| Wheels & Tires - SILVER Wheels & Tires on silver cars. |
![]() Join Date: Mar 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score ![]() IMG_3176.JPG |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| If you're lucky those screws might be sitting on the splash guard under the engine. If you're unlucky, you may have fuel starved your engine enough to cause internal damage. You need to pull the pump, check the O-rings and make sure they haven't been damaged (pinched) or destroyed. Then you need to check the pump, the housing, and the cam follower to make sure you haven't damaged any of those items either. Then you need to get yourself some new screws, the appropriate variety of thread-locker or locktite, and re-install the pump properly.
| The Following User Says Thank You to Vansquish For This Useful Post: | Spectrix (08-29-2018) |
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
Groans: 211
Is your pump physically stuck in the block? If so, you'll need to enlist some help and figure out a way to get it out. I understand you probably cant afford to tow it to a shop but the dealer may be your best bet. Independent shops might know how to work on your car as well and would be less expensive. On another note check out the Nator section and see if any locals can lend a hand. Where are you from?
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| The Following User Says Thank You to Thor Hammer For This Useful Post: | Vansquish (08-29-2018) |
![]() Join Date: Apr 2016 Location: Richmond, VA
| Not Ranked : 0 score Oh, man. You better hope your cam follower didn't pop out and get crushed by the cam lobes and wedge everything together. If that's the case, both you and whoever attempts to separate that mess is in a world of shit. |
| Not Ranked : 0 score Just kidding. lmao But hopefully that scared you enough to know what's actually possible. If the car still runs and just gives you an engine code you're probably fine. Just tighten it back up. It's spring loaded, so it requires force to push in. There's a good chance you screwed up the piston though. Good news is you already have new internals. |
| Not Ranked : 0 score I probably should clarify what you should do if it's "stuck"... The fuel pump has a piston that sits inside the cam follower. It's a solid piece of metal and it doesn't like to flex. If it's crooked, it won't want to come out or go in and will seem to be "stuck." You might have to straighten it out by putting pressure on the side where the bolts came undone, threading in the bolts, then loosening the bolt that is in place. It should come out if it's straight. Inspect everything and make sure nothing is damaged, including the cam follower. The cam follower is a little bucket that sits on top of the piston. That contraption looks like this: (Intake Cam Lobes)▷[===(Fuel Pump Piston) When you pull the piston out, stick your finger in the hole and grab onto one of the inner walls of the cam follower bucket and pull it out to inspect it. It's normal for the sides to be a little bit worn, so don't worry about scuffs unless they're big enough that you can feel them with your fingernail. As long as everything looks fine, replace your fuel pump piston and put everything back together. |
| I messed up | sboogie | Mazdaspeed3/6 General Discussion | 18 | 03-20-2013 07:34 PM |
| Messed up BAD | dpolseno41 | Mazdaspeed3/6 General Discussion | 10 | 03-14-2012 07:46 PM |
| AP messed up... | glndrums | Cobb ATR Support | 10 | 09-11-2011 12:09 PM |
| all messed up | bmfms3 | Exterior | 54 | 07-04-2011 02:29 PM |
