> MazdaSpeed 3 - How-To's
 Old 03-17-2013, 11:16 AM   #1
jmen73's Avatar
Posts: 63   (View Stats)
jmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of light
Default MS3 Shaft Pivot Seal Replacement
http://www.mazdaspeedforum.org/forum/foru...t-seal-116267/
The above is THE how-to I used for my MS3. It is very well written and works for the MS3. However, it is geared towards the MS6. I did mine yesterday (about 2-3 hours) and it was not nearly as involved and there are some caveats.
YOU DO need to remove CAI components. Good time to clean the MAF sensor.
YOU DO NOT have to remove or loosen the transmission motor mount. The MS3 configuration does not require this like the MS6. This will save a ton of time and some expletives. That said, I do recommend removing the battery box for clearance and cleaning. You may need to unclip the shifter cables under the battery box for clearance when removing the shaft. I unclipped the main shifter cable, not the reverse cable. Didn't see any real benefit.
As stated in the above how-to, YOU DO need to remove the bottom bolt (transmission) as identified in the above how-to. The shaft will not disengage from the trans unless you do this.
A T25 torx driver does work for the cotter pin if you don't have a punch available. I thought it may be different due to models but it is not.
Cheers.
2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not).
jmen73 is offline   Reply With Quote
The Following User Says Thank You to jmen73 For This Useful Post:
geo2maz (02-11-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/mazdaspeed-3-shaft-pivot-seal-replacement-140585/
Mystery oil leak at top of trans. This thread Refback 04-18-2015 05:26 PM
HOW-TO: shaft pivot seal replaced jrzy ms6 MazdaSpeed 6 - How-To's 287 08-18-2018 07:47 PM
Shifter Pivot/Seal Fix? Gru_Nuts MazdaSpeed 6 - How-To's 8 11-08-2014 12:03 PM
I think it called a shifter pivot seal nospeed MazdaSpeed 6 - How-To's 39 04-19-2013 12:51 PM
Shaft pivot seal useless tip paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 1 07-11-2012 03:48 PM
shifter pivot seal fluid rgvms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 05-22-2012 05:09 PM
Page generated in 0.33028 seconds with 28 queries
