> Cobb Tuning >
Cobb Access Port/Maps
  • 1 Post By dooderek
 Old 07-23-2010, 10:30 PM   #1
Chriscote's Avatar
Posts: 913   (View Stats)
Chriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the world
Groans: 137
Default Flat Foot Shift Issues
When i first tuned the FFS and LC my FFS worked like a charm every time. now about a month later it is messing up every time. i get blocked then end up grinding. is this my driving style or do i just need to retune. i have the limiter set at 5900 should i drop/raise if i aim to shift at 6k????
Chris
Chriscote is offline   Reply With Quote
 Old 07-23-2010, 10:32 PM   #2
Moving to the Cobb section..
 Old 07-26-2010, 04:20 PM   #3
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Chris
Chris,
This sounds like you may have a synchro wear issue. Does it help if you try to slow down your shifts? Have you changed your gear oil recently?
Gary
MAZDASPEED EXPERT GROUP
The Following User Says Thank You to Cobb Tuning For This Useful Post:
felt (07-26-2010)
 Old 07-26-2010, 04:29 PM   #4
Chriscote's Avatar
Groans: 137
Gary
Ill try slowing them down i have not tried recently just because i have been saving gas but i will tonight. the car only has 25K miles on it so it is probably not the gear oil. if you have anyting else i am all ears.
 Old 07-26-2010, 05:05 PM   #5
Gary
Let me know what your findings are and we'll take it from there.
Thanks,
Gary
 Old 07-27-2010, 07:50 AM   #6
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
Gary
You do know that the gear oil requires replacement at 24k mile intervals, right? Check the maint sched...
FORZDA 1 is offline   Reply With Quote
 Old 07-31-2010, 08:41 AM   #7
smakdown61's Avatar
Posts: 1,069   (View Stats)
Actually, changing the gear is oil isn't on the regular maintenance schedule. Under normal driving the original gear oil should last the life of the car (normal life). Now, for guys that constantly do FFS and launching, thats a different story...
smakdown61 is offline   Reply With Quote
 Old 07-31-2010, 09:12 AM   #8
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
I've been using REdline Mt-90 for 3 yrs, infact, i pumped it into the car the second day i've owned it. It works very well and that is what you should be using.
That's what I just put in for MTX fluid. Don't you have to use GL5 for the PTO and rear diff? Oh...you don't have a rear diff...ignore that part of the question.
KY is used for other things, certainly not for transmissions.
More frequently used on intakes or tailpipes. Sometimes on stick shifters.
Stealth01
2006 Mazdaspeed6 GT
 Old 07-31-2010, 09:22 AM   #9
[MSF STIG]
FORZDA 1's Avatar
Oh, maybe you're looking at the Speed3 sched? For the Speed6 the trans itself isn't listed in the maint sched, only the rear differential oil and transfer case oil which are also "gear oil". It's been a while since I looked at it and the mileage is actualy 29,100. You can do whatever you want with a Speed3, but I'll just go ahead and change the trans gear oil while I'm at it.
 Old 07-26-2010, 05:22 PM   #10
felt's Avatar
Posts: 1,504   (View Stats)
felt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the world
Groans: 1,364
Groaned at 589 Times in 386 Posts
Some have actually changed the tranny oil with KY or any "special lube" and there shifting had improved. Might be something to look at if all else fails.
felt is offline   Reply With Quote
 Old 07-27-2010, 03:19 AM   #11
evidence's Avatar
Posts: 1,033   (View Stats)
Haha.. is this a cruel joke on the guy who might actually try it, or did someone actually say that? You said it van damn style serious, so just incase.. KY being mostly water would perform terribly under heat, and not last long at all leaving you with a bunch of goop after the water evaporated..
On a serious note, Redline MT-90 is the shit for your tranny.
Some things.
The Following User Says NO Thank You to evidence For This Un-useful Post:
 Old 07-27-2010, 03:23 AM   #12
 Old 08-01-2011, 08:39 PM   #13
Mistersix's Avatar
Posts: 2,585   (View Stats)
Try setting your FFS limit down a bit. Try 5.5k. Your really close to your shift point and could be banging off of the FFS rev limit in mid gear change. making it hard for your synchros to....well sync.
I've found, with FFS, you want the tach needle to "fall" toward the starting rpm in the next gear. A setting thats to close or to far from the shift point seem to prove problematic.
 Old 08-01-2011, 08:45 PM   #14
2011speed's Avatar
Posts: 1,497   (View Stats)
Get dif fluid. It's magic
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 08-01-2011, 08:54 PM   #15
Mistersix's Avatar
I have to agree. I changed all my oils to amsoil severe gear and the car shifts felt noticeably better. The rear diff oil was black when it poured out. The other oil in the tranny and pto were clear. Whatever that was all about.
 Old 08-03-2011, 01:45 AM   #16
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
ky is for trannies, mt-90 is for transmissions.
well i think its clever
MS3CB likes this.
 Old 08-09-2011, 03:25 PM   #17
If you are going to be using FFS/LC on a regular basis, a high-quality transmission fluid is a must. If you notice that shifting is getting difficult, it's time to swap fluid at the very least. Lighweight shockproof by Redline is what we use in lots of cars. It really improves shifting feel quite dramatically. However, you do need to change it on a fairly regular basis if you are driving hard/drag racing etc.
Travis
COBB Tuning
Flat Foot Shifting Calculator & How To Set aaronc7
Cobb ATR Support
35 01-28-2014 08:47 PM
Cobb AP Flat Foot Shift????? michaeljp
Cobb ATR Support
15 07-31-2010 11:33 PM
Need help with installing flat foot shift gt5 MazdaSpeed 3/6 - ECU Computer Tuning 2 05-19-2010 11:27 AM
Launch Control and Flat Foot Shifting Mazdasp33d
38 08-06-2009 09:22 AM
Page generated in 0.37387 seconds with 30 queries
