| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
(Thread Starter) | Not Ranked : 0 score just wondering if you guys had any heads up on a cp-e sri? well any info is good thanks for the time.
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
We're hoping to have these guys available in the next couple weeks, and I'll post some pics as soon as the prototype is finished. | |
![]() Join Date: Apr 2008 Location: Cali
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 173
__________________ | |
| The Following User Says Thank You to Renzokuken For This Useful Post: | Sacrilicious (09-29-2008) |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score Will it work for the 3 and the 6? Would you make it go to the turbo inlet? |
![]() Join Date: Mar 2008 Location: Perth Amboy, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 704
Groans: 86
Groaned at 36 Times in 25 Posts
| Not Ranked : 0 score any chance this will have an option for a larger MAF housing?
__________________ L76-powered |
Actually yes! I'm working on a 3.25" and 3.5" housing option as I type this. | |
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | mdogg (09-25-2008) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 16 Times in 11 Posts
| Not Ranked : 0 score this is good news !
![]() Join Date: Sep 2008
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score cant wait!!!! i would def take my cobb sri off to run the cp-e piece!! let see some pics boys!! |
| Banned ![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 28
Groaned at 84 Times in 39 Posts
| Not Ranked : 0 score |
| Team Überfrazn ![]() Join Date: Apr 2008 Location: Plymouth, MN
Rep Power: 324 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 661
| Not Ranked : 0 score Great to hear! |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score hah! so our constant subtle hints at it the whole weekend helped? This is great news as most people want the Short Ram. And ATE they are looking into making turbo inlets also... I talked with Anthony about it when I was there. |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groans: 57
| Not Ranked : 0 score very intrested in the inlet plus bigger maf housing! Great news |
| Not Ranked : 0 score I'd be down for the bigger housing. Would it by chance be including an MAF scaler like your V6 intake, or will we have to tune for that with the standback or the like? Only way I could get the inlet is if it could be 3.5 all the way to the turbo, at least as an option. That's gonna be the inlet size of my new turtle and you can't really use a coupler on a silicone tube, lol. |
The problem with big MAF housings like 3.5" is that idle quality goes to hell when the housing gets bigger because the signal gets noisier. So we're going to try to make a 3.5" housing work, but it may not idle all that great. If we have to we can try bumping up the idle speed though... | |
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | Laloosh (09-25-2008) |
| Not Ranked : 0 score Have you thought of putting a partial cone in before the sensor, directing X% of the airflow through it? That wouldn't be restrictive enough to impede on high-flow situations, but it would keep the right amount of air going through the sensor. Like this. (b being the tip of the sensor, v being the cone) ___ b< ___ |
| Not Ranked : 0 score Exactly! |
We could do that but I honestly think the diameter is overkill for anything anyone is building these days. The 3.25" MAF is good for over 1000cfm, or just under 700hp before the sensor maxes out. I guess if guys really wanted bigger we could do it though.
Was that a C&L piece? I used one of those on an old Mustang of mine and I didn't have quite as much success | ||
| Not Ranked : 0 score It worked fine on the evos until the ecu got cracked. People still run intakes like that though without any tuning. The sensor just has to see a specific percentage of the air going through the intake. Another option that the subby guys do is to go to a push-through sensor and put it in the cold pipe. Lets them run whatever size intake they want. Hell, even an open turbo inlet with no filter. I think the SRT guys are doing that too now. |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score id sell my Cobb in a sec to pick a CP-E SRI!
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
Groans: 91
(Thread Starter) | Not Ranked : 0 score cp-e i know this is far fetched and hard to call but any idea on a rough price or did you set a price goal comming into it you can share?
![]() | | #24 | ![]() |
| Not Ranked : 0 score OK, I did a bit of research. According to the vendors on NASIOC, The Denso 5V MAF sensor that they have (same as ours I beleive) is good for up to a 3.25" diameter pipe with a recalibration. 3.5" gets too hectic. BUT, it also happens to work BETTER as a blow-thru MAF, when placed in the cold pipe. I think I'm gonna try that out with the specifications they gave me to see how it works.
__________________ Last edited by ATE BALLER; 09-25-2008 at 04:16 PM. |
![]() | | #25 | ![]() |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
| Not Ranked : 0 score Hopefully soon, cause I'm itching to buy something lol. |
![]() | | #26 | ![]() |
![]() Join Date: May 2008 Location: Lehigh Valley, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 376
| Not Ranked : 0 score Can we get a rough idea of when this will be available and the cost? |
![]() | | #27 | ![]() |
| Ive got a 120mm MAF on the truck thats recal'd and has no idle issues. Stock is 90mm
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
On the Mazda, if CP-e could design a sample tube, it will relieve the idle syndrome for a big meter. As pointed out, Fords use this and their are no idle issues because of it. It will add a bit more restriction in the system however. You can also convert it to a blow through design on the cold pipe for those big turbo guys, but it would require bigger pipes and an extension harness. C&L had a smart idea with interchangeable sample tubes ( for injector sizes ) but their engineering was pretty pathetic and caused some drivability issues as you built the car up. This could be tuned out changing the MAF scaler in most of the available software out for the EEC-IV. CPe is able to do the same with their standback so it might be a pretty neat R&D project. Either way, a new meter will be needed for these higher power guys. You can only tweak the stock MAF so much. A 3" wouldn't be a bad starting point for them.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
![]() | | #30 | ![]() |
Groans: 91
(Thread Starter) | Not Ranked : 0 score in the first post they said they hope to have them done in the next couple of weeks.
![]() | | #31 | ![]() |
![]() Join Date: Aug 2008 Location: Cerritos, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score I am interested in this piece...cp-e ftw! I wonder how this will compare to cobb SRI? 4.5 inch filter ID? more information on the silicone turbo inlet please! |
![]() | | #32 | ![]() |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score im getting the cp-e sri for sure. CP-E FTMFW!!
__________________ 2008.5 MS3 Metro Gray...slow |
![]() | | #33 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
| Not Ranked : 0 score sweet!
__________________ || CP-E CAI || CP-E Inlet || CP-E FMIC || CP-E Catback || SU TurboSmart BOV || PG Turbo Manifold || CDI/PG Fuel Pump internals+spring || Denso 1step colder plugs || ATP DP || ATP FCD || ATP CEL trick || TWM stage2 SS+bushings || AWR Engine mount || SU rear diff mount || TT rear diff Rear mount || Whiteline anti-sway bar || AWR Endlinks || BC racing CO's || matt black OZ Ultraleggeras + Kumho ASX || Cobb AP || VEI boost || VEI oil Pressure/Water Temp. || AEM wideband || ApexI Turbo Timer || N2MB WOTbox || SM catchcan || BS delete+baffle kit || Spin on Oil filter conversion + Prosport sandwich || Other: Other mods are BS! Sponsored by: STREETUNIT.COM check them out :thumbsup: |
![]() | | #34 | ![]() |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score fuck me i would be interested too if reasonably priced... also interested in the turbo inlet, would like to see how the recirculation hose would meet into it, and see a good inlet that could be used with stock battery. big turbo bolt up abilities would have me sold on the inlet!!!
__________________ 2008 STi Intake Turboback AP |
![]() | | #35 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score interested in the sri and turbo inlet. |
![]() | | #36 | ![]() |
![]() Join Date: Mar 2008 Location: Windsor Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 197
| Not Ranked : 0 score Can't wait to see the SRI.
__________________ 2010 Victory Red HHR SS 2008 CPW MS3 (SOLD) 2004 Black SRT-4 (SOLD) |
![]() | | #37 | ![]() |
Groans: 106
| Not Ranked : 0 score how soon can we be teased with pics!!!
![]() | | #38 | ![]() |
| Not Ranked : 0 score Perfect timing for CP-e to bring this to market IMO. The Cobb unit so many people are waiting on seems cursed with production issues. People seem to be lining up to buy them too. I know I've been waiting for a quality SRI since Dec of 06 for the speed6. Priced even close to what the Cobb intake is and I'll be one of the first to order. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Can you give us a date when this will be available to buy? Also when will the cp-e speed 3 engine mounts be back in stock? |
| 9ff already working on Porsche Panamera? | Haltech | Automotive News | 0 | 09-24-2008 11:50 AM |
| cd player stopped working | Grim | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 09-04-2008 07:29 PM |
| Map Clamp not working | oskinosmee | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 08-17-2008 11:37 AM |
| BMW working on M3 CSL with 470 hp | Haltech | Automotive News | 0 | 07-16-2008 11:00 AM |
