 Old 06-01-2016, 07:11 PM   #1
Lex007's Avatar
Posts: 5   (View Stats)
Lex007 will become famous soon enoughLex007 will become famous soon enough
Default 18x9 JNC010's w' 245/40/18
I've done a fair amount of searching on these forums and decided to just post a thread asking the community for help. I want to buy and install a set of JNC010 18x9's with a 30 offset. The only catch is that I really want to go with 245/40R18's! I am installing H & R coilovers with SPC front adjustable ball joints and the Corksport rear adjustable camber arms. Will this setup work and how much if any fender work will need to be performed? I haven't seen anyone on here with a wheel offset lower than 35. There's one member with a set of XXR 530's with a 35 offset, but that is the lowest that I have seen on here.
Lex007 is offline   Reply With Quote
 Old 06-01-2016, 07:15 PM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS
2010 black mica speed3
Soon:built motor
KiwiFlavor (06-02-2016), Quigs (06-02-2016), Vansquish (06-01-2016)
 Old 12-30-2016, 08:09 PM   #3
EvoFire's Avatar
Posts: 389   (View Stats)
I'll save you the searching and tell you no.
The Following User Says NO Thank You to EvoFire For This Un-useful Post:
Vansquish (12-30-2016)
 Old 04-24-2018, 04:58 AM   #4
greg08's Avatar
Posts: 480   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 22 Times in 15 Posts
I have 18x8 +38 245/40r18 and its perfect fit. Can easily lower the car if you roll rear fenders a bit
greg08 is offline   Reply With Quote
 Old 04-24-2018, 10:10 AM   #5
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Congratulations on your necro thread revival award! The OP that posted this two years ago can now get on with the installation of his wheels thanks to you! He has been freed from the chains of fender rub!
Seriously......
monkey.bones.007 (04-24-2018)
 Old 04-24-2018, 02:09 PM   #6
greg08's Avatar
Seriously......
Thank you for joining me on this journey. It's been a long road to get to this point, and you have helped me to feel accomplished and you have made me realize I am not alone..
 Old 04-24-2018, 02:26 PM   #7
Groans: 211
I'm here for you man. Soldier on.
The Following 2 Users Say Thank You to Thor Hammer For This Useful Post:
greg08 (04-24-2018), JakeMS3 (04-24-2018)
 Old 04-24-2018, 11:20 AM   #8
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
The Following User Says Thank You to JakeMS3 For This Useful Post:
Thor Hammer (04-24-2018)
The Following User Says NO Thank You to JakeMS3 For This Un-useful Post:
greg08 (04-24-2018)
18x9.5 +20 mike16241 MazdaSpeed 3/6 - Wheels & Tires 17 01-21-2014 11:27 PM
18x9 on a pu Manny 2010 MS3 - Wheels & Tires 3 07-18-2012 05:46 AM
18x9 +45 question specvspeedfreak 2010 MS3 - Wheels & Tires 8 09-25-2011 08:32 PM
MS6 18x9.5 +38 Chriscote MazdaSpeed 3/6 - Wheels & Tires 11 11-15-2010 02:45 AM
18x9.5 +48 fit diepanthony MazdaSpeed 3/6 - Wheels & Tires 12 07-05-2010 01:20 AM
Page generated in 0.28082 seconds with 25 queries
