> Cobb Tuning >
Cobb Access Port/Maps
 Old 03-11-2014, 11:31 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Default Question regarding a logged parameter
So I finally noticed something that had been staring me in the face since I started my tuning adventure those many years ago.
I was comparing some logs from similar tunes and noticed that boost, MAF voltage, mass airflow, boost, timing, etc were all extremely close, but the boost temps, calculated load, IDC and VDyno output are way, way different.
This leads me to believe that the mass airflow reading that gets logged is actually just a lookup from the MAF table and *NOT* the baro/temp corrected *actual* airflow that the engine sees.
While I can provide logs if needed, I'm thinking that this is something that can only be confirmed/denied by Cobb directly, since only they will be able to dig through the rats nest that is our ECU and determine if this is the case or not.
As a side note, if it matters, I drive a 2009 first gen MS3.
Mauro_Penguin (04-13-2014), udntknw (03-12-2014)
 Old 03-11-2014, 11:45 PM   #2
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
Not to question you, but isn't that the point of the maf scale? When the maf sees x voltage, its assumed based on the maf scale that's what the airflow is?
Or maybe I'm not picking up what you are putting down. (more likely)
Just tapa it in.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
The Following User Says Thank You to udntknw For This Useful Post:
Enki (03-11-2014)
 Old 03-11-2014, 11:51 PM   #3
Enki's Avatar
Groans: 189
Basically, if you are looking at MAF voltage, you should be able to just go to ATR and translate that back into a whole number, give or take; voltage is a real, measurable number, but having mass airflow just look back to the MAF table is almost pointless if the *true* airflow number is, in fact, different from what the engine is actually basing its calculations off of.
The reason this could be important is that load numbers are at least partially based off of actual airflow; if you recall the post I made in your thread with links to the actual math used for the load PID, you'd see that there's multiple steps including factoring in barometric pressure and temperature that needs to be done to factor load.
Basically, knowing that this number is/is not accurate can make setting up a base map for load tuning quite a bit easier, and would potentially drastically improve tuning for aux fueling during weather changes (though I've not looked into that much, since I have little interest in going 5th port).
Mauro_Penguin (04-13-2014), Sergeant_M (04-11-2014), udntknw (03-12-2014)
 Old 03-12-2014, 01:06 AM   #4
Enki's Avatar
Groans: 189
Just went back through the logs in question, only this time instead of comparing voltage/airflow numbers between the logs, I compared the same voltage/airflow numbers within the same log...and now I'm a bit more confused as I'm seeing the airflow climb at the same voltage in proportion to RPM, except in instances where the voltage goes up and the airflow goes down.
After doing more math from the two logs, I'm still unsure as to whether or not this is what it should be (the diff numbers are just divided by the preceding numbers both ways):
5k airflow: 5650 l/min diff: 83.33%
6k airflow: 6780 l/min diff: 120.00%
ve 5k @ 2.0 load: .8660
ve 6k @ 2.0 load: .8630
eff 5k: 4893 l/m diff: 83.62%
eff 6k: 5851 l/m diff: 119.57%
massflow 5k: 318.02 diff: 81.88%
massflow 6k: 388.38 diff: 122.12%
massflow 5k: 297.32 diff: 83.18%
massflow 6k: 357.43 diff: 120.21%
So basically, all else being equal, the difference in airflow between 5k and 6k rpm should be ~20% more @6k compared to 5k, and that seems to bear out in the logs; however, the difference in peak airflow before redline is only ~14 g/s and the difference in reported power by VDyno is > 50 horse.
Someone call me a cab and get me out of crazy town. Please.
btstarcher (03-12-2014), Mauro_Penguin (04-13-2014)
 Old 04-11-2014, 12:04 AM   #5
Enki's Avatar
Groans: 189
Basically zero response on this thread/issue. Did some log tshooting with another member ( @NCspecV81; ) who was having issues with fuel pressure dropping even though he only had 80% IDCs, and it was determined that he was running out of fuel. Leaning him out resulted, strangely, in *HIGHER* IDCs and a resolution to the pressure dropping.
More fuel for the fire regarding pids that give weird/incorrect data.
 Old 04-11-2014, 10:33 AM   #6
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Groaned at 8 Times in 2 Posts
I'll put it on the list to investigate. However, just a warning, it's a long list!
The Following 3 Users Say Thank You to Evan@COBB For This Useful Post:
Enki (04-11-2014), Mauro_Penguin (04-13-2014), NCspecV81 (04-11-2014)
 Old 04-11-2014, 10:41 AM   #7
Enki's Avatar
Groans: 189
Better than nothing. Thanks!
 Old 04-11-2014, 11:10 AM   #8
Sergeant_M's Avatar
Posts: 504   (View Stats)
Sergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the world
You should just go work for NASA or something.
Sergeant_M is offline   Reply With Quote
 Old 04-11-2014, 11:47 AM   #9
NCspecV81's Avatar
Posts: 2,867   (View Stats)
This would be awesome. Something just isn't jiving right with IDC values on my logs.
Logged my 1/4mile run MTLspeed6 Mazdaspeed3/6 General Discussion 6 08-21-2013 02:01 AM
Ultimate Guide to Parameter Monitoring? ANITIX87 Gen2 MS3 General Discussion 50 11-19-2012 12:24 PM
Ultimate Guide to Parameter Monitoring? ANITIX87 MSF KB - Mazdaspeed 3/6 - ECU Computer Tuning 39 09-19-2012 01:36 PM
question about data logged fuel psi Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-16-2010 09:21 PM
STOCK engine parameter recordings RocketScientist MazdaSpeed 3/6 - ECU Computer Tuning 0 12-29-2009 10:43 AM
Page generated in 0.30888 seconds with 24 queries
