> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - RED
Wheels & Tires - RED Wheels & Tires on red cars.
 Old 08-23-2018, 10:43 AM   #1
Loophole35's Avatar
Posts: 59   (View Stats)
Loophole35 is just really niceLoophole35 is just really niceLoophole35 is just really niceLoophole35 is just really nice
Default 08 MS3 w/ 949 6UL's 17x9 +48
Here's my 2008 red MS3 on 6UL's. I've not seen any other MS3's with these wheels, I know the MX-5 community uses them a lot.
I'm on Koni yellow's and H&R sports. No spacers in the front and rear is rolled and tab trimmed. No camber kits.
Tires are 245/45R17 Falken 615+
Let me know what you think.
Loophole35 is offline   Reply With Quote
The Following User Says Thank You to Loophole35 For This Useful Post:
mr_mazda329 (03-28-2019)
 Old 03-27-2019, 05:17 AM   #2
reynellflores's Avatar
Posts: 2   (View Stats)
reynellflores is an unknown quantity at this point
How is this setup working for you so far? I have been looking for wheels for quite a while and considering 17x9, 17x8.5 and 18x8.5. I am currently on Rx8's and would like something lighter like RPF1's but I don't want to use spacers or have rubbing issues in the back.
reynellflores is offline   Reply With Quote
 Old 03-27-2019, 11:35 AM   #3
Loophole35's Avatar
Still going strong. Had the very rare rub in the right rear and ended up putting camber kits in the rear and setting to -2.6°.
Love the added grip. May try out RE71R's next set of tires though, nothing wrong with the Falkens just want to try the best tire out.
2008 True Red Mazdaspeed 3
Mod list:
Cobb RMM, TIP, SRI w air box, CBE and AP3
Corksport Short throw plate w/ shifter bushings, TMIC and BPV
CPE catted DP
Tune done by Will at PD-Tuning (still slow need BT)
150k miles on original motor and turbo
H&R sport springs w/ Koni yellows
17x9 +48 6UL with 245/45R17 Flaken Azenis
 Old 03-27-2019, 09:31 PM   #4
Glad is working for you!
So how much clearance you think you have on the front? I suppose it is tight since you are not using spacers?
 Old 03-28-2019, 02:41 AM   #5
mr_mazda329's Avatar
Posts: 798   (View Stats)
mr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the world
Groans: 55
Nice to see someone try them out. I have about 4 sets of 6ULs for my Miatas. They look great on your car. Tungsten/Red combo works really well.
You'll love the RE71Rs over the Falkens, but I would recommend the BFG Rival S 1.5s over them. You pay more, but it truly is the better tire other than wet grip. RE71Rs will heat cycle out quicker than the rivals as well.
09 MS3 CWP BNR-S3 GFB Respons BPV, HTP 3.5in whalepenis , CXRacing/TR8L Core FMIC CorkSport CBE CNT Catless long DP, NGK Plugs, DM Trilogy, Cobb AP VEGA Tuned, CP-e HPFP CP-e Injector Seals
97 Miata Daily Driver
04' Mazdaspeed Miata Track Car
Road Racing > Autocross > Spirited Driving > Sitting in Traffic > Mowing Lawns > Drag Racing
mr_mazda329 is offline   Reply With Quote
The Following User Says Thank You to mr_mazda329 For This Useful Post:
Loophole35 (03-28-2019)
 Old 03-28-2019, 09:50 AM   #6
Loophole35's Avatar
I’ve got about 10mm between the shock body and rim and about 5mm between the bead protection of the tire and the shock body. The little rubber “hairs” would touch but no rubbing.
If I were running coil overs I would need likely a 10mm spacer.
Mod list:
CPE catted DP
17x9 trm c3 speed3sailor Wheels & Tires - SILVER 7 10-06-2014 06:41 AM
17x9 +35 StevenW 2010 MS3 - Wheels & Tires 16 09-04-2014 06:40 AM
17x9 +45 with 255/40 TWOptSL0W MazdaSpeed 3/6 - Wheels & Tires 19 07-16-2012 02:43 AM
Page generated in 0.26323 seconds with 23 queries
