> MazdaSpeed 3 - How-To's
 Old 12-22-2011, 06:57 PM   #1
MurrySpeed's Avatar
Posts: 22   (View Stats)
MurrySpeed will become famous soon enoughMurrySpeed will become famous soon enough
Default Starting a GT3076R build looking for suggestions
Hey i have a 07 speed 3 The mods i currently have are a cobb ap, cp-e 3'' TBE, cp-e fmic, water meth, mazdaspeed intake, forge BPV, autotech HPFP internals. Just last week i picked up a new gt3076r for a good price now im looking to buy some internals. Does anyone have a brand they recommend and maybe a good engine guy to hone and install the internals??? And someone who could make me a few good tunes???? I would b more than happy with 350-400 whp. Thanks guys. Cheers
MurrySpeed is offline   Reply With Quote
 Old 12-22-2011, 07:05 PM   #2
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
you dont need engine internals if all your going for is 350-400.
for tune get a perm tune
 Old 12-22-2011, 07:07 PM   #3
jroc's Avatar
Posts: 1,482   (View Stats)
ask around your hood for an engine builder. since you dont have a location, no one but you knows where the hell youre at.
read up on some how to threads for engine building/tuners/tunes. ultimately, your budget is your limit on brands.
JDMFresh.com 1990 Mazda Miata
 Old 12-22-2011, 07:31 PM   #4
MurrySpeed's Avatar
Thanks ya sorry i forgot to add my location im in muskoka but i would have no problem bringing my engine to toronto my buddy got his subi built at gord bush racing and he seemed pretty knowlegable. And as for leaving the internals stock i really would like to forge the pistons and rods so if i decide i want to go to 450-500 whp down the road all i would need is a tune
 Old 12-22-2011, 08:04 PM   #5
MurrySpeed's Avatar
I havnt been able to find anything on injectors
Either any suggestions?
 Old 12-22-2011, 08:10 PM   #6
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
Your internals are already forged. There are no good options for injectors right now. (unless something changed in the last few weeks) But a few people are working on it. Perm tuning is the best way to go.
As far as parts... @JP@edgeautosport.com or @eric@edgeautosport... These are the guys to go through... Best customer service and prices!! Eric knows quite a bit about BT builds too
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline   Reply With Quote
The Following User Says Thank You to RayRay For This Useful Post:
Alpha (12-22-2011)
 Old 12-22-2011, 08:11 PM   #7
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
There aren't any and people run that power on stock internals.
 Old 12-22-2011, 08:11 PM   #8
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
whats the point of 450-500whp? thats nothing but tire fire.
you dont need internals
2015 Mazda 6
The Following 2 Users Say Thank You to IshiKage For This Useful Post:
crazyp (12-22-2011), RayRay (12-22-2011)
 Old 12-22-2011, 08:25 PM   #9
crazyp's Avatar
Groans: 68
you already have some pretty good mods for what you want, all you really need is an exhaust mani but if you have a turbo with the atp housing it will bolt to your stock mani.
 Old 12-22-2011, 09:01 PM   #10
MurrySpeed's Avatar
I thought that crank was the only thing that was forged?? So the rods and pistons are factory forged?? And yes i was planning on getting a aftermarket cast manifold thanks for the advice guys!!!!
 Old 12-22-2011, 09:11 PM   #11
RayRay's Avatar
Yep! Right now there are probably 20+ MS3's and 6's running 450+hp. Almost all with stock internals. I think there are a few well over 500. Power isn't the problem. Traction is!! Being able to use that power anywhere under 50mph is the real quick!
2009 MazdaSpeed 3
IshiKage (12-23-2011)
 Old 12-22-2011, 09:38 PM   #12
MurrySpeed's Avatar
Well thats wicked guys maybe i will run the gt30 on the stock internals for next summer then so where it goes from there! Whats involved in changing the turbo and exhaust mani???? When i put my DP it was tight enough under the car lol
 Old 12-22-2011, 09:48 PM   #13
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
fuck stock internals save your block and time and spend the extra cash now. all those stock blocks will blow eventually
the stock rods are garbage casted low grade metal imo
vs the bulletproof chromolly billet like my pauter rods if you would compare youll see my rods will be the last thing to give way.
get the arp studs and cometic head gasket and fresh bearings.
 Old 07-11-2012, 10:44 AM   #14
Hoyoman's Avatar
Posts: 302   (View Stats)
Hoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the world
Groans: 43
Groaned at 6 Times in 3 Posts
Only pistons are forgedd
2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck
E35 meth d012 26psi 420/451 self tuned/built
Hoyoman is offline   Reply With Quote
 Old 07-11-2012, 11:16 AM   #15
Hoyoman's Avatar
Groans: 43
Report: Bugatti to build 1,000+ Galibier sedans starting next year? Haltech Automotive News 0 08-01-2011 08:10 AM
Page generated in 0.33027 seconds with 27 queries
