> MazdaSpeed 3/6 - Appearance > Appearance - Exterior > Appearance - WHITE
Appearance - WHITE All appearance mods for white cars
 Old 10-14-2012, 03:09 PM   #1
typeshluder's Avatar
Posts: 127   (View Stats)
typeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the worldtypeshluder is the leader of the world
Default Freshly Detailed
Washed. clayed, waxed and put new plugs in before winter.
typeshluder is offline   Reply With Quote
The Following User Says Thank You to typeshluder For This Useful Post:
smoogs12 (10-14-2012)
 Old 10-14-2012, 03:13 PM   #2
Bob-o's Avatar
Posts: 1,312   (View Stats)
Clean! I rather fancy the rain guards on your windows
 Old 10-20-2012, 01:27 AM   #3
EvoFire's Avatar
Posts: 389   (View Stats)
EvoX Enkeis? What are you dropped on?
 Old 10-20-2012, 02:03 AM   #4
tastysi2004's Avatar
Posts: 1,063   (View Stats)
very nice. and yes, what suspension are you runnning?
2008 MS3 gt mica black
EL NATOR DE Virginia/Florida
Update: getting that
Purple drank in my tank.
554whp/546wtq @ 30psi.
another build? maybe soon..
#CATBACKEXHAUST
 Old 10-20-2012, 03:27 AM   #5
BOTTLEFED08's Avatar
Posts: 730   (View Stats)
BOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the world
Jelly of the white.. Looks very nice. What brand rain guards do you have?
2008.5 Mazdaspeed 3 (sold)
2014 Evo X Gsr
BOTTLEFED08 is offline   Reply With Quote
 Old 10-20-2012, 03:56 AM   #6
KevMS6's Avatar
Posts: 316   (View Stats)
Quality looking motor
Tuned with by
 Old 10-20-2012, 07:09 PM   #7
Yep, Evo X wheels with an Eibach Pro Kit
They are JDM OEM Mazda. Not sure if you can still get them new.
 Old 10-20-2012, 08:29 PM   #8
Sweetsandman's Avatar
Posts: 334   (View Stats)
Sweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the world
Looks awesome!! Those wheels are sseexxxx
I'd love to get a set off the EvoX MR (BBS I think?)
I Tapped that
'08 Cobalt SS - 334whp- SOLD
'09 WRX - Stage 1 - SOLD
'12 Mazdaspeed3
Sweetsandman is offline   Reply With Quote
 Old 10-20-2012, 08:38 PM   #9
EvoFire's Avatar
How much did you need to roll? And does it still rub?
 Old 10-21-2012, 08:42 AM   #10
I did a little bit of a roll with a baseball bat in the rear, which got rid of the rubbing. I'm on 225/40 tires though, so any wider you'd definitely need to do more work to the fenders.
I Tapped that
Yeah me too. The guy I bought my Evo wheels from upgraded to the BBS MR wheels. They are EXPENSIVE!
 Old 10-21-2012, 02:47 PM   #11
EvoFire's Avatar
I have a set I can get my hands on for probably $500, this is Canada mind you so everything is more expensive up here.
I want to put some 235/45, if not 235/40. I find the gearing already too short and some extra sidewall won't hurt. Only probably is trying to make it fit cause the offset is quite low on the Enkeis (+38 I believe).
Then my car will be exactly the same as yours lol.
BTW what lip is that on the front?
freshly murdered karl-hungus MazdaSpeed 3/6 - Wheels & Tires 6 02-17-2012 01:52 PM
freshly clean and waxed TGM ms6 jdcms6 Car Detailing 9 01-15-2011 11:12 PM
My freshly PC'd RX8 wheels 08BLKMS3 Wheels & Tires - BLACK 46 05-06-2010 09:50 PM
Page generated in 0.31489 seconds with 26 queries
