| Review Discussion Want to comment on a review, do it here. |
![]() Join Date: Apr 2017
Rep Power: 0 ![]() Thanks: 19
(Thread Starter) | Not Ranked : 0 score I have a 2006 mazdaspeed 6 with a corksport srt + tip, Cobb apv3, corksport hpfp, and some other mods. anyway, I only get 13 peak psi of boost and the most ive ever seen was 14.1 on the cobb. I looked all over my pre and post turbo connections and everything seems tight and secure. Ive also tried unplugging the battery and doing a re-flash of the cobb ots stage 1+sf 93 map. still not hitting over 13psi. my idle is smooth. However, my wastegate duty cycle on the cobb seems to be a bit suspect and starts to kick in around 10 ish psi. Thoughts? |
| Display Modes | |
| Low boost issue | nicknguyenle | 2010 MS3 - Troubleshoot/Diagnostics | 4 | 02-05-2018 08:30 AM |
| Over Boost Issue, Boost leak? | vincentspeed3gogh | MazdaSpeed 3/6 - ECU Computer Tuning | 23 | 12-27-2014 02:31 AM |
| Need Help with a possible Boost Cut issue??? | EddyV1987 | MazdaSpeed 3/6 - Big Turbo Builds | 7 | 04-24-2013 04:24 PM |
| Boost issue | sriser66 | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-19-2013 10:40 PM |
