Like Tree29Likes
 Old 12-16-2014, 12:35 PM   #41
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
@jgarmo;
 Old 12-16-2014, 02:05 PM   #42
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
Very tempting.... I just got orders to Virginia so Im torn. =[
2012 Mazdaspeed3 Black Mica
 Old 12-18-2014, 03:53 PM   #43
speed3black87's Avatar
Posts: 75   (View Stats)
speed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud of
Groaned at 8 Times in 3 Posts
Can you pleeease put a price together for your homies in Canada? I am in Ottawa Ontario K1T1M8 and would love a price shipped. This deal is sweet and I was about to pull the trigger on an order but wanted it bundled anyways.
John596 likes this.
2012 MAZDASPEED 3 BLACK MICA -COBB SRI - COBB TIP - STEBRO CBE -ULTIMATE RACING CATLESS DOWNPIPE- STREET UNIT TEST PIPE -AUTOTECH INTERNALS - STREET UNIT TMIC - CORKSPORT TRUNK BRACE- STREET UNIT RMM (BROKE) JBR 88A RMM - CPE PASSENGER MOUNT - CPE TRANSMISSION MOUNT -COBB ACCESSPORT -SNOW PERFORMANCE STAGE 2 BOOST METH INJECTION KIT- DAMOND OCC -XXR 531 18X9 HYPER SILVER 235/40/18 GFORCE TIRES- PIRRELI PZERO RACING SLICKS ON OEM RX8 R3 RIMS- KSPORT SPEC AR COILOVERS - TURBO SMART BPV-DENSO ITV22'S
STRATIFIED TUNE BY LEX
speed3black87 is offline   Reply With Quote
 Old 12-18-2014, 04:09 PM   #44
Sanctioned MSF Peddler
Pat@RPM's Avatar
Posts: 59   (View Stats)
Pat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the worldPat@RPM is the leader of the world
We can't really do a "one price fits all" for stuff shipped to Canada. Available options, and cost, vary by location.
To ship to your location however, it would cost ~$158 via USPS Express.
Pat@RPM is offline   Reply With Quote
The Following User Says Thank You to Pat@RPM For This Useful Post:
speed3black87 (12-18-2014)
 Old 12-18-2014, 05:16 PM   #45
That's still a great price. Another question I hope you can answer. Will a corksport turbo inlet fit the BNR or would I need to also upgrade that as well.. I would want to get everything out of the way at once.
The Following User Says Thank You to speed3black87 For This Useful Post:
Pat@RPM (12-18-2014)
 Old 12-18-2014, 05:31 PM   #46
Pat@RPM's Avatar
Im pretty sure the CS TIP is 60mm (2.35 ish inches). So I would think that it should be possible to stretch over the BNR's inlet (2.5"). However, caveat emptor comes into play here. I have never tried it personally, so I cant guarantee it to you. It definitely seems doable though.
All that being said, it's probably a less than ideal situation. If the budget allows, I would make the jump to a one-piece 3" intake system.
 Old 12-18-2014, 05:37 PM   #47
JgamB's Avatar
Posts: 2,566   (View Stats)
The short answer is yes, it will fit. It's a helluva struggle but I've seen it done, and also wrangled the JBR stock sized silicone onto mine. The better answer though is you'll likely run out of MAF volts with too small of an ID, and should go with a 3" or larger.
 Old 12-28-2014, 05:49 PM   #48
Tedspeed6's Avatar
Posts: 1,801   (View Stats)
Tedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the world
That's a sweet ass deal. Looks like I know where some of my tax return $ is goin.
Black Cherry 06 MS6
New factory long block, gt2871r, JBR 3.5" intake and trilogy mounts, autotech internals, M2 DP with eBay cat, magnaflow CBE, vtcs delete IM
Awaiting install Cx piping with tr8 core, Cobb 3 port and JBR OCC
Tedspeed6 is offline   Reply With Quote
 Old 01-02-2015, 07:07 PM   #49
grade247's Avatar
Posts: 58   (View Stats)
grade247 has a spectacular aura aboutgrade247 has a spectacular aura about
Default CAI and TIP
So I recently ordered this from you guys and to my dismay for not doing more research found that I need to replace my crap stock TIP. What are you suggestions I got this as the stock ko4 is burning about 1qt 2-3 days now. I also have a Cobb short ram CAI and was told ill have to replace that as well?
grade247 is offline   Reply With Quote
 Old 01-02-2015, 07:42 PM   #50
Pat@RPM's Avatar
This post worries me.What other mods do you have?
You'll want to have at least and AP, internals, 3" intake (or some way of mating up to the 2.5" inlet on the bnr), and a solid tune.
In addition, an aftermarket EBCS and a 3 bar map sensor with PNP harness is also strongly recommended.
jack_hammer (01-02-2015)
 Old 01-02-2015, 08:28 PM   #51
scubasteve711's Avatar
Posts: 1,238   (View Stats)
Groans: 70
ummm not to drag this off topic any further, but that turbo isnt what's burning that much oil.....
yup... this deal is still killing me... and potentially my wallet
Pat@RPM likes this.
07' Speed6 Velocity Red Mica
Last edited by scubasteve711; 01-02-2015 at 08:28 PM. Reason: MSF Database - Automerged Doublepost
scubasteve711 is offline   Reply With Quote
The Following User Says Thank You to scubasteve711 For This Useful Post:
Pat@RPM (01-02-2015)
 Old 01-02-2015, 08:31 PM   #52
grade247's Avatar
Pat I have all that you mentioned but after a quick bit of research I am going with the htp 3.5 full intake. I have this deal coming from rpm with the fuel internals. I DO have an ap running a 91 map. And yes it IS the turbo I have talked to quite a few other with ko4's worse then that. I could should you pictures of the blow by I'm getting not good at all.
The Following User Says Thank You to grade247 For This Useful Post:
 Old 01-02-2015, 08:36 PM   #53
Pat@RPM's Avatar
Pat I have all that you mentioned but after a quick bit of research I going with the htp 3.5 full intake. I have this deal coming from rpm with the fuel internals. I DO have an ap running a 91 map. And yes it IS the turbo I have talked to quite a few other with ko4's worse then that. I could should you pictures of the blow by I'm getting not good at all.
Great!
But you will want to get in touch with one of the e tuners on here (I recommend freektune since you are so close). An ots map WILL NOT work for the s3.
 Old 01-02-2015, 08:39 PM   #54
grade247's Avatar
Great!
absolutely. I am new to turbo cars but I know this is a massive upgrade that an OTS will not handle. I was thinking him or purple drank
Pat@RPM (01-03-2015)
 Old 01-03-2015, 10:39 AM   #55
Oni
Oni's Avatar
Posts: 565   (View Stats)
How
Many miles on your motor? May still be good to do a compression test to know where you're starting with the new turbo.
@Pat@RPM; I'm coming for you when those W2s come in.
smoogs12 likes this.
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
The Following User Says Thank You to Oni For This Useful Post:
smoogs12 (01-03-2015)
 Old 01-03-2015, 10:53 AM   #56
grade247's Avatar
111k currently. Ill doubble check it but the amount of oil on the turbo - intercooler connection and inside my throttle body is a bit of a sign the seal are more or less non existent. When I start hitting 10psi plus it spews blue clouds and my rear 02 failed. It is parked for now dont need my cat to light on fire
 Old 01-03-2015, 11:12 AM   #57
Pat@RPM's Avatar
Originally Posted by Oni View Post
How
Sounds good, man. Hopefully not long now.
I just went through all the orders and we have something like 18 people in line. Hopefully we can get a few extras from BNR so that we can actually have some on hand for a little while.
@Mandinca; Had a problem very similar to yours. We took a very similar course of action with his car when trying to fix the issue. Replaced the turbo, pcv valve, all that jazz. In the end we just put a new engine in his car lol. I know that probably isn't what you want to hear.
 Old 01-03-2015, 12:28 PM   #58
grade247's Avatar
God no if that is the case I may dump the car. Not doing a 3k motor swap
 Old 01-03-2015, 12:57 PM   #59
Oni
Oni's Avatar
Not doubting the turbo is bad. But at 111k miles, it's good to know that's not all that's bad. Like mentioned above.
 Old 01-03-2015, 01:33 PM   #60
grade247's Avatar
True ill deff check it out! Hopefully it checks out
 Old 01-03-2015, 05:13 PM   #61
IlleztImportz's Avatar
Posts: 169   (View Stats)
IlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond repute
How come the past few weeks when I tried to order, I get the error that the code doesn't meet the requirements?
IlleztImportz is offline   Reply With Quote
 Old 01-03-2015, 05:23 PM   #62
Pat@RPM's Avatar
Can you grab me a screen shot of your cart?
 Old 01-03-2015, 07:18 PM   #63
I typed and even copy and pasted
 Old 01-03-2015, 07:22 PM   #64
Pat@RPM's Avatar
Because you don't have all the items in the cart.
You need to add everything that I listed in the OP.
IlleztImportz (01-03-2015)
 Old 01-03-2015, 07:27 PM   #65
oopsy daisy. thank you haha
 Old 01-05-2015, 01:26 PM   #66
El Beaner's Avatar
Posts: 4,262   (View Stats)
Damnit, now you guys are making it hard to decide between going FMIC or spending the extra ~$300 and getting this instead
If I were to buy this and ship to another state could I avoid the taxes lol?
Might be worth getting with an OK Nator member and having it all sent there and picking it up to save on that roughly $100 in taxes.
SOLD 2012 LSM Tech - 11/17/17
The Following User Says Thank You to El Beaner For This Useful Post:
Pat@RPM (01-05-2015)
 Old 01-05-2015, 02:05 PM   #67
Pat@RPM's Avatar
As long as the shipping address isn't in Texas you wont be charged tax.
***Disclaimer*** I am not an authority on tax law. All I am saying is that the site will not calculate tax if the shipping address is outside of Texas.
El Beaner (01-05-2015)
 Old 01-06-2015, 07:24 AM   #68
grade247's Avatar
Pat I was curious if you know anything about my motor mounts? My order # is 138292. The bnr I know is on backorder. The rest has been sent out. I havnt seen anything on the two shipping invoices I have received about the mounts.
 Old 01-06-2015, 07:31 AM   #69
Pat@RPM's Avatar
As far as I know, all of the orders that were placed in December still have yet to ship.
Donny @RPM; any news from bnr?
 Old 01-06-2015, 08:21 AM   #70
grade247's Avatar
I havnt yet BUT my hpfp map sensor and pnp harness and my cobb ebcs should arrive today via fed ex. Only reason why I was curious about the motor mounts. No big rush on anything planned on doing one big tear down so cant do anything till the bnr ships anyways.
 Old 01-06-2015, 08:54 AM   #71
Pat@RPM's Avatar
Whoops. Sorry. I just quickly skimmed your post and thought you were talking about a turbo order.
I not sure but im guessing your mounts were drop shipped .
Edit: reading>me today. Trying to do too many things.
 Old 01-06-2015, 02:09 PM   #72
grade247's Avatar
No worries pat. In just received most of my order! All I need now is the RMM and the bnr s3 cant wait to put this all in!
 Old 01-06-2015, 08:42 PM   #73
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Your RMM is on the way. Sent you tracking.
BNR said yesterday that turbos are supposed to start shipping this week. I didn't talk to him today. I'll have to give him a call tomorrow.
 Old 01-06-2015, 09:05 PM   #74
RicksSpeed3's Avatar
Posts: 46   (View Stats)
RicksSpeed3 will become famous soon enoughRicksSpeed3 will become famous soon enough
Gosh what a great deal, sooo wish I could get it��
RicksSpeed3 is offline   Reply With Quote
 Old 01-06-2015, 09:16 PM   #75
grade247's Avatar
Yup received the tracking numbers no rush pat I can wait for a quality part from bnr
 Old 01-10-2015, 07:12 AM   #76
Pat@RPM's Avatar
Turbos have started shipping! Ten orders have gone out this week and more to come starting Monday. Thank you to everyone for being so patient!
It's not certain at this point if we will have any extras in stock and ready to ship after the current back order is cleared. We will have a better idea in a week or two.
 Old 01-10-2015, 05:59 PM   #77
season_of_ages's Avatar
Posts: 290   (View Stats)
season_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond repute
So this will of course go on thru tax season, right?
season_of_ages is offline   Reply With Quote
The Following User Says Thank You to season_of_ages For This Useful Post:
juxt3r (01-10-2015)
 Old 01-11-2015, 08:53 AM   #78
Pat@RPM's Avatar
You know it
ItsNox (01-12-2015)
 Old 01-11-2015, 08:59 AM   #79
74te27's Avatar
Posts: 36   (View Stats)
74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all
Yes!
09 White Mazdaspeed 3 Koni Yellow/Eibach pro kit
74te27 is offline   Reply With Quote
 Old 01-28-2015, 11:49 AM   #80
@RPM; or @Pat@RPM; , I've emailed a couple times about shipment info for my bnrs3. Could someone look into it please, thanks.
-Peter C.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/bnr-s3-upgrade-bundle-therpmstore-com-181344/
Tipp für größere MPS-Anschaffungen 2014 This thread Refback 12-12-2014 12:55 PM
ACCESSPORT + AUTOTECH BUNDLE @ therpmstore.com smoogs12 Revolution Performance Motorsports 49 12-12-2019 10:51 AM
BNR S3 Turbos @ therpmstore.com smoogs12 Revolution Performance Motorsports 129 08-28-2017 07:22 PM
therpmstore.com review ImGryssLOL Revolution Performance Motorsports 3 03-16-2015 11:25 AM
Fastbrakes Wilwood Brake Caliper Upgrade Kits @ therpmstore.com Chimmike Revolution Performance Motorsports 46 02-11-2015 10:08 PM
Page generated in 0.62047 seconds with 35 queries
