> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - RED
Wheels & Tires - RED Wheels & Tires on red cars.
 Old 05-29-2014, 10:37 PM   #1
zooomMPS3's Avatar
Posts: 67   (View Stats)
zooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud ofzooomMPS3 has much to be proud of
Neutral  +1 score
Default Speed 3 on Evo X's
So, I finally got these 18 x 8.5/38 offset Evo X's wrapped in 235/40/18 Nitto NT555's today. I am really liking the look. I previously fitted the Mazda centre-caps to which went in no problem. There is a bunch of rubbing in the rear if I don't take it slow but I am going to raise the rear suspension between 3-5 mill, roll the rear fenders a lot more thoroughly and grind back the joins where the rear bumper meets the rear fender to eliminate any rubbing.
Please excuse the very poor photography.
zooomMPS3 is offline   Reply With Quote
The Following 4 Users Say Thank You to zooomMPS3 For This Useful Post:
12blkms3 (05-29-2014), J'sSpeed3 (07-21-2014), Jsn_Rob (05-31-2014), snailD (05-29-2014)
 Old 05-29-2014, 10:59 PM   #2
12blkms3's Avatar
Posts: 735   (View Stats)
12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world
Groans: 68
Groaned at 62 Times in 29 Posts
I did the same this weekend, had to roll the rears. These are 245 / 40/18
[SIGPIC][/SIGPIC]2012 Black Mica
JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers
324whp 368tq Vdyno CF 1.01
268whp 300tq AWD Mustang Dyno
3 GAL. E85 mix STRATIFIED
13.10 @ 108.1 (Nt05's) Auto Club Speedway
12blkms3 is offline   Reply With Quote
The Following User Says Thank You to 12blkms3 For This Useful Post:
snailD (05-29-2014)
 Old 05-29-2014, 11:01 PM   #3
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Groans: 332
Same as above, rubbed like a mofo even with rolled fenders. Added some negative camber and it's gone.
Emerald Green 2002 Miata
Mods:
Waiting list:
Full vinyl wrap
Events:
LynzeCs bottom bitch.
 Old 05-29-2014, 11:23 PM   #4
Sinister_Speed3's Avatar
Posts: 180   (View Stats)
Sinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond repute
I am getting tires (235/40/18) installed tomorrow but will wait to install so I can get the fenders rolled before install.
Sinister_Speed3 is offline   Reply With Quote
 Old 05-29-2014, 11:25 PM   #5
zooomMPS3's Avatar
Yes I highly recommend that you do. The set up will rub like crazy if you don't, whether lowered or stock. Good luck with it
 Old 05-29-2014, 11:50 PM   #6
snailD's Avatar
Posts: 3,039   (View Stats)
looking good, it seems very familiar just on a juan instead of poo. i need to get mine rolled still but the rubbing really isn't too bad. 245/40 falkens, which run a little narrow so probably fit a little more like 235's and on swift springs.
12blkms3 (05-30-2014)
 Old 05-30-2014, 12:28 AM   #7
zooomMPS3's Avatar
Yeah this is why I went with 235's instead of 245's. With 245's the rubbing would have been destructive. As it is I have to be careful because after half a day the join where the rear bumper meets the fender has been slightly pushed out. It's an easy fix thankfully.
 Old 05-30-2014, 08:16 PM   #8
12blkms3's Avatar
Groans: 68
Is your fog light missing?
 Old 05-30-2014, 11:39 PM   #9
snailD's Avatar
yea they both are
 Old 05-31-2014, 01:25 AM   #10
zooomMPS3's Avatar
Yeah so, really liking the wheels, the rubbing in the rear..... not so much. Today I got the rear raised a bit, some edges of the rear fenders ground, and a bit more of a roll. Thing is, its still rubbing a bit. This I expect but its gonna be a drag if I have passengers in the rear so now I am contemplating getting the rear fenders professionally widened slightly in a way that keeps the original shape of the fender.
 Old 06-01-2014, 07:19 PM   #11
EvoFire's Avatar
Posts: 389   (View Stats)
Can you tell where its rubbing exactly? Maybe just attack that section with a vengeance. I know my car rubs on the joins, and I'll probably grind the tabs a bit more in a few weeks.
Video: High-speed bicycle inspired by land-speed-record cars Haltech Automotive News 1 08-03-2013 07:43 AM
Official: 2013 Bentley Continental GT Speed debuting at Goodwood with 616 HP and 205 MPH top speed Haltech Automotive News 0 06-20-2012 05:20 AM
Page generated in 0.31640 seconds with 26 queries
