![]() Join Date: Aug 2013
Rep Power: 0 ![]() Thanks: 0
Groaned at 7 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score 2011 mazdaspeed 3 Corksport FMIC with TIH and intake CS downpipe CS high flow CAT With full CS exhaust TS BOV Now should I run the Stage1+CS+TIH+IC 93 which has everything but the high flow cat and the down pipe or Stage2+CS+TIH+IC 93 which includes the HF CAT and Downpipe? also both maps have listed CDFP - Camshaft Driven Fuel Pump which I'm not to sure of. if anyone has some input that would be great.
__________________ 2011 MS3 - H&K lowering springs CS FMIC CS intake Turbosmart dual BOV CS down pipe CS high flow cat CS full CAT back COBB accessport V3 |
| The Following User Says Thank You to Cuneo'sSpeed3 For This Useful Post: | Sid3wayS (08-27-2013) |
