> MazdaSpeed 3 - How-To's
Like Tree103Likes
 Old 04-16-2013, 09:15 AM   #41
Rokusek's Avatar
Posts: 5,551   (View Stats)
only thing you have to do is once you have the engine in time and everything tight just turn the engine slightly so that the cam lobes that is flat is almost flush with the bucket and it should slight right on.
Sweet! I will update the OP with this
 Old 04-24-2013, 08:46 AM   #42
Rokusek's Avatar
OP UPDATED
 Old 05-01-2013, 02:44 PM   #43
baardoon's Avatar
Posts: 31   (View Stats)
baardoon is a splendid one to beholdbaardoon is a splendid one to beholdbaardoon is a splendid one to beholdbaardoon is a splendid one to beholdbaardoon is a splendid one to beholdbaardoon is a splendid one to beholdbaardoon is a splendid one to behold
when ordering the parts, i need to order the timing chain guide and the timing chain lever correct? i havent really seen it specified as most people refer to both as the guides. thanks for the right up as well. should be a huge help here pretty soon!
baardoon is offline   Reply With Quote
 Old 05-01-2013, 05:25 PM   #44
Rokusek's Avatar
Yes you are correct. They aren't always needed, so when you do buy them don't open them and keep the receipt so you can return them if needed. They don't usually wear out to much.
I replaced mine when I built my motor at 85k, it's better to have them and not need them than to not have them and need them.
TiGraySpeed6 (05-01-2013)
 Old 05-24-2013, 12:50 PM   #45
Bathor10's Avatar
Posts: 16   (View Stats)
Bathor10 has a spectacular aura aboutBathor10 has a spectacular aura aboutBathor10 has a spectacular aura about
Ok after almost a month of dealing with lost and damaged package with ups I finally got my timing tools. Everything went easy during the install. But now I'm having a problem. Under hard acceleration I'm getting a popping noise comming out the exhaust. I double and triple checked the timing before even cranking the engine. The chain I pulled out was almost 1/4 inch streached compared to the new replacement. Which would have caused a retard timing. Now that I have the new one installed it would advance it that much. So I figured my octaine wasn't enough. But after octaine boost and 93 fuel I'm still getting the same problem. I'm thinking about pulling it back apart and checking or maybe even retarding the timing. Just wondering if anyone has any imput on something I may be looking over before I do that job again.
Bathor10 is offline   Reply With Quote
 Old 05-24-2013, 01:10 PM   #46
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
It sounds like unburnt fuel is burning in your exhaust, which could be caused by improper exhaust valve timing. I know you checked it, but that seems like the most logical reason right off the bat. What modifications are you running? What does your tune look like in terms of AFR and ignition timing? Do you have any logs?
EDIT: Is it possible your crank position sensor was installed improperly and now your ignition timing is retarded?
 Old 05-24-2013, 02:31 PM   #47
Bathor10's Avatar
As of right now a cat back and a cold air. Factory tune.
Pretty sure it's gotta be the crank off if anything. I did some old school stuff when setting it up counting the chain lengths to make sure it was exactly the same between the intake and exhaust cam. But being the crank is not keyed I couldn't count those. But if I go back into it to reset it atleast I won't have to pull off the front cover. So will save me a bit of time.
Last edited by Bathor10; 05-24-2013 at 02:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-25-2013, 10:59 AM   #48
thebestdj07's Avatar
Posts: 48   (View Stats)
thebestdj07 has a spectacular aura aboutthebestdj07 has a spectacular aura aboutthebestdj07 has a spectacular aura about
im having the same issue as /\.. did everything per the writeup. chain was tight after 3 turns by hand. replaced the ocv. 93octane. when i just pulled the cover off to replace the ocv the chain had a little slack in it but not alot. meaning it was not as tight as when i first installed it.
any ideas?
thebestdj07 is offline   Reply With Quote
 Old 05-26-2013, 10:27 PM   #49
Bathor10's Avatar
Well going to tear back into it in the morning. Going to start with putting the crank pin in place and check to see if the crank sensor is correct and to see if the 8mm bolt will go into the crank pulley. Maybe something turned when I impacted it back together. If those look correct going to pull the vc and fuel pump and reset that. Start with easy and move on up.
 Old 05-26-2013, 10:43 PM   #50
guitarzan134's Avatar
Posts: 948   (View Stats)
guitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the world
There is a specific tooth on the crank pulley that the CPS has to be aligned with. It is very obvious which one, as there is a small amount of white paint on the correct tooth. The paint was almost worm off mine, but after looking at the rest of the pulley teeth, it was a no-brainer.
When we replaced my timing assembly, my CPS was slightly off. We loosened the intake cam bolt to allow the chain to rotate (we only needed a couple of teeth), and then adjusted the crank pulley and CPS. We rechecked the timing with the tools, then tightened the cam bolt (not tty, as mentioned earlier). Car has been kicking ass for ~15k, since.
Good luck!
I literally drive the wheels off Mazdaspeeds. Come at me, bruh!
2007 Mazdaspeed3 GT Black Mica
-~CORN!!! - Corksport PMM, CBE, SRI, & TIP - UR TP - Ebay DP - ETS TMIC - PnP IM - CPE SafeSeals - Autotechs - Forge V1 - NGK IX - Cobb AP, RSB - JBR TIG's + CB, Knob, SSB, & 88a RMM - GT-Spec chassis bracing - Hawk HPS/Stoptech Posiquiet - Technafit Lines - DBA T3 - ATE TYP200 - Moog Endlinks - Koni Yellows - Rota Grids 18x8.5 - Michelin PSS 245/40~-
guitarzan134 is offline   Reply With Quote
The Following User Says Thank You to guitarzan134 For This Useful Post:
SLOWHATCH (07-30-2013)
 Old 05-27-2013, 12:36 PM   #51
Bathor10's Avatar
Ok reset the timing again. Now it pops even more... I also got to thinking. If the camshafts are properly alligned from counting the chain links and marking the teeth my crank pulley may in theory be off 1 or 2 degree and as long as the cps is set accordingly then it shouldn't really matter. Unless there is also a crank sensor located on the flywheel. How exact does the cps need to be centered on the white crank tooth? Cause I got it pretty close by eye. Don't really know what I'm going to do now.
 Old 06-11-2013, 06:02 AM   #52
Rokusek's Avatar
When you say your counting chain links and marking teeth, are you not using the timing tools? Stop counting stuff up top, use the tools and make sure the lobes over cylinder 1 are matched up with one another at a 45* angle.
If you have checked it a second time i would go back in and reset both the cam gears along with the crank. at this point i dont see much else you can do to try and fix this issue. being you have checked it already and it got worse.
The CPS needs to be dead center on the marked tooth on the crank pulley. There is only the crank position sensor on the bottom of the block and the cam alignment sensor that is on the vavlve cover next to the fuel pump housing.
The Following 2 Users Say Thank You to Rokusek For This Useful Post:
phate (06-11-2013), silvapain (06-11-2013)
 Old 06-11-2013, 06:38 AM   #53
Heres how I ended up setting mine install the cam holding tool so lobes ae at 45 deg. Install crank stop. Mark and remove the crk sensor then the pulley.do everything to get the timing cover off. loosen both cam bolts making sure your holding the cam with a wrench so u dont bust the end where the holder is......... adjust so chain is tight replace fricton washers between gears n cwm. tighten to 60ft lbs. At this point the chain should be tight and the holder will be able to slide in and out with no force, throw the crank pulley back on and snug it. Back the crank holder out a bit, remove the cam holder and rotate crank a full 2 times (remove spark plugs it makes this part easier) upon coming up on the 2 full rotatons end install the crank stop and make sure the crank hits it. The cam holder should slide right back in... if so then replace washers on crank put timing cover back on then reinstall the crank pulley beforreeeeee u get it tight also install the pulley holding bolt into the cover. Now tighten to 75 ft lbs mark the bolt and go another 90 deg. Install the crk sensor to match 20th tooth counter clockwise from missing one. Get on eye level with it. Remove all tools rotate 2 more times and it should line all back up............, if u done all that and still get the light well check the pcm. Go to the cmp sensor and run the test marked in the service manual.
 Old 07-23-2013, 12:38 PM   #54
Bathor10's Avatar
Ok guys I know it's been a while since I posted but I have officially found the problem. When I would have the popping noise I would immediately park the car and go back to work on it. I decided last week to just drive it and not drive it hard. About 4 days of that I finally got an engine light on. Checked it out was number 2 cylinder misfire. Replaced the coil and no longer that scary popping noise. I thought yay! Finally fixed it. Well few days ago got another light come on. Now it's only engine misfire no specific cylinder. I checked the ohms and voltage at each coil. Everything is up to spec and looking good. Nothing out of the ordinary with it cold or hot. I'm going to look at the other forums about that problem. Just wanted to give a final update on this page. Just many times of doing the timing system I feel like a pro at it now.  and to the last question yes I was using the timing tools. But on top of that I was counting the teeth cause that's how I always do them. Peace of mind thing for me.
Rokusek likes this.
The Following 2 Users Say Thank You to Bathor10 For This Useful Post:
Rokusek (07-23-2013), SLOWHATCH (07-30-2013)
 Old 07-31-2013, 08:32 PM   #55
Teejhorse's Avatar
Posts: 26   (View Stats)
Teejhorse is a jewel in the roughTeejhorse is a jewel in the roughTeejhorse is a jewel in the rough
Groaned at 16 Times in 2 Posts
Did you ever figure out what your problem was? I'm just curious because I desperately need to replace my timing chain and VVT but I dont have the money to get it done so I'm thinking about doing it myself. Im good at working on cars and everything but it sound like a pretty intimidatingly tough job. Any recommendations on things that you would do differently? Also about how long did it take you? "my car is my daily driver so I cant be without it long"
Teejhorse is offline   Reply With Quote
 Old 07-31-2013, 08:35 PM   #56
tastysi2004's Avatar
Posts: 1,063   (View Stats)
damn i just remember those days and nights as being long and cold as fuck for no reason!
2008 MS3 gt mica black
EL NATOR DE Virginia/Florida
Update: getting that
Purple drank in my tank.
554whp/546wtq @ 30psi.
another build? maybe soon..
#CATBACKEXHAUST
 Old 08-06-2013, 02:27 PM   #57
USMCMAzda's Avatar
Posts: 95   (View Stats)
USMCMAzda is a name known to allUSMCMAzda is a name known to allUSMCMAzda is a name known to allUSMCMAzda is a name known to allUSMCMAzda is a name known to allUSMCMAzda is a name known to all
Groaned at 146 Times in 20 Posts
what is the
Crank Pulley SST (M6x1) used to hold holds crank pulley in place while breaking crank bolt and torque. ?
USMCMAzda is offline   Reply With Quote
 Old 08-06-2013, 05:43 PM   #58
ajberhorst's Avatar
Posts: 242   (View Stats)
ajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond repute
So here is my two cents to put into this after a few chats over the iPhone and a lot of Face Timing haha.
I would update with a few more pictures. If your like me (pray to jesus you aren't), you know that you have a wrench that is adjustable, but you don't know that it is technically called a crescent wrench... and yes thats me admitting that before this I didn't know that (flamesuit engage).
... Another thing is that there should be a disclaimer for froobs like me that have only ever done bolts on's that you need to be able to removed your entire intake system, the wiring harness, fuel pump and the housing over the intake cam, valve cover, passenger motor mount, and the power steering pump. This would have been good for me to know as I did this because I went a long pulling stuff as I went instead of just pulling it all off at once, then tackling the actual project.
Another idea would be to put the part number for the Kobalt impact gun that you recommended to me because that thing is an animal and works better than two other air guns I tried to use. Just a thought though, most people probably know better than I did.
I would go more in depth into timing for anyone who tried to do this for the first time. I was incredibly confused about what exactly top dead center meant, but after you and 15driley15 explained it to me it made a lot more sense that this was your piston being at the peak of the cylinder. Also it should be mentioned that you need an incredibly strong bolt (at least grade 8) or you will have to buy an impact gun because you will bend and cause damage to that bolt hole... not that I did or anything... >_<...
Other than that the write up was phenominal and you were more helpful than I could have ever imagined. Not to mention you only gave me a little shit about that crescent wrench lol. Which was a fuck ton less shit than I deserved haha.
I would be happy to take pictures one weekend soon of things that I thought might be helpful if you want? Let me know and thanks brotha!:notworthy :
CorkSport TMIC, Stage II Short Ram Intake w/ Cold Air Conversion Box, Boost Tubes, Rear Motor Mount, and Turbo-Back Exhaust. Auto Tech HPFP Internals. H&R Lowering Springs. OEM Replaced Transmission, Clutch, Front/Rear O2 Sensors. Street Unit Iridium Spark Plugs.Custom Powder Coated Satin Black Rims. Replaced OEM Front Bumper.
VVT Actuator replaced at 101K Miles. w/ help from Rokusek & 15driley15
Stratified Tuned by Lex
ajberhorst is offline   Reply With Quote
 Old 08-06-2013, 05:50 PM   #59
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
Wonder if your flywheel is the culprit for your misfire? There are a few cases out there where the vibrations from the dual mass fly wheel have caused a misfire issue.
 Old 08-18-2013, 12:30 PM   #60
Lex2007's Avatar
Posts: 574   (View Stats)
My god man, you are an angel for posting this procedure. And I say this as an atheist!
All joking aside, you really are a true brother. A humanitarian. I have posted indepth instructions of this type on various forums and I know how much time it takes. We should all buy you one huge giant BEER plus a beer wench to service you.
So....I have a question. My 07 speed3 is at 74k...so Mazda will laugh if I go there asking for mercy. But before I decide to do this myself, I need to know what the implications are for fucking this procedure up. Thats my test for any such job. If I screw it up will it cost me more than paying for someone to fix it the first time or will I just have to do it twice?!
what are the total costs for parts versus paying a dealer?
So I ask you as a guy who has changed transmissions, clutches, etc and who has a full compliment of air tools, but who is not familiar with valvetrains, can I do this without destroying my engine?
This is my daily driver. She's gotta work flawlessly.
The Following User Says Thank You to Lex2007 For This Useful Post:
Rokusek (08-18-2013)
 Old 08-18-2013, 12:41 PM   #61
Lex2007's Avatar
One last question. IS this the noise caused by a bad VVT actuator and stretched chain?
 Old 08-18-2013, 02:32 PM   #62
Rokusek's Avatar
07 mazda speed3 engine noise what is it - YouTube
Thank you for your kind words lol. Its hard to say with the video you posted. Take a video of the car starting up. Most vvt noises are within the fkrst 5-10 seconds of start up. really bad vvt youll hear the whole time.
As far as the rest if your questions ill have to answer later when I get to a computer.
-PJ
Galaxy S4 Bitches, fuck an iFail!!!
 Old 08-22-2013, 12:32 PM   #63
Lex2007's Avatar
so, Mr. Rokusek, what the deal?
If I screw up the repair will it cost me more than paying for someone to fix it the first time or will I just have to do it twice?
 Old 08-22-2013, 12:35 PM   #64
USMCMAzda's Avatar
I can answer this... It will cost a lot if you have to do it a second time.. I paid someone to do mine because I didn't want to mess with it I bought all the parts my self and just paid labor. If it messes up once kiss your head goodbye..
 Old 08-22-2013, 12:41 PM   #65
Lex2007's Avatar
ok. What did you pay for labor? parts?
So the consequences are that you will bend valves? incessant engine lights? Can you be more specific?
 Old 08-22-2013, 01:59 PM   #66
Rokusek's Avatar
Doing this yourself is easy and can be done in a weekend if you have the mechanical abilities and the tools. If you fuck it up there is a possibility of bending some valves from the timing being off. you could not tighten down the crank bolt or cam bolt and risk it all falling apart and damaging the motor. I just spent a weekend walking @ajbernhorst; though this process, He didnt do a right up as far as how easy it was as i asked him to but. He did it over the course of a few days when it could have been done in a day or two. he ran into some unforseen issues that he couldnt have prevented along with not listening to me when i told him to do something a specific way. However, his car is running i think hes having some high KR right now, and is still trying to trouble shoot that.
Your probly looking to spend a max of 350 to do it yourself, unless you need to buy tools, if you take it to the dealer and pay out of pocket your looking to spend a minimum of 1500. pending on where you go.
If you have done all that and then some there is no reason you cant do this... the first time I did this was on my own car and the only thing i really knew about cars was simple bolts ons on the speed3. it took me 3 days of fail because i didnt listen to several people when i should have, and i didnt tighten down the ground on top of the fuel pump housing.
It looks super scary and the outcome of failure scares the shit out of some, but if you take your time read over the OP and know what needs to be done. you can do it. The best advice I can give you for this swap is DO NOT RUSH IT!!! TAKE YOUR TIME!!!
I appologize for the delay, work school and my car being down has been taking up my time. Finals next week. but, my thoughts are in red ---^^^
-PJ
 Old 08-22-2013, 02:42 PM   #67
USMCMAzda's Avatar
07 74k? Didn't Mazda extend the warranty for this untill 80k?
 Old 08-22-2013, 03:09 PM   #68
Lex2007's Avatar
-PJ
Thanks for these thoughts!
My problem is figuring out what the noise I hear is....is it related to VVT or something else.
Rokusek (08-22-2013)
 Old 08-22-2013, 03:13 PM   #69
ajberhorst's Avatar
-PJ
I'm going to back him up. I've got minimal install experience and he was there to help me with my stupidity as much as I asked. FaceTime is a miracle lol. Feel free to message me and I will help you as he did for me!
The Following User Says Thank You to ajberhorst For This Useful Post:
 Old 08-22-2013, 03:38 PM   #70
Lex2007's Avatar
Youre too kind ajberhorst. Thx
 Old 08-22-2013, 07:35 PM   #71
Rokusek's Avatar
Lex after re watching and listening to your video im not so sure its vvt related. Can you post a video of start up?
 Old 08-23-2013, 09:18 AM   #72
Lex2007's Avatar
Great right up man, I couldn't even do a better job my self, and I done plenty of these under warranty. Just a FYI you dont have to separate the hpfp you can take it off as a whole unite.
Mr. Motherfnmonsta,
Given your expertise as a Mazda mechanic, would you comment on the noise in this video?
 Old 08-23-2013, 02:15 PM   #73
Groans: 106
Mr. Motherfnmonsta,
Almost sound like rod knock to be honest, but it also could be the chain slapping the inside of the valve cover to.
 Old 08-23-2013, 03:25 PM   #74
Lex2007's Avatar
Rod knock! no no no. Mr. dont use those words.
I think we are each focusing on different noises.
That isnt my car in the video but mine makes the same oscillating sound...its not metallic. Its a rhythmic sound...low frequency. Almost like a pumping noise.
 Old 08-25-2013, 04:00 PM   #75
merc73's Avatar
Posts: 8   (View Stats)
merc73 will become famous soon enoughmerc73 will become famous soon enough
So how do you prime the fuel pump once its all back together? I had to pull the head off my CX-7, and have a ways to go before I get to this step, just looking ahead...
merc73 is offline   Reply With Quote
 Old 08-25-2013, 07:50 PM   #76
Rokusek's Avatar
shhh dont use thise words here...
Like I said post a video of your car at start up.
Once it's all back together you will to the key to on but dont start it. Let it sit for a moment while the pump primes the fuel rail for 20-30 seconds or so then back off again for a few seconds. Then repeat 4-5 times to be sure. You will hear clicking and a wine noise just like you do everytime you put the key to the on position before starting. Then turn her over.
 Old 08-30-2013, 07:10 PM   #77
merc73's Avatar
So a couple more questions. I noticed the crank timing gear spins freely on the shaft, so I take it that torqing the crank pulley is what holds the gear in time? What is the function of the friction washers? These help hold the gears in place? And why is it so important to replace them? They look fine.
Got all my parts ordered including a rebuilt head. Its all apart and I'm replacing the turbo as well.
$1525.00 dollar experiment. Wish me luck
 Old 08-30-2013, 08:58 PM   #78
Lex2007's Avatar
Where do you get a rebuilt head? Mazda?
May I ask what happened to it?
 Old 08-30-2013, 09:12 PM   #79
merc73's Avatar
Mazda 3 6 2 3 DOHC Cylinder Head L3K9 | eBay
On EBAY, where else... LOL
My wifes car, a CX-7, had the timing chain break and the valves were damaged. Rather than replacing the entire engine, I'm doing it on the cheap and crossing my fingers. Its a ton of work I can tell you that.
How do you get the upper 02 sensor out of the turbo manifold...anybody?
"Und willst du nicht mein Bruder sein, so schlag' ich dir den Schädel ein!"
 Old 08-30-2013, 09:40 PM   #80
Lex2007's Avatar
Taking the upper sensor off is easy. I posted a procedure on the mazda3forums....with pics. google it.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-vvt-140986/
Does this sound like the dreaded VVT issue? 200 Mazda 3 Hatchback 2.3L - Mazda3 Forums : The #1 Mazda 3 Forum Post #236 Pingback 11-04-2015 03:31 AM
Almost went ZZB! ? Mazda MPS Owners Club This thread Refback 07-25-2015 07:08 AM
HOW-TO VVT - Mazdaspeed Forums This thread Refback 04-07-2015 06:46 AM
MS3 Valve Cover Painting? - DFW Mazdas This thread Refback 03-13-2015 11:54 PM
$3K towards car. Help. - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-28-2015 07:44 AM
ALignement roues denté et crank sensor ! - Mazda 3 Quebec This thread Refback 08-06-2014 01:12 PM
vvt rattle?? This thread Refback 06-25-2014 02:06 PM
Mazdaspeed 3 VVT/Timing Chain/Etc DIY Repair - Setting Chain Tension - YouTube This thread Refback 05-22-2014 03:55 AM
Mazdaspeed 3 VVT/Timing Chain/Etc DIY Repair - Chain Tension After Crank Bolt Torque - YouTube This thread Refback 05-07-2014 01:40 PM
Mazdaspeed 3 VVT/Timing Chain/etc DIY Repair - Day 2 & 3: Rebuild - YouTube This thread Refback 04-20-2014 07:27 PM
How To: Assemble A Forged MZR DISI Motor - Page 2 This thread Refback 04-15-2014 08:38 AM
Mazdaspeed 3 VVT/Timing Chain/etc DIY Repair - Day 1: Tear-Down - YouTube This thread Refback 04-10-2014 02:43 PM
VVT failure Thread This thread Refback 04-04-2014 03:04 PM
vvt rattle?? This thread Refback 02-24-2014 05:22 AM
PSA | If you hear ANY chain noise in your CX7 or MS3, take it to a mechanic or dealership, immediately. : mazda This thread Refback 02-10-2014 02:18 PM
For Sale: Quality Parts For Sale: Cobb AP / JBR / Corksport / PTP This thread Pingback 10-21-2013 04:45 AM
Noob guide to Preventative Maintenance and Modding - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-27-2013 03:23 PM
vvt rattle?? ? Mazda MPS Owners Club This thread Refback 05-11-2013 01:39 PM
vvt rattle?? ? Mazda MPS Owners Club This thread Refback 03-26-2013 01:29 AM
Page generated in 0.62401 seconds with 32 queries
