> Cobb Tuning >
Cobb ATR Support
 Old 04-20-2009, 02:28 PM   #1
Default Access Tuner Helpfile
See below for the PDF helpfile
The Following 5 Users Say Thank You to Haltech For This Useful Post:
DaleNixon (06-17-2009), dougefresh_ (06-17-2010), evidence (04-20-2009), FreeFlyFreak (04-20-2009), OMGWTFHAX (12-04-2009)
 Old 10-04-2009, 10:24 AM   #2
evidence's Avatar
Posts: 1,033   (View Stats)
1.07 is the newest currently
Some things.
The Following 5 Users Say Thank You to evidence For This Useful Post:
dougefresh_ (06-17-2010), Lincoln (01-23-2010), meeker13 (04-28-2010), mike8748 (04-16-2010), OMGWTFHAX (12-04-2009)
 Old 06-15-2010, 05:20 PM   #3
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Just an FYI regarding the Helpfile... Under "Boost Dynamics" Boost Error is defined incorrectly imo. Here is what the Helpfile says regarding the Boost Dynamics Table:
Boost Dynamics
Table Description - The Boost Dynamics table is used as a feedback control system to correct for errors in the desired Boost Target versus the Actual Boost measured in the inlet manifold. The feedback control method used is known as a Proportional-Integral controller.
Boost Error = (Desired Boost Target) - (Actual Boost)
This table represents a compensation (correction) necessary to counteract the Boost error that has occurred. The table is referenced by Boost Error (represented in mm Hg) on the x-axis. Table values are the percentage change made to the Wastegate Duty Cycle value. Tuning Tips - This table can be used to refine boost control characteristics for under and over boost conditions.
It should read: Boost Error = (Actual Boost) - (Desired Boost Target)
Here's a screen shot of the Boost Dynamics Table:
A quick example will make this clear. Say I'm over-boosting and my target PSI is 18, but I'm hitting 21. According to the HELPFILE:
Boost Error = Desired Boost (18 PSI) - Actual Boost (21) = -3 for Boost Error. Now look back at the table in ATR. For a -3 Boost Error, the Boost Dynamics Table is calling for an INCREASE in wgdc of 5% (+.05). Increasing the wgdc will increase boost.... you def don't want that when you're already over-boosting!
Now look at the same example w/ my (and others) definition
Boost Error = Actual Boost (21 PSI) - Desired Boost Target (18) = +3 Boost Error.
Looking back at the table in ATR, this makes a lot more sense. With a boost error of +3, the Boost Dynamics table is calling for a 10% DECREASE (-.10) in wgdc, which will lower boost, which is what you want here.
I know this is old news for most, but some may find this confusing as I did when I first came upon it. In a nutshell, when you're over-boosting, wdgc should be decreased and vice-versa. I'm pretty sure the table is set up correctly, but the definition of Boost Error is 'backwards' as I explained.
 Old 06-24-2010, 06:34 PM   #4
evidence's Avatar
1.09 came out with the load cap fix ATR
Some things.
The Following User Says Thank You to evidence For This Useful Post:
hnda etr (07-21-2010)
 Old 06-24-2010, 10:23 PM   #5
Also, ignore my post #3. What I said was correct, but I emailed Christian about it, and the helpfile has been corrected w/ the new release of ATR yesterday .
Cobb Access Port....Canadian! MPS MazdaSpeed 3/6 - ECU Computer Tuning 4 10-13-2008 03:57 PM
Cobb Access Port on Mazdaspeed6 bova
Cobb Access Port/Maps
8 09-24-2008 02:15 PM
Chrysler's new tech suite includes Web access Haltech Automotive News 0 06-26-2008 01:21 PM
Logitech Access USB Keyboard 600 $19.97 Haltech Hot Deals Section 0 03-28-2008 11:00 AM
Page generated in 0.27202 seconds with 23 queries
