Like Tree24Likes
 Old 02-24-2015, 07:54 PM   #121
TORQUERULES's Avatar
Posts: 283   (View Stats)
TORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond repute
The Stage 2 looks like a great upgrade for a DD without having to buy a lot of extra supporting modifications. I wonder how much it would affect an existing tune?
Sent from my Windows Phone
(SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc.
2017 Mazda CX-3 Meteor Gray
TORQUERULES is offline   Reply With Quote
 Old 02-24-2015, 07:58 PM   #122
rolanblack's Avatar
Posts: 2,110   (View Stats)
If your going to upgrade your turbo, its best just to retune it rather than running your previous tune. Might run like shit or not to your expectation.
 Old 02-24-2015, 09:18 PM   #123
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
This is true. Stage 2 (and Stage 1 for that matter) is a minor upgrade from stock, but it does flow a bit more and the compressor map is different. You definitely shouldn't assume that it will operate exactly the same as your stock turbo.
 Old 02-25-2015, 05:59 AM   #124
Thumbs up
I understand. Just kind of thinking of where to go with all of this. Next year may bring a bigger turbo and different tuning if I can swing it. But to be honest, as much as I love power, I want reliability over the long haul too. So while a S3 BNR would be great, I would rather just give up some power and keep supporting costs down with a S2.
I know there are a lot of Hypertech haters on here, but it does work great for a bolt on car. It is just limited on what you can do to yourself (no ability for custom tunes, etc.). I know it is very rich so I was thinking of how I would go about purchasing the mods. Turbo first, then custom tuning with AP, or the reverse, or all together (which is how I am sure I will go).
Just ignore me, my mind is on a thousand different things right now. It has been a crazy year. Lol.
The Following User Says Thank You to TORQUERULES For This Useful Post:
RPM (02-25-2015)
 Old 02-25-2015, 03:06 PM   #125
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
If you upgrade your turbo you will need a proper tune to go with it. Its definitely not optional. So I would strongly advise buying them [AP, tune, and turbo] at the same time.
That said, once you buy an AP, you really don't have anything that would keep you from running an S3 if you wanted. All you would need to do is pick up a couple minor things like a 3 bar MAP sensor and a 3 port EBCS. Further more, you might even want to look in to those parts even if you decided to just stick with the S2.
Just a few things to consider.
TORQUERULES likes this.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 02-25-2015, 03:41 PM   #126
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
If I'm looking at the bnr s1 to replace my about to shit itself k04, there'd be little issues for the tuneage which is the hypertech?
In theory, reflash to stock, replace turbo, reflash tune, and done. That's my brownie logic again.
Are you able to source turbo gaskets, or they included?
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 02-26-2015, 06:28 AM   #127
Sanctioned MSF Peddler
Pat@RPM's Avatar
Posts: 59   (View Stats)
Pat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the world
The S1 is probably the only exception.
I cant say I have ever heard of anyone using a HT tuner with an S1. However I do know that you can use a Cobb OTS map to get you started, so I imagine HT would lead to similar results. I'd still probably look for a custom tune at some point though.
As far as the gaskets go, we can get you whatever you need. We are still working on getting the Mazda OEM stuff listed on the site, but we can work with you directly if you need something before that stuff gets listed. Just shoot us a PM
Pat@RPM is offline   Reply With Quote
 Old 02-26-2015, 03:55 PM   #128
Marcus's Avatar
PM sent and I dont mind being the bnr + ht guinea pig.
Pretty sure all will be will....
**knocks on wood**
 Old 05-19-2015, 10:59 PM   #129
Marcus's Avatar
Still havent ordered it but I did get an email back from Hypertech when I emailed them with the bnr s1 tech info and asked if it'd work.
Got a succinct, 'yep'. Not sure if thats a good thing tho (lol?).
 Old 08-28-2017, 07:22 PM   #130
RPM
RPM's Avatar
Just a quick bump since this remains our most popular selling turbo!
Fastbrakes Wilwood Brake Caliper Upgrade Kits @ therpmstore.com Chimmike Revolution Performance Motorsports 46 02-11-2015 10:08 PM
For all of those with BNR turbos.. numbnuts22715 MazdaSpeed 3/6 - Turbo Induction 66 01-09-2012 10:37 AM
OBX Turbos manofhonor24 MazdaSpeed 3/6 - Turbo Induction 8 06-07-2009 12:16 PM
Page generated in 0.31129 seconds with 25 queries
