| Appearance - RED All appearance mods for RED cars |
![]() Join Date: Jan 2012 Location: Kingston, ONTARIO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 82
__________________ 2007 MS6, COBB AP, SU RMM, TT DIF MOUNT, COBB SRI/TIP, AUTOTECH To be installed: CX racing FMIC, CS DP, TWM shifter, Oil catch can [SIGPIC][/SIGPIC] |
![]() Join Date: Nov 2011 Location: San Diego, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
| Not Ranked : 0 score i can dig it man. looks perfect from behind, but a little dark from the side shots... what tint did you use and %? been thinking of doing this on my MS3
__________________ 09 CWP MS3: COBB AP / MSD DH / AT HPFP / CPE SRI / CS TIP / CS BT-RH / M2 DP / CNT CBE / HKS BPV / EVO X / E85 PERM FREEKTUNE 330/38007 TGM MS6: COBB AP / JBR PP SRI/TIP/ JBR BT-RH / CS CBE / FORGE V1 / JBR RMM / H&R CO Stratified OTS 07 BM MS6: DREADNAUGHT / JUGGERNAUT / SU DMM*PMM*TMM / JBR RMM / BC CO / MAGNAFLOW CBE / JBR OCC / SURE BSD / PRODRIVE GC06-H ![]() Long Signature made especially for Micha |
![]() Join Date: Apr 2012 Location: Minoa, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,172
| Not Ranked : 0 score Looks good man... I'm about to do mine once the temp here in NY warms up
__________________ 2012 Black Mica Mods CS catless DP, CS RP Magnaflow CBE Autotech HPFP NGK Plugs CS RMM JBR PMM CS Short Shit Kit and Shifter Bushings Cobb SRI and TIP CS TMIC SU Boost Tubes JBR Reticulation Tube Cobb AP v2 H&R springs JBR Rear Sway Bar Self Built 3 Port EBCS maisonvi Shift Knob Tuned on 93 and corn [SIGPIC][/SIGPIC] |
| Not Ranked : 0 score are you guys taking them having them tinted or just using a self tint spray or laminex stuff
(Thread Starter) | Not Ranked : 0 score I did the spray shit I bought from Canadian tire in Canada... I think its called VHT night shade... 13 bucks a can.. i put on 2 coats... 4 is the max... 1 coat of clear at the end.. a quick sand and then polish. The cops around here can be idiots so i didnt want to go too dark... im actually happy with the way it turned out. ohh and the pics were taken with my phone so it looks better in real... the side shot does look darker.
| Not Ranked : 0 score I think im gonna do the stick on shit lol... But hey you Should have put way more then 1 coat of clear coat on...
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score i like it, I'm undecided on going with black or red since i dislike the clear of the pu
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
| Resident Baus ![]() Join Date: Mar 2011 Location: Cherry Hill, NJ
Rep Power: 356 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groans: 34
Groaned at 56 Times in 18 Posts
| Not Ranked : 0 score it's not bad, would've been great just a little less dark. looks like a good job though
__________________ 2011 Black Mica MS3 FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines Installation TBD: H&R springs + Koni yellow shocks + struts |
![]() Join Date: Feb 2012 Location: Dana Point, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,483
Groans: 107
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score You should black out the emblems. If you use plasti-dip you can take it off if you don't like it.
__________________ 2012 MS3 Stratified 91 Cobb AP | UR FMIC, TP, CBE | Autotech Internals Forge v2 BPV | Denso ITV22 | SURE Aeros Full3 ID283* JBR 88a RMM/TMM, 70a PMM, OCC, RSB, TIGs, Coolant bypass, EGR delete, Bushings, Knob Aeroforce Interceptor | Defi Boost gauge *Product is advertised as ID300 |
![]() Join Date: Aug 2011 Location: Terrebonne Quebec
| Not Ranked : 0 score real nice. works well with the black rims. i agree with the black emblems... would make it all look uniform. |
(Thread Starter) | Not Ranked : 0 score I will try it out... plasti dip is hard to find around here... id have to order it from TO and pay shipping... i paid 27 dollars a can last time but they dont stock it anymore because of the chemicals in it.
![]() Join Date: May 2011 Location: Lexington, KY / Troy, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score Plasti dip is releasing a smoke spray, designed to be a removable tail light (as well as anything, really) tint solution Tapped
__________________ 08.5 CWP MS3 GT AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays |
| The Following User Says Thank You to cabrone For This Useful Post: | DiGi Faggot (05-03-2012) |
![]() Join Date: Sep 2011 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,381
Groans: 148
Already is out: Plasti Dip Smoke | Plasti Dip Interntional Plasti Dip Smoke Blackout Smoked Tail light Tint Taillight Tinting Spray Paint 075815112200 | eBay | |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Looks great! I was undecided on this but you just sold me on it.
__________________ 2007 Mazdaspeed 6 Velocity Red Mica - Bone ass stock. |
| Need Tail light | Fartee | Mazdaspeed3/6 General Discussion | 7 | 02-09-2012 11:21 AM |
| Need new rear tail light | JeffTheMan | Mazdaspeed3/6 General Discussion | 0 | 12-24-2011 05:03 PM |
| CAR LED Tail Light MS6 | Poohster | MazdaSpeed 3/6 - Appearance | 9 | 06-22-2011 11:47 AM |
| Tail light question. | feldm4n | Mazdaspeed3/6 General Discussion | 9 | 12-20-2009 03:05 PM |
