| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
(Thread Starter) | Not Ranked : 0 score I tried different metric sockets that I have, but I don't have a 20mm. From the looks of it, it appears to be a 20mm socket but I want to get confirmation before I order the socket (20mm isn't readily available).
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - |
![]() Join Date: May 2012 Location: Ontario
Says 18mm in that How to. Maybe your socket wasn't deep enough to clear the spring inside of it.
__________________ My car thread: http://www.mazdaspeedforum.org/forum/forum/f542/pwdunmore-s-2012-a-150456/ | |
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - | |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score I believe cpe uses a larger nut in there pumps not 100 percent on that . The how to is for installing internals in a stock pump not a cpe pump. 20mm sounds right just get a deep socket that is 20mm all the way not one that reduced diameter to a stud size hole inside.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| Not Ranked : 0 score 5doors is prolly right because it's a CPe pump which I didn't notice in your signature, do you have any measuring calipers to get an exact size on the nut because that would conclude this mystery lol.
(Thread Starter) | Not Ranked : 0 score I had a caliper, but can't recall where it is. I was using it in school last semester for my engineering design class but don't know it's whereabouts.... Lol
I still can't find my work headset that I was using less than a month ago... and now I'm working on a computer and making calls so it would be perfect. Fuck murphy's law... I don't think have a 20mm deep socket either otherwise I would just let you use it lol. I will check when I get home but as you said it's an odd size to get in a set. I know my normal set jumps from 19mm to 22mm but my other set might have it with any luck. I'll let you know if I do.
| The Following User Says Thank You to pwdunmore For This Useful Post: | Polish_Eagle (03-07-2014) |
Groans: 74
| Not Ranked : 0 score Put 2 flat thooth pics on eather side of the nut and use a ruler to measure the nut diameter and convert to mm useing google. If u want to be anal u can subtract out the thickness of the thoothpics but u get the idea. Good luck dude.
| The Following 2 Users Say Thank You to 5doorsoffury For This Useful Post: | Polish_Eagle (03-07-2014), pwdunmore (03-07-2014) |
(Thread Starter) | Not Ranked : 0 score Haha, love it. I'll see if CPE can confirm before I finish my classes today, if not I'll do that.
| The Following User Says Thank You to Polish_Eagle For This Useful Post: | 5doorsoffury (03-07-2014) |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score good luck getting that info readily from cpe Last edited by Nitr0EngiE; 03-07-2014 at 01:35 PM. |
| The Following User Says Thank You to Nitr0EngiE For This Useful Post: | chaser27 (03-07-2014) |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
| Not Ranked : 0 score First time I ever did it, I forgot to compress the spring (by just pushing on it with whatever you're using, impact gun/ratchet). I thought the same thing: "The fuck? My 18mm deep well isn't deep enough?". It is a spring, and it does compress lol Yes I admit to being a noob once upon a time.
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! |
(Thread Starter) | Not Ranked : 0 score LMAO, oh I know. I was just hoping since they won't warranty my fuel pump with their "Lifetime Warranty", that they would at least help me out by saying the nut size.
(Thread Starter) | Not Ranked : 0 score Love the support, you can always count on cpe.....
(Thread Starter) | Not Ranked : 0 score Decided to just buy a new caliper today and measured the nut. The caliper said it's 19.8mm, which means I indeed need a 20mm socket. Thought I'd post it here since cpe is the least bit helpful and other users could potentially benefit from this.
| The Following 3 Users Say Thank You to Polish_Eagle For This Useful Post: |
| Brownie CDFP question | metalgear386 | 2010 MS3 - ECU Computer Tuning | 13 | 09-02-2013 03:08 AM |
| CP-E cdfp install question | llescaflownell | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 07-11-2011 03:34 PM |
| Question on installing CDFP internals | ElBartoRex | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 19 | 02-22-2010 09:11 AM |
| cdfp question | itzl0l | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 2 | 12-25-2008 08:52 PM |
| AWE CDFP | SpdFreak | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 12-24-2008 02:17 PM |
