| Wheels & Tires - BLACK Wheels & Tires on black cars. |
![]() Join Date: Jun 2010 Location: Cedar Rapids, IA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
(Thread Starter) | Not Ranked : 0 score I'm getting rust blisters along the front edge of my hood, right along one of the bends. I tried to grind one out, rust treat it, fill it and repaint the area. It looked pretty good for about a week then started rusting right back through the damned patch. Has anyone had any luck fixing these blisters, short of buying a whole new hood? |
Groans: 433
| Not Ranked : 0 score grinding it isn't going to fix rust. you gotta sand it out until ALL the rust is gone, then you fill it, prime it, and repaint it. if you don't get all the rust, that will happen again within a week or so.
(Thread Starter) | Not Ranked : 0 score Yeah, which is exactly what happened to me. I think the rust is coming through from the inside of hood somewhere. I'm just trying to figure out if it's possible to do anything about it that would be any cheaper than just buying a new hood. |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score I have these too. I also think water/moisture gets behind and under the bend on edge of hood.
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
| Raise Your Hood Easily with the CorkSport Hood Strut Lift Kit | CorkSport | CorkSport | 285 | 12-10-2014 11:10 AM |
| Hood Pins for Firberglass Hood | airhunt2 | Mazdaspeed3/6 General Discussion | 8 | 04-23-2014 10:39 AM |
| Official: Limited Edition Range Rover Evoque blisters eyeballs | Haltech | Automotive News | 0 | 01-11-2013 09:50 AM |
| Hood Bra | Rom_Chek | MazdaSpeed 3/6 - Appearance | 7 | 05-24-2012 10:20 PM |
