Closed Thread
 Old 01-31-2011, 04:00 PM   #41
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Shielding shielding shielding
Tin foil doesn't sound so stupid now, does it... lol
IIRC the PCB ground on the SB isn't tied to the SB chassis. At one point i had Gerry try tying those two together to see if it helped some.
The mazdaspeed is def a noisy beast when it's making power. Hope all works out well Gerry and Sander!
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
MattJackson86 (01-31-2011), NJSPEED3 (02-01-2011)
 Old 01-31-2011, 04:47 PM   #42
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
I didn't hear if Gerry ever tried that or not. That is basically what I am saying and imo the reason the cable I tried fixed the issue. I am just grounding my laptop chassis to ground which in turn should be grounding the SB USB cable and thus SB to the cars chassis.
And no, the pcb of the SB is not connected to the chassis of the SB. It just sits in some grooves of the chassis, but no electrical grounding between the two.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline
The Following User Says Thank You to MattJackson86 For This Useful Post:
djuosnteisn (01-31-2011)
 Old 01-31-2011, 04:53 PM   #43
Captain
IMO, a properly grounded PCB, electrically connected to the housing, and cable shielding connected to the same housing on all cables in and out of the SB would help immensely. And grounding the other end of the usb cable and laptop certainly wouldn't hurt lol.
Sounds like your making great progress Matt!
www.permtuning.com
 Old 01-31-2011, 05:13 PM   #44
^ Agreed 110%.
Thanks. Hopefully we will know more when Gerry tries the cable.
 Old 02-01-2011, 09:41 PM   #45
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
there are quite a few things I been meaning to try but this weather just wont let up. Like I said on my bt thread im 100% the issue is noise related I went out and tried out Matt's software with my current tune it failed. I then lowered my boost from 23-24 to 19-20 and I was able to log with Matt's sb software with no problem.
NJSPEED3 is offline
djuosnteisn (02-02-2011)
 Old 02-02-2011, 07:48 AM   #46
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
New software here: This will alleviate the Read / Write problems some have been having:
http://cp-e.com/imgs/StandbackMazda.zip
Website: www.cp-e.com
www.cp-e.com is offline
The Following 4 Users Say Thank You to www.cp-e.com For This Useful Post:
djuosnteisn (02-02-2011), NJSPEED3 (02-02-2011), RichieRichness (02-07-2011), SilverDemon (02-02-2011)
 Old 02-02-2011, 08:10 AM   #47
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Does that software work properly with the AEM map sensor??
SSinstaller is offline
 Old 02-02-2011, 12:43 PM   #48
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groaned at 86 Times in 65 Posts
Chris - you are really the only one who could test it - I don't know if anyone else has that setup.
-JEWBERT
jhershorin is offline
The Following User Says Thank You to jhershorin For This Useful Post:
 Old 02-02-2011, 01:10 PM   #49
What exactly has been the issue in the past with that setup and the software?
 Old 02-02-2011, 02:27 PM   #50
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I will be testing the AEM set up shortly... just waiting on the parts to show up.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
SilverDemon is offline
 Old 02-02-2011, 03:23 PM   #51
Groans: 60
I just hate to mess with what I have, now that it's working 100%...
The selection for "use alternate MAP" did not work with.. I'd select it, it would write and verify properly, but when I pulled the map back off the SB it would be unchecked..
 Old 02-02-2011, 03:36 PM   #52
So I tested CP-E's new version a little bit.
Good (so far)
- I did not get the read failures yet. Cant say for sure if they are fixed as it was somewhat infrequent I did get this.
I did not manage to try logging either yet. So not sure if that works or not.
Bad:
- The MAF Transfer table (bottom half) still does not load correctly from a tune file
- The map indicator (P or S) is still backwards.
Minor:
- Really minor, but being a developer I have to mention it. If the splash screen is going to say the version of the software, it would be best if it was the correct version.
- If this is the mazda version of the software, remove the BMW references.
Can anyone comment on what exactly the "Use Alternate MAP Sensor" does? Is it specifically for the AEM map sensor? I just don't see an option to configure the map sensor other than "use alternate".
FYI, if you want these comments elsewhere let me know. I know this was the thread originally for logging issues.
 Old 02-02-2011, 05:48 PM   #53
SS, I tested this out and I don't see any issue with the CP-E software on this matter. I checked the "Use Alternate Map Sensor", hit Send Params, unchecked the box, hit read Params and the box got checked automatically. So it seems to be reading/writing that param fine.
 Old 02-02-2011, 07:18 PM   #54
Bad:
I will pass these on to the software developer. Thank you for your input.
I believe that the alternate map sensor is slated for a 3.5 bar linear transducer. I'll double check tomorrow though.
The Following 2 Users Say Thank You to www.cp-e.com For This Useful Post:
NJSPEED3 (02-02-2011), the_caruch (02-02-2011)
 Old 02-03-2011, 08:51 AM   #55
Groans: 60
AFAIK it's currently only for the AEM 3.5 bar map... I actually sent my sensor to Jordan during the initial development of this feature..
It would be very nice if it was just a checkbox and the SB allowed you to enter the transfer equation for your particular sensor (Y= mX+b)..
 Old 02-03-2011, 08:59 AM   #56
Thanks for the info. The equation would be nice, but unfortunately that would require a firmware update to the SB as it does not have that functionality at the moment (that i am aware of). Not something that can be done in software alone.
 Old 02-03-2011, 03:01 PM   #57
You are correct, this is an option only for the AEM 3.5 Bar sensor. I'm sorry this is not more clearly labeled in the software.
I would like to personally see a user definable voltage vs. pressure sensor offset table in the software at somepoint, however, there really aren't that many people (with Mazdaspeed cars) who need to see more than 20 psi, let alone more than 36.7 psi. (Greater than 3.5 Bar map would read).
If there are enough people that would like to see the use of different map sensors, I can see what we can do about changing the software / firmware.
 Old 02-03-2011, 03:26 PM   #58
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Well figured I'd share my dealio. I have logged at 21-24psi but the car was not running it's best(blowout etc..). I know you guys are making more power than me so maybe that's why I haven't had the issue yet.
2012 WRX HB w/mudflaps yo!
spnkr21 is offline
NJSPEED3 (02-03-2011)
 Old 02-03-2011, 07:35 PM   #59
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
I downloaded the new SB software and tried to log with the SB. Once I try to view the low on the BBX, I get the following message:
Any ideas?
http://i1204.photobucket.com/albums/...6Feb031829.gif
11cruzito11 is offline
The Following User Says Thank You to 11cruzito11 For This Useful Post:
 Old 02-03-2011, 08:40 PM   #60
11cruzito11,
Email me.
Thanks,
-Sander
 Old 02-03-2011, 08:46 PM   #61
11cruzito11,
Email me.
Thanks,
-Sander
Email sent!
 Old 02-08-2011, 11:43 AM   #62
Tripple OG
NJSPEED3's Avatar
Groans: 113
I tried both wires Sander sent me and no cigar!
I think CPE needs to figure out what we needs shielded and include a kit with their SB. Sorta like what they did with adding Filters for any standback sold prior to when they figured out filters were a necessary.
This really sucks! Im about to order slicks I need this resolved already.
NJSPEED3 is offline
 Old 02-08-2011, 12:09 PM   #63
Damn really? Mine is a night and day difference with the cable I made. Where did the other end of the cable get grounded? Mine was the USB in the pc and the other end in the kick panel grounding point.
 Old 02-08-2011, 04:04 PM   #64
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
Try what I suggested Gerry just for the hell of it...
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
cpolly69 is offline
 Old 02-08-2011, 06:05 PM   #65
Tripple OG
NJSPEED3's Avatar
Groans: 113
Sander sent me the wire which I had to connect the ground to the main ground point in the engine bay, same one as the battery negative on the driver's side.
Matt Im positive as you make more power you will experience the same issues again. Like I said in the past if I lower boost a bit or lower timing i can log with no issues.
Its frequency noise no doubt in my mind which is related to how much power you're making.
Im still waiting on Sander to get back to me. If I dont hear from him in the next few days I'm going to call CPE but this isnt looking good.
NJSPEED3 is offline
 Old 02-08-2011, 08:43 PM   #66
Sorry Gerry, I must not have gotten an email from you on this.
I'm discussing with Lou the next plan of action on this. I've brought up the idea of grounding the USB plug internally to the chassis ground to see if this helps. I'll let you know something tomorrow hopefully.
NJSPEED3 (02-09-2011)
 Old 03-07-2011, 07:55 AM   #67
stefan's Avatar
Posts: 2,216   (View Stats)
stefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the worldstefan is the leader of the world
Groans: 140
Groaned at 116 Times in 64 Posts
any news on this?
Originally Posted by NJSPEED3:
you see here in NJ when you meet the nj nator crew ...its a wrap for your warranty son
stefan is offline
 Old 03-07-2011, 10:45 AM   #68
cpolly69's Avatar
Groans: 27
News is -
Gerry got an ap and is going to tune with that.....
Man I was just tuning myself 2 weeks ago and I keep dropping connection with just the normal software not even the bbx stuff) every time I do wot runs....
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
cpolly69 is offline
The Following 2 Users Say Thank You to cpolly69 For This Useful Post:
NJSPEED3 (03-07-2011), superskaterxes (03-07-2011)
 Old 03-07-2011, 11:02 AM   #69
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
I'd say it's 25% of the time for me when I drop my connection when using Matt's software (I don't use BBX).
However, I've noticed the connection drops about 50% of the time when running my laptop off of AC power instead of battery.
RichieRichness is offline
 Old 03-07-2011, 11:14 AM   #70
cpolly69's Avatar
Groans: 27
I'm talking all off the battery - I gave up trying to use off ac adapter in the car after the first time I hooked up the sb.....
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
cpolly69 is offline
 Old 03-07-2011, 11:17 AM   #71
Yea the laptop/sb already has to deal with a bunch of noise from the engine. AC noise is just going to make that even worse.
Has anybody else had luck with the grounding cable? I know this wont work all the time for everyone, but it helped me out a lot. Worth a shot...
I do believe Gerry is going down to CP-E to have them look at the issue. Hopefully that will yield results.
 Old 03-07-2011, 11:26 AM   #72
Groans: 35
Matt, what ground are you talking about? The one that's on the PNP harness? Now that I think about it, I never connected the ground on my PNP.
 Old 03-07-2011, 11:33 AM   #73
No im talking about a custom made USB cable I made and wrote about. It grounds your laptop to the car, in theory helping eliminate the noise (or some of it) on the SB. The idea was that the cable would ground the laptop to car chassis, and this would in turn ground the SB to the cars chassis. Starting on page 2 we talk about it. Sander even sent it to Gerry to try, though no luck. It looks like it eliminates some of the noise, but the more power your car makes, the more noise, the better solution we need.
See Gerrys thread: http://www.mazdaspeedforum.org/forum/foru...tml#post711178
RichieRichness (03-08-2011)
 Old 03-07-2011, 02:43 PM   #74
Tripple OG
NJSPEED3's Avatar
Groans: 113
After thinking about things I decided not to go down to CPE. Im moving on to the AP shortly. I was able to take a few logs by lowering my boost a bit. My tune is basically done for a street tune. I'll take her to the strip a few times and then swap in the AP.
NJSPEED3 is offline
 Old 03-07-2011, 02:57 PM   #75
just a side note for those who havent jumped ship, YET, lol
theres a setting in windows 7 (and maby other OS's) that lowers the USB power when running on battery. apparently the proceed has this same problem so you all might want to look into this.
superskaterxes is offline
 Old 03-08-2011, 06:56 AM   #76
jhershorin's Avatar
LOL...also try different usb ports as some are more stable power wise then other...ask me how i know
-JEWBERT
 Old 03-08-2011, 07:32 AM   #77
Groans: 35
Electronics are crazy sometimes.
Closed Thread
Standback Tuning Software, Drivers, and Logging Software www.cp-e.com Custom Performance Engineering (cp-e.com) 24 04-24-2011 11:49 AM
installed standback having issues... cpolly69 MazdaSpeed 3/6 - ECU Computer Tuning 90 04-05-2010 11:01 PM
Logging with ATR DaleNixon
Cobb ATR Support
12 06-29-2009 10:38 PM
Data Logging Raglem MazdaSpeed 3/6 - ECU Computer Tuning 21 08-15-2008 07:41 PM
Page generated in 0.55604 seconds with 32 queries
