> MazdaSpeed 3/6 - Dyno Sheets/Discussions
MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information.
 Old 01-28-2016, 03:55 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
Default Need advice/help
I have a fully bolted MS6 and am on my first draft e85 map from freektune. I did a 4th gear log and put it into virtual dyno (cf 1.09) and im only getting around 268-270hp/330 tq. thats seems pretty low for bolted e85...i understand lots of drivetrain loss but still. So i just got done doing a compression test 177/177/176/175. shouldnt i be just a little higher in hp?
wes3id is offline   Reply With Quote
 Old 01-28-2016, 04:30 PM   #2
Police - Grammarhead
Vansquish's Avatar
What's your E85 mixture ratio?
I can say that with an almost fully-bolted (no exhaust mani) MS6, I was able to get to around 290/335 on pump gas at relatively low temperatures.
270/330 isn't bad for the MS6, but I suspect you'll end up above that once you're fully tuned. A first revision from freektune is going to be a relatively safe place to start, and it won't be indicative of the full power you're likely to be able to achieve.
 Old 01-28-2016, 04:39 PM   #3
wes3id's Avatar
im running Full E85, no mix.
 Old 01-28-2016, 05:36 PM   #4
What's the approximate max whp/wtq on 100% e85 on a speed6 on stock injectors?
 Old 01-28-2016, 05:39 PM   #5
I wouldn't have even bothered putting a first draft into Vdyno. It will be in no way indicative of the final result.
InkedInspector (01-28-2016), MS3Shadow (01-28-2016), TiGraySpeed6 (01-29-2016), Vansquish (01-28-2016)
 Old 01-28-2016, 05:42 PM   #6
Vansquish's Avatar
I hope you like cleaning your HPFP...
The Following 4 Users Say Thank You to Vansquish For This Useful Post:
Easter Bunny (01-28-2016), InkedInspector (01-28-2016), MS3Shadow (01-28-2016), robbspeed (01-28-2016)
 Old 01-28-2016, 05:55 PM   #7
wes3id's Avatar
I read up on the redline si-1 treatment. taking of the HPFP and cleaning it with si-1 every now and then doesnt take much time at all.
The Following User Says Thank You to wes3id For This Useful Post:
 Old 01-28-2016, 06:01 PM   #8
Vansquish's Avatar
Watch those o-rings, and you might want to consider going for some nitrided HPFP internals (Integrated Engineering sells some).
 Old 01-28-2016, 06:13 PM   #9
wes3id's Avatar
I just started using virtual dyno, and am only doing it for reference. but that is good to hear...i was really hoping to at least hit 300 whp.
Thought i read that those IE internals didnt do so well on full E85.
No Idea, i'm late to the corn game. was under the impression (from research on here) that we don't yet have any upgraded injectors available yet.
Last edited by wes3id; 01-28-2016 at 06:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-28-2016, 07:29 PM   #10
Vansquish's Avatar
Not sure where you got that info. @littleloogy;?
IE HPFP Internals For E85
Correct. Here's the most recent info:
Upgraded injectors (because aux fuel is for losers)
wes3id (01-28-2016)
 Old 01-31-2016, 02:17 PM   #11
wes3id's Avatar
tried doing another 4th gear pull after changing a plug..still on first draft of freektune full E85 tune....not too bad, i can accept this...can't wait to see what i the final revision will look like.
File Type: jpg virtual dyno run 1 4th gear pull e85A.jpg (131.4 KB, 24 views)
My first Maf Cal log, need advice JDMJOSH 2010 MS3 - ECU Computer Tuning 0 11-02-2012 12:21 PM
advice please mps6dave Mazdaspeed3/6 General Discussion 11 06-29-2012 03:40 PM
Page generated in 0.30922 seconds with 24 queries
