> Cobb Tuning >
Cobb Access Port/Maps
  • 1 Post By ms3rick
 Old 04-14-2013, 08:53 PM   #1
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
Default Which map should I run?
The only mod that I have is a Sure full 3 Aeros so that is an intake and a TIH in one ( yeah i know sure sucks and all that)
What i am planning on running is the Stage1+SUR2+TIH 93. On the map it says that it could be used with the stock fuel pump but after i read a little more they say that all stage 2 maps and the Stage1+Intake+TIH require an upgraded fuel pump.
So im not sure if its ok to run that map without fuel cuts. Im not looking to upgrade my fuel pump internals just yet.
Could a custom tune or running Stage1+SUR2 93 map prevent the engine of needing 1600psi + fuel pressure?
If i have to upgrade the fuel pump i will. Just seems like a hassle to go through if i dont need it.
Thanks
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
 Old 04-14-2013, 09:07 PM   #2
DylanFYHN's Avatar
Posts: 641   (View Stats)
DylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the world
Groaned at 41 Times in 22 Posts
read bitch.
apparently you aren't even reading what the OTS map says. "no upgraded HPFP"
you might personally want to get hpfp. but the stage 1 ots map doesnt call for them.
why the fuck did i just be nice and answer your question? geeze i feel like a faggot now
DylanFYHN is offline   Reply With Quote
The Following User Says Thank You to DylanFYHN For This Useful Post:
Bulgsta (04-14-2013)
 Old 04-14-2013, 09:10 PM   #3
snailD's Avatar
Posts: 3,039   (View Stats)
if you dont have a fuel pump, you dont run a map which requires one. its pretty simple. run the best stage 1 map that works with your mods
Originally Posted by DylanFYHN View Post
read bitch.
you're trying too hard...
caesura (04-14-2013)
 Old 04-14-2013, 09:16 PM   #4
DylanFYHN's Avatar
Wanna see my peepee?
 Old 04-14-2013, 09:20 PM   #5
snailD's Avatar
theres a whole thread dedicated to that, you should post it in there
 Old 04-14-2013, 09:14 PM   #6
Bulgsta's Avatar
haha thanks faggot u da man.
im planning on getting hpfp by the end of the month
2007 Mazdaspeed 6
 Old 04-14-2013, 09:14 PM   #7
Pharms3's Avatar
Posts: 344   (View Stats)
Pharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the worldPharms3 is the leader of the world
Groaned at 7 Times in 3 Posts
u cant haz fast w mzr motor w/out upgraded hpfp internals... suck it up and buy the hpfp, test pipe and e85 tune
Pharms3 is offline   Reply With Quote
The Following User Says Thank You to Pharms3 For This Useful Post:
Newspeed23 (07-21-2013)
 Old 04-14-2013, 09:35 PM   #8
DylanFYHN's Avatar
So mention you when I do? That what your sayin?
 Old 04-14-2013, 09:40 PM   #9
snailD's Avatar
nah not my thing. but you seemed so eager to show someone i told you about a good spot to post it where you will get many thanks
 Old 07-21-2013, 03:41 PM   #10
strikerfire3000's Avatar
Posts: 2   (View Stats)
strikerfire3000 is an unknown quantity at this point
Default Not sure what map I should run
Hello all
I'm in the process of buying a cobb sport access port tune for my Mazdaspeed 6 07. the question I have is that the only mod I have so far is a DC Sport long ram air intake and I understand that the access port is not compatible with that intake. When spoke to a rep from COBB they said I might need to run a custom map. Can anyone point me in the right direction
strikerfire3000 is offline   Reply With Quote
 Old 07-21-2013, 04:15 PM   #11
ms3rick's Avatar
Posts: 2,959   (View Stats)
Originally Posted by strikerfire3000 View Post
Hello all
Www.stratifiedauto.com reckon you buy test pipe and Hpfp along with their etune
Sc0rp7 likes this.
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
Page generated in 0.32109 seconds with 24 queries
