Like Tree48Likes
 Old 04-08-2014, 10:14 AM   #81
- POD -'s Avatar
Posts: 619   (View Stats)
- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world
For just GC? or GC+KONI?
Oops, sorry, full fit. Koni + GC.
- POD - is offline   Reply With Quote
 Old 04-08-2014, 10:22 AM   #82
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Got it. Since we're on to the next page, I'm going to repost this in case someone missed it:
We had to add $40 to each of the full kits, but they now include:
  • Ground Control bump stops
  • Perches cut by Ground Control
  • KONI shocks rebound pre-set to match springs
  • Full warranty on all parts through Ground Control, including modified KONIs
Technically, we can still honor the old pricing if you don't want any of the above, but we believe that all of the above is easily worth $40. Heck, just the bump stops would cost you that much!
The original post has been updated. We just need a few more to reach the 20+ pricing and we still have 2 weeks left! Getting to 40+ is probably a bit of a stretch, but I figured I'd go ahead and include it anyways, just in case. It would be a nice surprise!
 Old 04-08-2014, 10:40 AM   #83
RPM
RPM's Avatar
Originally Posted by - POD - View Post
You guys are seriously killing my wallet....
What would shipping be to Edmonton Alberta?
You'd be looking at anywhere from $92 to $118 (not including duties/taxes) via FedEx International. The rate would vary based upon the service requested and the day it was shipped. I can get a more accurate quote when we get closer, but this should give you a good idea of what to expect.
 Old 04-08-2014, 10:45 AM   #84
- POD -'s Avatar
Ouch. That hurts.
Thanks for the quote, I'll have to ponder this.
 Old 04-08-2014, 10:50 AM   #85
RPM
RPM's Avatar
Ouch. That hurts.
Yeah, it's a little pricey because it's 42 lbs.
- POD - (04-08-2014)
 Old 04-08-2014, 02:50 PM   #86
Elvisrosales88's Avatar
Posts: 113   (View Stats)
Elvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the world
Groaned at 9 Times in 2 Posts
@rmp; can you give us a bit more information on the available spring rates.
I'm looking for set up that would not be too unpleasant (relative, I know) to drive on a daily basis, but can still can corner well through canyon roads.
will GC and Koni yellows provide this?
Cobb AP+ Stratified OTS--JBR Powerpath Stage III intake-- Turbosmart BPV--AutoTech Fuel Pump Internals--CPE TMIC-- OBX test pipe+ UR catback--ITV-22 plugs-- H&R springs--CPE RMM- JBR PMM and TMM--
Elvisrosales88 is offline   Reply With Quote
 Old 04-08-2014, 03:56 PM   #87
RPM
RPM's Avatar
The range of spring rates that GC offers is 450-650 lb/in in the front and 500-800 lb/in in the rear. When you order on our site, it will ask several questions that will help GC determine the best spring rates for your needs. If you you choose "Daily Driver" and "Aggressive" ride feel, they'll probably get you exactly what you're looking for.
smoogs12 (04-08-2014), [R]usty (04-08-2014)
 Old 04-08-2014, 04:06 PM   #88
I'm in..
GC+ koni 100%
The Following 2 Users Say Thank You to Elvisrosales88 For This Useful Post:
 Old 04-08-2014, 06:07 PM   #89
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
interesting
07 MS3
The original Genpoo Hater
 Old 04-08-2014, 10:46 PM   #90
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
Can you use Corksport camber plates with this kit?
Would assembly go spring--> upper spring perch --> bearing --> camber plate
Also can you reuse the stock dust boots? Or is it not necessary to reuse them?
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
The Following User Says Thank You to gmoney542 For This Useful Post:
jtday (04-08-2014)
 Old 04-08-2014, 10:59 PM   #91
RPM
RPM's Avatar
If the KONIs are compatible with the Corksport camber plates, then this kit would be, as well.
The dust covers attach to the stock bump stops. These will be replaced by the GC bump stops, which I do not believe will work with the stock dust cover. That said, it is not necessary to reuse them.
The Following 3 Users Say Thank You to RPM For This Useful Post:
gmoney542 (04-09-2014), jtday (04-08-2014), smoogs12 (04-09-2014)
 Old 04-08-2014, 11:15 PM   #92
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
KONI shocks rebound pre-set to match springs <<<< I would pay over $40 just to have this one thing. Good job.
Update your OP to include this.
The Following 5 Users Say Thank You to specvspeedfreak For This Useful Post:
Chimmike (04-09-2014), jack_hammer (04-09-2014), jtday (04-08-2014), SLOWHATCH (04-27-2014), smoogs12 (04-09-2014)
 Old 04-08-2014, 11:17 PM   #93
jtday's Avatar
Posts: 650   (View Stats)
I came here to ask the same question. After looking at pics of both, I believe you are correct in your assumption. It looks like the inner circle on the bottom of the plate would be inserted into the bearing/upper perch for assembly. That's one of the huge selling points for me. A few of other popular offerings require use of the shitty stock plastic bushing (bearing) which is turning me off.
2009 MS3 GT
 Old 04-08-2014, 11:30 PM   #94
RPM
RPM's Avatar
Done.
 Old 04-09-2014, 10:05 AM   #95
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
What bearings or bushings have you guys been replacing during install?
Are you reusing OEM top hats or ordering new ones?
GC + Koni 100%
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
The Following 6 Users Say Thank You to Adog35 For This Useful Post:
Chimmike (04-10-2014), Elvisrosales88 (04-09-2014), jtday (04-09-2014), nybe0010 (04-09-2014), RPM (04-09-2014), smoogs12 (04-09-2014)
 Old 04-09-2014, 01:29 PM   #96
Raider's Ohio Bottom Bitch
therza2169's Avatar
Posts: 204   (View Stats)
therza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the world
Same questions here. I was also wondering what else I will need for the install. I already planned on getting camber arms for the rear, but I wasn't sure about the need for new endlinks, or anything else.
therza2169 is offline   Reply With Quote
 Old 04-09-2014, 05:31 PM   #97
Adog35's Avatar
End links are you to you....
You don't technically need anything for the install.
I am speaking more from a maintenance standpoint
with 44k on some OEM components.
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
 Old 04-09-2014, 06:12 PM   #98
jtday's Avatar
GC + Koni 100%
No need for bushing replacement with this kit. It comes with its own. Idk about end links. I'd direct your questions to @Bap; 's thread to keep this one uncluttered.
2009 MS3 GT
 Old 04-09-2014, 06:36 PM   #99
gmoney542's Avatar
So after searching forever I haven't been able to find anyone running CS camber plates with KONIs. It's hard to find threads of people actually using them though, opposed to people just asking if they need them.
I did find that people have used them on stock struts, Bilsteins, and many different coilovers. I can't imagine why the KONIs would be the one option that's incompatible with CS camber plates... so I'm just going to assume they'll work.
This looks like a totally awesome setup. Quality parts, made in America. I'm in.
GC+KONI 100%
The Following 2 Users Say Thank You to gmoney542 For This Useful Post:
 Old 04-09-2014, 09:21 PM   #100
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
Do we need front strut mounts?
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
 Old 04-10-2014, 04:15 AM   #101
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
GC+KONI 100%
A lot of people don't want to cut the strut towers, my self being included. Without cutting out the clearance hole the amount of camber the plates are capable of is very minimal (same goes for the KMAC plates).It's my understanding that the CS camber plates are made as a direct replacement for the OEM top hats. If something works with the OEM top hats it should work with the CS.
Also, since they can provide a kit that will fit without cutting the perches. GC 100%
The Following 2 Users Say Thank You to daafisch For This Useful Post:
gmoney542 (04-10-2014), smoogs12 (04-10-2014)
 Old 04-10-2014, 05:11 AM   #102
hatchedspeed3's Avatar
Posts: 1,966   (View Stats)
Count me out on this GB, wont do me any good with a fucked motor.....
2009 CWP MS3 1-23-2014
The Following 2 Users Say Thank You to hatchedspeed3 For This Useful Post:
Chimmike (04-10-2014), smoogs12 (04-10-2014)
 Old 04-10-2014, 07:52 AM   #103
Bap
Bap's Avatar
Posts: 248   (View Stats)
Bap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the world
if you look at the springs on the left they are for the front and it shows the included upper spring mount / bearing that goes on to the top hat for the strut assembly. But it mounts to the top hat in exactly the same way as oem. for compatibility to corksport camber plates I am not sure if the koni's are an issue or not.
Bap is offline   Reply With Quote
The Following 4 Users Say Thank You to Bap For This Useful Post:
Chimmike (04-10-2014), daafisch (04-10-2014), gmoney542 (04-10-2014), smoogs12 (04-10-2014)
 Old 04-10-2014, 02:44 PM   #104
gmoney542's Avatar
What if we had something like @dale_gribble; spacers for the MS3? GI for Dale Gribble (DG) 1/2" MS6 front spacers
From what I understand, without cutting the strut tower the center nut doesn't have enough room to fully adjust because it is above the clearance hole. You put the spacer between the camber plate and strut tower. You would increase ride height, but it could move the center nut down below the clearance hole and allow you full adjustment. The plate would also have to be designed so that the center nut and bearing doesn't just hit the plate.
 Old 04-11-2014, 11:47 AM   #105
- POD -'s Avatar
Hey RPM, would you have any issue taking payment from Canada and shipping this to my parents house in Washington State? If so, what am I looking at for shipping in that case for the Koni + GC?
Thanks guys!
 Old 04-11-2014, 11:49 AM   #106
RPM
RPM's Avatar
Thanks guys!
No problem at all. Shipping in the continental US is free.
smoogs12 (04-11-2014), [R]usty (04-11-2014)
 Old 04-11-2014, 11:51 AM   #107
- POD -'s Avatar
Damn that was fast, great customer service as always!
Ok, I'll take a look at the fiances at the end of the month. I'll know by the 28th if I can swing this.
Thanks again!
The Following User Says Thank You to - POD - For This Useful Post:
 Old 04-13-2014, 10:50 AM   #108
[R]usty's Avatar
Posts: 2,204   (View Stats)
Alright sold my OTS koni yellows. Put me down for Koni's +GC.
2010 Mazdaspeed3 w/tech
The Following 2 Users Say Thank You to [R]usty For This Useful Post:
Chimmike (04-13-2014), smoogs12 (04-13-2014)
 Old 04-14-2014, 03:42 PM   #109
RPM
RPM's Avatar
One more person until we're at the 20+ pricing, which is awesome! That's just $394.95 for GC only and $899.95 for GC+KONI!
That's right.. A set of quality height/rebound adjustable coilovers from highly-regarded manufacturers for under $900!
The Following 4 Users Say Thank You to RPM For This Useful Post:
802MS3 (04-15-2014), Chimmike (04-14-2014), easy (04-15-2014), jack_hammer (04-14-2014)
 Old 04-14-2014, 04:36 PM   #110
Mattyhawk1's Avatar
Posts: 739   (View Stats)
I think I'm missing something. How does the lower sleeve lock to the shock body?
 Old 04-14-2014, 04:43 PM   #111
jtday's Avatar
It just slides over the top and sits there which is just fine. 900 for these is kickass.
2009 MS3 GT
The Following User Says Thank You to jtday For This Useful Post:
RPM (04-14-2014)
 Old 04-14-2014, 06:02 PM   #112
Mattyhawk1's Avatar
Thanks for the response, but another question, do these sleeves have tight tolerance to the koni body (ie is there no noticeable movement in the sleeve to the shock body)?
 Old 04-14-2014, 07:15 PM   #113
jtday's Avatar
You could probably twist it if you really wanted to, but the spring force will keep it from moving excessively. Don't worry about the sleeve design, it works without flaw.
2009 MS3 GT
Mattyhawk1 (04-15-2014)
 Old 04-14-2014, 08:05 PM   #114
Hal
Hal's Avatar
Posts: 233   (View Stats)
Hal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the world
Can we get a military discount on top of the awesome GB price?
If so, make me #20 . GC+Koni
www.emeraldtuning.com
twittter: @emeraldtuning
YouTube: https://www.youtube.com/user/EmeraldTuning
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Heavy Shift Knob
JBR Flaps
Buddy Club Custom 3" Exhaust
Koni Yellows
Corksport 4-Piston Brake Upgrade
Corksport Springs
Corksport Adjustable End Links
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
Hal is offline   Reply With Quote
 Old 04-14-2014, 08:23 PM   #115
Hal
Hal's Avatar
Screw it, im in.
lets get this party started!
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Flaps
Koni Yellows
Corksport Springs
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
The Following 4 Users Say Thank You to Hal For This Useful Post:
covelife1016 (04-14-2014), RPM (04-14-2014), smoogs12 (04-15-2014), [R]usty (04-14-2014)
 Old 04-14-2014, 08:36 PM   #116
Canuck's Avatar
Posts: 6   (View Stats)
Canuck is just really niceCanuck is just really niceCanuck is just really niceCanuck is just really nice
I'm 80% in for the GC+Koni combo.
Canuck.
Canuck is offline   Reply With Quote
The Following 3 Users Say Thank You to Canuck For This Useful Post:
 Old 04-14-2014, 08:49 PM   #117
[R]usty's Avatar
Any discount if we get to 30? Maybe another $10 off. Just throwing it out there.
 Old 04-14-2014, 10:50 PM   #118
If I wasn't satisfied with my bilstein/swifts, I would be getting these. What a great deal.
 Old 04-14-2014, 11:31 PM   #119
RPM
RPM's Avatar
Sorry, man. No other discount can be used with this deal!
I wish we could, but there's not another quantity break for us until 40.
Last edited by RPM; 04-14-2014 at 11:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-15-2014, 07:05 AM   #120
Hal
Hal's Avatar
So how do we order? I have money burning a hole in my credit card.
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Flaps
Koni Yellows
Corksport Springs
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.58529 seconds with 37 queries
