Closed Thread
 Old 11-25-2008, 03:49 PM   #1
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
Default Please help Ms6 FMIC owners!!!
So i am installing my cpe FMIC at the moment and have hit a few speed bumps, so im calling for anyone who has done this.
1) it seems to me that the instructions that cpe provides contradict the kit i am putting on, specifically on the final cold pipe going into the throttle body (the one with the BOV flange on it). It says put the "expanded side" of this piece into the throttle body(coupler). this would make the BOV flange very close to the throttle body, which is not the way it is pictured in the instructions. the instructions would lead me to believe the BOV flange should be right nest to the shifter...
2) what is the accordion looking thing in the drivers side fender wall ( right where both of the IC pipes look like they should go) and does it need to be removed/relocated for the pipes and couplers to have clearance?
these pics are probably huge, im sorry for that, thanks for any input...
-dane
2008 STi
Intake
Turboback
AP
danesti is offline
 Old 11-25-2008, 04:19 PM   #2
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i believe you want the expanded side near the TB because the TB is larger than the size of the pipe.
bova is offline
 Old 11-25-2008, 04:23 PM   #3
danesti's Avatar
Groans: 137
ya thats how i have it now. i think im going to leave it that way. it just would be different than the instructions though. the instructions would indicate that the expanded side of the pipe is the side further away from the BOV flange.
i think my main concern now is that damn accordion thing...
thanks for the input Bova
2008 STi
Intake
Turboback
AP
danesti is offline
 Old 11-25-2008, 04:39 PM   #4
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
You've got the right idea damems6. The expanded part of the pipe is going to slip into the throttle body as Bova said. I'll have to take a look at the instructions and see why that's not consistent!
The accordion thing is the power steering cooler, and the pipes should be able to wrap around it without any issue. If you have any fittment issues after you get all the pipes in place feel free to post some more pics and I'll help point you in the right direction.
Edit: Ahh, I see what happened. The instructions have a picture of the original bypass valve flange design, which was later relocated so we could accommodate more bypass valves. I'll make sure that mistake is changed. Thanks for bringing it to our attention!
www.cp-e.com is offline
 Old 11-25-2008, 04:47 PM   #5
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
hahahaha, dane, don't you remember me griping about the placement of the flange. IT'S SO FUCKING CLOSE TO THE THROTTLE BODY!!
granted, mine's the 3, and yours is the 6, but still...
phillyb is offline
 Old 11-25-2008, 05:09 PM   #6
m4tic's Avatar
Posts: 4,928   (View Stats)
thanks for the invite
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
m4tic is offline
 Old 11-25-2008, 08:56 PM   #7
danesti's Avatar
Groans: 137
alright.. an update...
its on.
the power steering cooler. ya they fit around it with the proper adjustment, so i was just being a n00b on that.
the BOV cold pipe, i really dont feel like too much of a n00b on that on because the instructions, and the fact that it almost doesnt fit in with the rest of the kit properly, and my shifter weight is hitting it (if i pop the hood and try to pull it away, it seems ok for a little while)
overall i was not impressed with the entire setup and how everything had to be done.
i was missing three clamps which i used from my stocker. (luckily because the provided ones werent fitting around the throttle body anyway)
the allan screws for everything were a bit difficult, and i dont like the way you have to remove the stock splitter (only to put in the mounting bracket which is pretty beefy.)
i might just be a newb, but i couldnt get my stock recirc hose to my BOV ( i usually run BPV), and i tried to used the provided one but it wouldnt fit on my inlet pipe, and would barely fit on my HKS recirc fitting (my stock one was very loose on this fitting)...
i let my car warm up for a bit and i took her for a drive.. i went to about ten PSI before the coupler on the turbo blew off and my thing was free spooling. (luckily i brought a flashlight and tools with me )
thats my fault though for not tightening it enough.
cpe- thanks for fixing the instructions... and it sure would have helped for better pictures/ a little more instruction. taking the bumper off was the easiest part and that where most of the instruction was!!!
2008 STi
Intake
Turboback
AP
danesti is offline
 Old 11-25-2008, 09:32 PM   #8
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
You should try to loosen all of the clamps, then readjust to allow for more clearance around the counterweight. Once you are satisfied with the new position, retighten them all again. Before anything else, have a friend row through the gears to make sure you are still clear.
Intercooler piping almost always has a decent amount of room for adjustments to be made by pulling, pushing, twisting, etc. as needed.
L76-powered
mdogg is offline
The Following User Says Thank You to mdogg For This Useful Post:
danesti (11-25-2008)
 Old 11-25-2008, 09:00 PM   #9
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groaned at 86 Times in 65 Posts
every time i have built a car you want the bov / bpv as close to the throttle body as possible. efficiency is the key for that.
-JEWBERT
jhershorin is offline
 Old 11-25-2008, 09:10 PM   #10
danesti's Avatar
Groans: 137
i figured that was the case.
when the hks VTA flutters... is that compressor surge??? its not acting like it but sure sounds like it...
2008 STi
Intake
Turboback
AP
danesti is offline
 Old 11-25-2008, 09:30 PM   #11
phailerider's Avatar
Posts: 4,639   (View Stats)
i noticed a huge change wih mine and thought it was surge at first. i dont think it is. you can get the sound generated slightly in free rev and you should be able to tell.
im glad you finally got it on and your comments are greatly appreciated. im sure a point has been taken to update it and make it more user friendly. those seem like simple, but awful legitimate concerns.
btw...you seriously were missing three clamps? that shocks me actually.
phailerider is offline
The Following User Says Thank You to phailerider For This Useful Post:
 Old 11-26-2008, 12:01 AM   #12
phillyb's Avatar
Groans: 1,940
fuck the counterweight. take it off
phillyb is offline
danesti (11-26-2008)
 Old 11-26-2008, 07:51 AM   #13
danesti's Avatar
Groans: 137
already did...
but honestly i would prefer to have it on...
off he goes for now though...
philly... seeing as how we both had a hard time putting something as easy as a front mount on...
were going to have to dedicate about a week and at least 5 threads on the MSF to get my turbo on, im committed. hahah
thanks for all the advice everyone... thats why i love these forums.
2008 STi
Intake
Turboback
AP
danesti is offline
The Following User Says Thank You to danesti For This Useful Post:
phillyb (11-26-2008)
 Old 11-26-2008, 09:52 AM   #14
danesti's Avatar
Groans: 137
thought i would share some more big pics.
core looks a bit sideways imo... probably user error...
comments/ suggestions appreciated
edit for pics (hopefully, thanks J)
danesti is offline
 Old 11-26-2008, 09:55 AM   #15
jhershorin's Avatar
i dont see pics!!! im installing mine next week
-JEWBERT
 Old 11-26-2008, 10:16 AM   #16
phillyb's Avatar
Groans: 1,940
change your theme to mazdaspeed dark
if you have any questions, see if this thread answers them - http://www.mazdaspeedforum.org/forum/foru...tachments.html
phillyb is offline
 Old 11-26-2008, 07:57 PM   #17
jhershorin's Avatar
He fixed it after I made the comment. Thanks though philly! You are always around to help! Props to you!
-JEWBERT
 Old 11-26-2008, 10:33 PM   #18
phillyb's Avatar
Groans: 1,940
hahaha. no doubt j
phillyb is offline
Closed Thread
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
Cat-less DP Owners, Please Chime In... AutoXRacer MazdaSpeed 3/6 - Turbo Induction 12 08-20-2008 03:56 PM
COBB FMIC owners...how does it perform? Yahdy Ras MazdaSpeed 3/6 - Turbo Induction 8 07-16-2008 12:22 AM
More proof that Mazda RX-8 owners want to be Ferrari owners Haltech Automotive News 0 06-11-2008 07:40 AM
Page generated in 0.37512 seconds with 28 queries
