> Cobb Tuning >
Cobb Access Port/Maps
 Old 03-23-2011, 11:30 PM   #1
ChimmyChong's Avatar
Posts: 592   (View Stats)
ChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the world
Groans: 39
Default First Logs... stage1 map with test pipe ok?
Updated: Some one suggested that I should try the "Stage2+K&NSRI_91 BT-Safe Mode Map" with my mods... Gave it a go and here are my logs... Which map should I be running when comparing logs from the ones posted?
FP looks good to me on both... KR, LTFT, and STFT looks good on both too... Or are they bad??
Can I safely run the Stage1 map? Im pretty sure Im making bigger power on that since my calc load and MAF voltage was higher on those logs + boost
Hey guys,
Im running the "Stage1+KNSRI 93 v100D BT" map for my 2010 speed.
The only other flow mod I have on my car is a test pipe.
I heard that I may need to recalibrate my MAF but I don't know what to look for in that section (i don't know what is good).
Also, I noticed that my wgdc is maxing out at 100% at times...
Should I be running a "Stage2+KNSRI 91 v100D BT Safe Mode", which I believe will lower my wgdc but throw some other parameters off (if so what kind... what should I look for if I do end up testing this map out)
All these logs where completed after driving 28 miles and a few key cycles.
2010 Liquid Silver MS3
// BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray //
// JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers //
// 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's //
ChimmyChong is offline   Reply With Quote
 Old 03-23-2011, 11:33 PM   #2
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
The two I looked at looked pretty good. Considering get a fp soon though.
manelscout4life is offline   Reply With Quote
 Old 03-24-2011, 10:57 PM   #3
Groans: 39
Updated OP...
Can you guys compare my different map logs?!?!?!?!?
 Old 03-25-2011, 05:43 AM   #4
Amazon's Avatar
Posts: 2,679   (View Stats)
Groans: 214
Stage2 safe mode is for the stock fp. Your pressure is holding up fine, but I'm sure it will tell you to fuck off if you ask much more of it.
Amazon is offline   Reply With Quote
Stage1+SF+TIH+CDFP 93 Octane BT Logs PapaSmurf 2010 MS3 - ECU Computer Tuning 12 06-02-2011 06:24 PM
Ultimate racing test pipe and down pipe install w pics 2010 MS3 2010 MS3 - Engine, Transmission & Driveline 28 03-17-2010 10:38 AM
Brand name test pipe vs. custom muffle shop test pipe Huligan MazdaSpeed 3 - Engine, Transmission & Driveline 10 10-05-2009 07:52 AM
SU test pipe vs. turboxs test pipe ZoomByU MazdaSpeed 3 - Engine, Transmission & Driveline 22 08-06-2009 03:09 AM
Page generated in 0.25165 seconds with 23 queries
