Refback 01-11-2013 09:52 AM
2012 MS3 Misfire P0300 Code - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 11-15-2012 05:54 PM
E3 spark plugs - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 11-08-2012 05:49 PM
Random MS3 Chat Thread - Page 120 This thread Refback 10-20-2012 01:18 PM
2010 Mazda 3/Mazdaspeed 3 Forums - View Single Post - E3 spark plugs This thread Refback 09-14-2012 06:08 PM
2012 MS3 Misfire P0300 Code - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 06-11-2012 10:34 AM
Mazda 3 Plug wire help! : mazda This thread Refback 05-14-2012 11:00 AM
E3 spark plugs - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 03-13-2012 03:00 PM
Toronto Mazda 6 • View topic - Spark Plugs This thread Refback 04-28-2011 12:20 PM
Hesitation Issue - Possible Fix? (spring stretch) - Maxima Forums This thread Pingback 04-27-2011 09:24 AM
2007-2008 MS3 AccessPORT Calibration Reviews - Page 2 - COBB Forums This thread Refback 10-10-2008 05:00 PM
2007-2008 MS3 AccessPORT Calibration Reviews - Page 2 - COBB Forums This thread Refback 05-16-2008 10:12 AM
2007-2008 MS3 AccessPORT Calibration Reviews - Page 2 - COBB Forums This thread Refback 05-15-2008 10:39 PM
2007-2008 MS3 AccessPORT Calibration Reviews - Page 3 - COBB Forums This thread Refback 05-15-2008 02:06 PM
2007-2008 MS3 AccessPORT Calibration Reviews - Page 3 - COBB Forums This thread Refback 05-15-2008 01:54 PM
2007-2008 MS3 AccessPORT Calibration Reviews - Page 3 - COBB Forums This thread Refback 05-15-2008 01:37 PM
Buying BC Racing Coil Overs Haltech MazdaSpeed 3/6 - Suspension & Brakes 41 08-07-2008 07:28 PM
Anyone riding on MS Coil-overs or Springs? AutoXRacer MazdaSpeed 3/6 - Suspension & Brakes 44 06-19-2008 11:00 PM
MT: Cooling Fan Keeps Operating-Ignition Turned Off Crossbow MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 04-20-2008 05:03 PM
Carbonyte to stretch Lambo, Koenigsegg and Veyron into limos Haltech Automotive News 1 04-13-2008 06:35 PM
Page generated in 0.58816 seconds with 42 queries
