> MazdaSpeed 3/6 - Dyno Sheets/Discussions
MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information.
Like Tree3Likes
  • 1 Post By trifdignn
  • 1 Post By voodoo2crue
 Old 01-03-2018, 11:55 AM   #1
Speed2006's Avatar
Posts: 32   (View Stats)
Speed2006 will become famous soon enough
Default 08 Speed3 50/50 E85 dyno
Dyno of my Speed3 done at Speedline Performance in Ocala, Florida on 12/27/2017. Ambient temperature was 70°F, and pulls were in fourth gear. Only mods are Cobb SF and TIP, Autotech HPFP Internals, and a CNT catted DP. Car is ran on E48 (50/50) and it is self-tuned. First run registered as 365/413, and second was 369/410.
https://youtu.be/Ib0fY8-sP34
2008 Mazdaspeed3 E48 fuel
Cobb SF+TIH, CNT Catted DP, AP V3, Autotech HPFP Internals
369 WHP/ 410 WTQ 12/27/2017
Speed2006 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Speed2006 For This Un-useful Post:
Fstrnyou (01-03-2018), voodoo2crue (01-03-2018)
 Old 01-03-2018, 01:38 PM   #2
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
Damn that is impressive. This just goes to show how much power can be gained with E85. What boost and timing are you running to get that kind of power?
2007 Sunlight Silver Mazdaspeed3
Engine:
\\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\
Tuning:
\\Cobb AP V3\\ Freektune Custom Tune \\
Suspension/Brakes:
\\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\
flapjack is offline   Reply With Quote
 Old 01-03-2018, 03:02 PM   #3
Speed2006's Avatar
I've got the boost at 22-22.5psi, and my timing at 2 load is as follows:
Timing: -2.75 0.5 2.80 6.45 8.75 10.35 11.5 15.50 18.50 19.50
RPM: 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000
 Old 01-03-2018, 03:07 PM   #4
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
Either that dyno calibration is off or your driving a unicorn.
Which is it?
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
The Following User Says Thank You to voodoo2crue For This Useful Post:
sharksinspace (01-04-2018)
 Old 01-03-2018, 03:22 PM   #5
Speed2006's Avatar
The only reason why I don't question it too much is because it pretty-decently mirrors the Vdyno. I was personally expecting about a 350/400 kind of run, but I believe that this isn't all too far off.
 Old 01-03-2018, 03:33 PM   #6
Speed2006's Avatar
Also attaching a datalog from the dyno for those interested. BAT's were in the 130's after sitting on the dyno.
 Old 01-03-2018, 04:05 PM   #7
trifdignn's Avatar
Posts: 11   (View Stats)
trifdignn will become famous soon enough
You have a jesus ko4 lol
voodoo2crue likes this.
trifdignn is offline   Reply With Quote
 Old 01-03-2018, 04:14 PM   #8
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
At first glance, the math didn't seem to add up.
At 80% inj duty cycle with an E50 mix isn't that much fuel, but when compared to a max of around 255g/s...it's seems to match up.
Napkin math says 255g/s is about 250-275 whp for pump gas.
The E mix is allowing you to roll in about 10-11 degrees more timing.
I've read on this forum that each degree of timing can add up to about 10hp. Up to MBT of course.
That puts you exactly where you are.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Speed2006 (01-20-2018), Thor Hammer (01-04-2018)
 Old 01-03-2018, 04:19 PM   #9
Unicorn it is
Sent from my SAMSUNG-SM-G890A using Tapatalk
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 01-03-2018, 04:55 PM   #10
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Damn I thought the K04 was only good for 320-330 whp on an E mix. That torque must feel great but are you on a stock block?
 Old 01-03-2018, 05:35 PM   #11
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Dynojets read higher than mustang dynos.
Adjust your vdyno correction factor to 1.01 and report back
Sent from my SM-G930T using Tapatalk
 Old 01-03-2018, 06:05 PM   #12
When I put this into v dyno it comes up 293/296 which is more of what to expect out of a solid running K04 on an e mix. I'm going to conclude that it's not a unicorn afterall.
Also, why are you revving out to 7200 on stock block/k04? That's high risk/0 reward with the k04.
BuddySpeed3 likes this.
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 01-20-2018, 07:51 AM   #13
Speed2006's Avatar
I wasn't the one revving to 7200 lol I know there's no power up there. That was the dyno guys. I just made 7200 my rev limit in Accesstuner just in case I missed a gear or wanted to show off
The Following User Says NO Thank You to Speed2006 For This Un-useful Post:
voodoo2crue (01-23-2018)
 Old 01-20-2018, 08:26 AM   #14
Speed2006's Avatar
[QUOTE=voodoo2crue;3135906]When I put this into v dyno it comes up 293/296 which is more of what to expect out of a solid running K04 on an e mix. I'm going to conclude that it's not a unicorn afterall.
Wait... A 50/50 e85 Speed3 running 22 PSI, and 296 ft-lbs of torque seems more reasonable? Most OTS Cobb Stage 2 Speed3's running 93 can surpass that.
Running 14.5 PSI putting down 295:
First dyno pulls on Stage 1 and Stage 2 Cobb Maps
And almost every car on stage 1 or 2 on the COBB database puts down at least 300 ft-lbs of torque running only 15 or 16 PSI. https://www.cobbtuning.com/dyno-database/
Please, 410 might have been a high-reading, but I'm certainly not making 120 ft-lbs less than that.
 Old 01-23-2018, 07:10 AM   #15
[quote=Speed2006;3137094]
I didn't make those numbers up, I used your data log with the CF 1.01 factor that everybody else uses on this forum. It's not perfect but should give you a good idea of power/torque made. Even if it was off 20-30 hp/tq your still not close to what that dyno said. It's a VERY happy dyno, you believe whatever you want to.
Cheapspeed likes this.
2012 MS3 VRM/w Tech
Oil-RP 10/30
The Following 2 Users Say Thank You to voodoo2crue For This Useful Post:
Cheapspeed (01-23-2018), sharksinspace (01-23-2018)
 Old 01-23-2018, 09:16 AM   #16
Fstrnyou's Avatar
My personal take on dynos, use them for testing/tuning. The actual accuracy of the number is rubbish, but they're great for comparative analysis.
Other rides:
History:
Speed2006 (01-23-2018), Thor Hammer (01-23-2018)
 Old 01-23-2018, 11:08 AM   #17
Speed2006's Avatar
Okay. Is the Vdyno corrected for e85? or is it just gasoline predictions? If it's basing off gasoline numbers, I could understand that, just based off g/s of air. With e85 running much richer, the amount of air needed for combustion is much lower compared to 93, which could skew the numbers. Still don't know why I'm getting groaned at for posting numbers and video. Not making outrageous claims, just reporting what the machine told me.
 Old 01-23-2018, 11:13 AM   #18
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
you don't have to calibrate vdyno for different fuel types. at least not that i have ever heard of. we do need to know your tire size and weight numbers, though.
fwiw, my stock block CS turbo on e30 vdyno'd at 365whp, and ran on a dynojet at 375whp. to approach that on k04 is far from the norm.
Genpoo stuff
 Old 01-23-2018, 11:37 AM   #19
Speed2006's Avatar
I will admit that the HP appears to be high; that much is certain. But I do not believe that the TQ number is very far off. Phate with almost the exact same mods, running similar timing with just full e85 rather than 50/50 was putting down 430 ft Lbs. I know that the torque is there, because I beat JB4 335i's, 5.0's and S3 Speed3's.
E85 Discussion - HPFP lubrication and Flow issues
 Old 01-23-2018, 11:51 AM   #20
Fstrnyou's Avatar
vDyno measures the rate of acceleration and uses weight, gear ratio, tire size, etc and uses physics to calculate torque required to do X amount of work. Horsepower is calculated like always from the calculated torque and RPM.
Engine size, VE, BSFC, fuel type, ignition timing, boost, etc are irrelevant to the calculation.
Other rides:
History:
 Old 01-23-2018, 12:04 PM   #21
Speed2006's Avatar
What gear did you do the calculation in? When I put my run into Vdyno on 4th gear, smoothing at 4, and CF=1.01 I get this
2013 Speed3 Dyno NCspecV81 2010 MS3 - Dyno Sheets/Discussions 5 07-07-2015 07:25 AM
Mustang Dyno my Speed3 (Part 2) mleblond MazdaSpeed 3/6 - Dyno Sheets/Discussions 20 09-21-2009 03:33 PM
Mustang Dyno my Speed3 mleblond MazdaSpeed 3/6 - Dyno Sheets/Discussions 39 10-15-2008 11:37 AM
Page generated in 0.40793 seconds with 28 queries
