![]() Join Date: Mar 2012 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,256
(Thread Starter) | Not Ranked : 0 score I just got a new laptop over the weekend, and it has Windows 8 on it. While I am not completely sold on Windows 8 yet, I figure I would give it a chance. But, I cannot for the life of me get ATR to install. It won't see the AP. I installed AP Manager first and it installed the drivers, and everything works. But, when I close out of AP manager and start the install of ATR the AP disconnects from the computer and the ATR installer doesn't try to reinstall the drivers and it won't continue the install process. Has anybody had any luck getting ATR to install on Windows 8? If so how? Thank you
__________________ 2011 Speed 3 - Mica Black - Non Tech Mods Installed: JBR SSR Level 2 with Big Knob/ JBR Motor Mounts / Cobb AP / Cobb TIP + SRI / GFB BPV / CS Race Pipe / Autotech Internals / Denso IVT-22 / JBR Throttle Body Gasket & Bypass / JBR EGR Block Off / JBR TIG / JBR RSB / GA Apperance: DDM 6000k HID / JBR Mud Flaps / Windows Tinted Tuning with Boost_Creep in Progress! Working towards Corn. |
| The Following User Says Thank You to superskaterxes For This Useful Post: | jdub0802 (11-30-2012) |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
Groaned at 52 Times in 48 Posts
| Not Ranked : 0 score Subbing. I upgraded to Windows 8 on my tablet that i use to tune and now my ap won't connect. |
![]() Join Date: Nov 2011 Location: Clarksville, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,001
| Not Ranked : 0 score Same here, I believe it is just a driver issue for the AP. Sent from StalknTalk
__________________ 2013 CWP That's slow ![]() 2012 LSM Totaled by an asshole red light runner Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )Previous: MILTUNED E85 K04 |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,851
Groans: 58
| Not Ranked : 0 score Same here as well. Probably just a driver issue because as I understand it Win 8 isn't THAT much different from Win 7 underneath. |
Groans: 58
| Not Ranked : 0 score Just found this on Cobb's forums. I'll give it a shot when I get home around 1. https://forums.cobbtuning.com/forums...-x64-AP-Driver |
| The Following 2 Users Say Thank You to daafisch For This Useful Post: | dantes5823 (11-30-2012), Mase (11-30-2012) |
I am thinking that Cobb needs to update the Driver Install package in the ATR Install app the same way that they did for the AP Manager Install app.
__________________ 2011 Speed 3 - Mica Black - Non Tech Mods Installed: JBR SSR Level 2 with Big Knob/ JBR Motor Mounts / Cobb AP / Cobb TIP + SRI / GFB BPV / CS Race Pipe / Autotech Internals / Denso IVT-22 / JBR Throttle Body Gasket & Bypass / JBR EGR Block Off / JBR TIG / JBR RSB / GA Apperance: DDM 6000k HID / JBR Mud Flaps / Windows Tinted Tuning with Boost_Creep in Progress! Working towards Corn. | |
Groans: 58
| Not Ranked : 0 score So you're saying ATR works as long as APM is open? Good enough fix for me until Cobb releases a new version. |
(Thread Starter) | Not Ranked : 0 score No, even if APM is open ATR still won't see the AP as plugged in. I think what is happening is that the ATR installer is over writing the drivers that are installed by APM. Cause after you try to install ATR you have to go back and reinstall APM to get the drivers to work again.
Groans: 58
Don't see why not. | |
| Not Ranked : 0 score so wait, does this mean we can potentially use ATR on a tablet running Win8?
| The Following User Says Thank You to superskaterxes For This Useful Post: | Downmented (12-03-2012) |
| Not Ranked : 0 score FWIW- I upgrade installed win8pro over win7, not as a new install. -this was prior to any Cobb released win8 drivers being pushed, beta or otherwise -both APM & ATR worked on first click with no changes -the beta release of APM including the signed win8 driver installed & worked perfect AFAIK, neither apm or atr will work on Win8 RT I have an Asus Slate (Asus Eee Slate EP121) and touch as an interface is working well, selecting multiple cells & such is easy and works well. Also in Excel for logs.
| The Following 2 Users Say Thank You to TiGraySpeed6 For This Useful Post: | Pointless (11-30-2012), superskaterxes (11-30-2012) |
can you post some screen shots? i would LOVE to see this in action haha btw would a tablet be able to recognize a serial device with a USB>DB9 adapter?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| Not Ranked : 0 score Would you be bummed if I said it looks exactly the same as it does on Win7 cause, well, it does... ![]() Mostly I like how easy it is to use in the car compared to a normal laptop, and the Dashboard functionality of ATR is total WIN. Enough so that I sold the DH Edit to add- I'll start a new post on it with some screen shots such over the weekend. I've been meaning to do that just cause of the slate -vs- laptop thing.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | superskaterxes (11-30-2012) |
| Not Ranked : 0 score I'm gonna give this driver thing a shot. Then go street tune my car lol. |
| The Following User Says Thank You to dantes5823 For This Useful Post: | superskaterxes (11-30-2012) |
![]() Join Date: May 2011 Location: MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score I got it working with Access Port Manager 2.0.2.3 and Access Tuner Race 2442. I had to disable code signing for device drivers. If you remember when installing on Windows 7, Windows can't verify the publisher of this driver software and you had to click install this driver software anyways. Try at your own discretion: To get that prompt in Windows 8, I had to run these commands from an administrative command prompt (on the start screen type cmd, right click on it, and at the bottom of the screen select Run as administrator): BCDEDIT /Set LoadOptions DDISABLE_INTEGRITY_CHECKS BCDEDIT /Set TESTSIGNING ON I also ran gpedit.msc (can type from start screen) and navigated to User Configuration | Administrative Templates | System | Driver Installation | Double click on "Code signing for device drivers" and set it to Disabled. Then I restarted my PC and was able to install Access Port manager and Access Race Tuner.
__________________ 2011 black MS3 - Mods: Yes |
| The Following 8 Users Say Thank You to metallemur For This Useful Post: | alphasaur (11-30-2012), daafisch (11-30-2012), dantes5823 (11-30-2012), doubleflusher (11-30-2012), jdub0802 (11-30-2012), rfinkle2 (12-03-2012), superskaterxes (11-30-2012), TiGraySpeed6 (11-30-2012) |
Here are the directions to temporarily disable the signed driver check. To get started: From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon). Click ‘More PC Settings’. Click ‘General’. Scroll down, and click ‘Restart now’ under ‘Advanced startup’. Wait a bit. Click ‘Troubleshoot’. Click ‘Advanced Options’ Click ‘Windows Startup Settings’ Click Restart. Profit! When your computer restarts, select ‘Disable driver signature enforcement‘ from the list. (number 7) You can now load your modified driver. Once you have done this you can click on the installer for ATR and it will proceed just like it did in Windows 7. A pop up box will ask you if you trust the driver and such, you will click install anyways. ATR will install just as planned. Now restart you computer and everything should work. I now have ATR and APM working and my AP connecting to my laptop. Thank you all for your help and ideas!
| The Following 2 Users Say Thank You to jdub0802 For This Useful Post: | daafisch (12-03-2012), TiGraySpeed6 (11-30-2012) |
| Not Ranked : 0 score well ap connects now and i can use apm. Atr has been working since i upgraded and not clean installed it. Time to charge this bad boy and hit the streets. |
| The Following User Says Thank You to dantes5823 For This Useful Post: | TiGraySpeed6 (11-30-2012) |
| Master of Hard Parts ![]() Join Date: Sep 2011
Rep Power: 734 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 79
Groaned at 8 Times in 2 Posts
| Not Ranked : 0 score So, from what I've been told, the current "solution" is to update APM to "Beta". This should allow you to connect the AP via ATR. You'll need to have APM and ATR open together. Let me know if this fixes it.
__________________ Hard Parts Engineer - Mazda Expert Group 2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD! 2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car |
| The Following User Says Thank You to Evan@COBB For This Useful Post: | rfinkle2 (12-03-2012) |
| Not Ranked : 0 score With the Beta APM installed I'm able to use ATR in the car with full connectivity to the AP- dashboard gauges & logging, without APM open. I've attached the only shot I've got just for giggles, I left it full res so you can see the APM icon at the bottom is not active, and the green connection box. My car is going in today to see about getting the TC/VVT done before I cross 70K, so won't be able to get good screenshots of the working system till I get it back...
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | rfinkle2 (12-03-2012) |
| Not Ranked : 0 score what tablet is that?
| Not Ranked : 0 score That's the Asus Eee Slate EP121
![]() Join Date: Feb 2012 Location: Minneapolis, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 343
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score I tried all the steps listed here and I still wasn't able to install ATR. I found this alternate method to install on the Cobb forums. Reinstall the AP Manager and verify the AP can connect to it. Next, download 7zip and install it. Right click the ATR installer and open it with 7zip. Extract the license.ini and tunerRaceXXX.exe. Create a directory C:\Program Files (x86)\AccessPORT\AccessTUNER Race Put the license.ini file in C:\Program Files (x86)\AccessPORT\AccessTUNER Race. Right click the tunerRaceXXXX.exe and open it with 7zip. Extract the contents to a temporary directory. Put the files not in any subdirectory in to C:\Program Files (x86)\AccessPORT\AccessTUNER Race. Open the docs directory in the temp folder. Move the DLL files and DOCS directory in that docs directory to C:\Program Files (x86)\AccessPORT\AccessTUNER Race; Open the plugins directory in the temp directory. You will find another plugins directory. Move it to C:\Program Files (x86)\AccessPORT\AccessTUNER Race. Open the XML directory in the temp directory. You will find another XML directory. Move it to C:\Program Files (x86)\AccessPORT\AccessTUNER Race. Create a shortcut on your desktop to the tunerRaceXX.exe file in C:\Program Files (x86)\AccessPORT\AccessTUNER Race. After doing all that I was able to run ATR normally. |
| The Following User Says Thank You to Amnesiac For This Useful Post: | TiGraySpeed6 (01-01-2013) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score so you essentially just extracted the program files to the needed locations and voila- instant ATR? Handy. I had wondered if it wrote any files to the registry, but suspected not since it won't associate with PTM files, or open them without license errors.
![]() | | #25 | ![]() |
![]() Join Date: May 2010 Location: Goldsboro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score That is weird. I just bought my laptop with windows8 and I didn't have any problems. I hope you guys get it figured out!! |
| Official: Fisker Q&A sheds light, lots of light, on Karma problems, lots of Karma problems | Haltech | Automotive News | 0 | 08-23-2012 02:50 PM |
| Help with problems from '10 MS3 | yz007 | 2010 MS3 - Troubleshoot/Diagnostics | 14 | 05-23-2012 06:20 PM |
| Problems Problems | RUMBLEFISH | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 03-25-2012 02:12 PM |
| Problems with AC | trdsw | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 07-03-2011 10:49 AM |
| Few problems need help MS6 | KoleDeRacer | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 01-03-2010 10:26 PM |
