 Old 09-26-2011, 10:04 AM   #1
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
Default AEM High Output IGBT Inductive "Smart" Coil
I have noticed you have added these gizmos into your mazdaspeed6 section... always looking for some solution to fix the electronics issues in these cars I am intrigued, but in the same section you have the Oakada projects lift system, which i have never heard of anyone using on these cars, not to mention that even if it works(since its universal) that it provides any real benefit? I recall you used to carry HKS twinspark CDI boxes, those I know work on the ms6, but these new products I just dunno...
did you guys actually test these? or is it a generic product you added based on the fact that "it should theoretically work?"
thanks for your reply, I am just trying to see if this is something new, or just a generic car part that has been around forever
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
 Old 09-26-2011, 11:15 AM   #2
none of these coils will work. our coils have built in ignitors which you would need to replicate with another similar coil.
 Old 09-26-2011, 11:48 AM   #3
leo766's Avatar
thanks for clearing that up, i thought so, some of the stuff I see on the MAP site, i don't see being sold anywhere else, and every time I look into it, its usually because its a unresearched generic item, that wouldn't ever work on a ms6
why do they do this? it's only going to get them bad reviews in the end + unhappy customers
 Old 09-26-2011, 12:42 PM   #4
maperformance's Avatar
Posts: 4,979   (View Stats)
Hey guys thanks for the input. I am actually currently trying to re vamp the Mazdaspeed section on our site to try and get some of these generic items out of the section that will not work.
Modern Automotive Performance
Review: 2009 Audi A6 3.0T suits high-speed cruising to a "T" - or is that an "S"? Haltech Automotive News 0 07-01-2009 10:30 AM
Another "read my plugs" and Coil Spring Mod Frequentflyer MazdaSpeed 3 - Engine, Transmission & Driveline 2 12-13-2008 11:16 PM
Page generated in 0.25045 seconds with 22 queries
