> Cobb Tuning >
Cobb ATR Support
  • 1 Post By MS6 Alan
 Old 04-24-2009, 08:53 AM   #1
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Default MS3 Closed Loop Tables
A couple of months ago Christian had me experiment with some Closed Loop table changes to see how the car responds. After making the changes, it felt like my car became more eager to go fast. Here are the changes for anyone that wants to try them.
Closed Loop - Exit Delay A
Code:
15
Closed Loop - Exit Delay B
Code:
40
Closed Loop - Exit Delay C
Code:
40
Closed Loop - Max Load D
Code:
2.00    2.00    2.00    1.20    1.55    1.57    1.57    1.40    1.40    0.40    0.33    0.00    0.00    0.00
Closed Loop - Max Throttle B
Code:
75.00    75.00    75.00    75.00    60.00    60.00    60.00    60.00    60.00    60.00    60.00    60.00    60.00    60.00
Closed Loop - Max Throttle C
Code:
Closed Loop - Max Throttle D
Code:
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
Last edited by SLS MS3; 05-05-2009 at 10:58 PM. Reason: changed to standard code formatting for easy cut/paste
SLS MS3 is offline   Reply With Quote
The Following 9 Users Say Thank You to SLS MS3 For This Useful Post:
acidbbg (01-25-2011), Broxer (03-15-2011), evidence (04-24-2009), Fobio (04-24-2009), kgb (04-26-2009), LBV (04-24-2009), mike8748 (06-15-2009), SPEEDRAC3R (06-07-2011), thatsmrgimp2u (05-09-2011)
 Old 04-24-2009, 09:01 AM   #2
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
On that Max Load D table, are you sure the 2000 rpm # is 1.20? Just doesn't look like it fits .. Thx
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 04-24-2009, 09:10 AM   #3
SLS MS3's Avatar
I'm positive. That's the actual the stock value and the changes start at 2500 rpm. Guess I should edit out 1500 and 2000 since no changes are made at those points.
 Old 04-24-2009, 09:12 AM   #4
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
speed6 guys better be careful looking at speed3 guys stuff cause its not going to be the same.
The Following 2 Users Say Thank You to bova For This Useful Post:
dougefresh_ (03-30-2010), SLS MS3 (04-24-2009)
 Old 04-24-2009, 09:20 AM   #5
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
1.20 @ 2000rpm is same as stock/default... looks fine
btw I found a cool "trick" when you're changing a bunch of values like this that are the same. manually edit (E), the first and last number to 60 (in this case), then select all cells and push (H) for horizontal interpolation, and it will apply a value of 60 to all of them quick and easy.
 Old 04-24-2009, 09:47 AM   #6
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
so basically you are letting the ecu stay in closed loop at higher loads.
What does the 15 stand for in exit delay? I know you cut the values in half but does that mean the ecu switches to open loop earlier? If so that is the opposite of what the other tables seem to be doing. My closed loop throttle tables are all maxed out, which probably means they are not being used. You say the car was more responsive, but were there any things you didn't like? Do you still run that map?
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline   Reply With Quote
 Old 04-24-2009, 10:06 AM   #7
SLS MS3's Avatar
You can do the same thing vertically as well. Just select the top and bottom value and push (V). Interpolation isn't just for making values the same, it's great for smoothing out transitions also. If you select the first and last value then interpolate, the middle values will automatically be recalculated to even increments between the high and low value.
My understanding is that the exact opposite is happening, it's forcing the ECU to open loop sooner. Those load values are for when closed loop switches off. I think the exit delay is for how long the conditions need to be met before the ECU switches to open loop operation.
There was nothing I really didn't like about the change, but it took some adjusting to the way the car drives. I'm still running with these changes and have been for about 3 months.
The Following 4 Users Say Thank You to SLS MS3 For This Useful Post:
aaronc7 (04-24-2009), dread (04-24-2009), jahman (04-24-2009), Speed3eak (01-25-2011)
 Old 04-24-2009, 10:12 PM   #8
evidence's Avatar
Posts: 1,033   (View Stats)
Awesome.. thx for this. Gunna try it out in a bit.
BTW in Closed Loop - Max Load D the 5000 and 5500 values are stock and the same as the Cobb maps also.
One other trick to changing multiple values is just holding the left mouse button down to select a couple, and you can hit e and change em all quick like.
Some things.
 Old 04-26-2009, 12:57 AM   #9
itzl0l's Avatar
Posts: 462   (View Stats)
itzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond repute
i've been driving with these changes all night....makes a very nice diff. The car feels more eager to go, but not in a jerky throttle way like some maps have. Half throttle to 3/4 throttle acceleration feels much better. On WOT it takes less time for the AFR's to get out of the 13's and into the safe zone.
07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107
TOTALED 11/2/09
04 SRT4 - sold - trapped 120+
itzl0l is offline   Reply With Quote
The Following User Says Thank You to itzl0l For This Useful Post:
Fobio (04-26-2009)
 Old 04-26-2009, 06:38 AM   #10
dread's Avatar
did you did this in combo with aaron's throttle adjustment?
 Old 04-26-2009, 07:01 AM   #11
aaronc7's Avatar
Groans: 370
i did and i agree it feels good. I like how AFRs drop quickly when going into WOT also
Fobio (04-26-2009)
 Old 04-26-2009, 07:18 AM   #12
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
Yes.
+1
-- Mario Andretti --
 Old 04-27-2009, 09:50 AM   #13
dread's Avatar
I made this change last night and I honostly don't notice a difference. If anything I like it better in stock configuration. The car doesn't really feel any peppier to me. Its definately not a night and day difference like the throttle change.
 Old 04-28-2009, 12:12 PM   #14
itzl0l's Avatar
yea the biggest thing is the throttle fix. This fixonly made a little bit of difference in driving, but under WOT the afr's get down into the safe zone much quicker.
TOTALED 11/2/09
 Old 04-28-2009, 11:17 AM   #15
fostersafb's Avatar
Posts: 38   (View Stats)
fostersafb has a spectacular aura aboutfostersafb has a spectacular aura aboutfostersafb has a spectacular aura about
Should max throttle stay at 75% under 2500 rpms or do all of the max throttle values need to be changed to 60% to run this change?
fostersafb is offline   Reply With Quote
 Old 04-30-2009, 02:20 PM   #16
jahman's Avatar
Posts: 903   (View Stats)
jahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the world
Groaned at 9 Times in 7 Posts
I noticed zero difference, open loop doesnt even seem to happen earlier on my car...dunno.
And the linear throttle thing is not for me, way too smooth, way too boring, way too toyotaish. I love the hard hitting power of the "jerky" maps. Guess I'm different...
07 Mazdaspeed3
jahman is offline   Reply With Quote
 Old 05-05-2009, 11:19 PM   #17
SLS MS3's Avatar
Last Friday at the local dragstrip, I worked with MS6 Alan to figure out which tables to change on Speed6's. He was very pleased with the changes and we'll make a seperate post for anyone that wants to try them out.
The Following User Says Thank You to SLS MS3 For This Useful Post:
MS6 Alan (05-07-2009)
 Old 05-07-2009, 05:07 PM   #18
MS6 Alan's Avatar
Posts: 453   (View Stats)
MS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the world
Here are the changes we made to my MS6 map at the track last week. The stock tables and values are different for the MS6, some of the table names are different too, but we figured all that out. It definitely changed the way the car drives, and its for the better, IMO. I've been running it for a few hundred miles now, seems to smooth my 2-3 stutter a bit more.
2006 US Federal Mazdaspeed6
Exit Delay A
Code:
15
Exit Delay B
Code:
40
Exit Delay C
Code:
40
Closed Loop - Max Load C
Code:
2.00	2.00	2.00	1.20	1.55	1.57	1.57	1.40	1.30	0.40	0.33	0.00	0.00	0.00
Code:
Code:
Closed Loop - Max Throttle E
Code:
event likes this.
'06 Mazdaspeed6 GT - Titanium Gray
- ATP 3076r - CP-e XCel Intake - CP-e FMIC - CP-e 4" TIP - COBB AccessPORT - Medieval EWG Manifold - Tial 44mm EWG - ATP Downpipe - Custom 3" Dual Magnaflow CBE - JBR EGR Block Off - HKS SSQV BPV - mrlilguyCDFP (KMDv1) - Denso ITV-22 Plugs - F2 BSD & Baffle - CP-e Upper Rear Diff Mount - TurbineTech Forward Rear Diff Mount - TurbineTech Front Motor Mount - AWR Rear Motor Mount - Tanabe Strut Tower Brace - Technafit SS Clutch Line - RPM Sport Springs .75/1.1 - TWM Stage 2 SS w/bushings - COBB Shift Weight - Défi-Link BF Boost Gauge - Innovate LC-1 Wideband - Hardwired Passport 8500 X50 - AuxMod Basic for CarPC -
MS6 Alan is offline   Reply With Quote
The Following 2 Users Say Thank You to MS6 Alan For This Useful Post:
Docnox (12-12-2010), kyzomo (08-19-2011)
 Old 05-07-2009, 07:43 PM   #19
LBV
LBV's Avatar
So you made Closed Loop changes at the track? Aren't you going WOT at the track? That's open loop. Just clarifying.
 Old 05-11-2009, 07:59 PM   #20
evidence's Avatar
Neutral  +1 score
Actually the ms3 and probably the ms6 is just about the same stays in CL until 4500+ RPMs at WOT under normal circumstances. If you bump the load down in those closed loop tables it lets WOT load pass over that threshold and you should then be OL from 2500+ RPMs. Lets your AFRs come down earlier, and theoretically make more power if all goes well.
Some things.
 Old 05-30-2009, 02:26 PM   #21
anubis-mzd6's Avatar
Posts: 7   (View Stats)
anubis-mzd6 is an unknown quantity at this point
Is there any way someone that is making changes to Speed6 CL tables to start a new thread. I'm in Iraq and I'm trying to understand all this before I get home sometime next month. I would like to get the PT knock fixed while i am home and I dont want to input changes for the Speed3.
anubis-mzd6 is offline   Reply With Quote
 Old 05-30-2009, 02:55 PM   #22
SLS MS3's Avatar
Sure, I'll make a separate thread
http://www.mazdaspeedforum.org/forum/foru...p-changes.html
 Old 06-23-2009, 06:48 PM   #23
dkswim's Avatar
Posts: 175   (View Stats)
dkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud ofdkswim has much to be proud of
going to do this tonight. any reason this would not work with any stage from stage 1 all the way up to stage2+++
dkswim is offline   Reply With Quote
 Old 06-25-2009, 08:16 AM   #24
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
no
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
 Old 06-28-2009, 10:24 AM   #25
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
So, does everyone agree that making these adjustments makes the car run quicker AND safer?
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 06-29-2009, 02:50 PM   #26
evidence's Avatar
Well, you have to wonder why Mazda set things up to stay in closed in all but the more extreme situations. Was this for safety and emissions? Did they then add the sharp jerk in the throttle tables to combat the high AFRs that are produced in closed loop at high throttle before 4500k?
My feeling is at the sacrifice of tight control/safety (which we don't seem to like anyway) and maybe a little bit of gas mileage the early and often open loop changes here are for the best.
Some things.
The Following User Says Thank You to evidence For This Useful Post:
DaleNixon (06-29-2009)
 Old 06-29-2009, 02:59 PM   #27
DaleNixon's Avatar
Groans: 91
When I said "safety", I meant safety for the engine, not the occupants I'm sure you knew what I meant.
I'm assuming doing this is theoretically safer for the motor because it drops the AFR's quicker when you're getting on it.
 Old 03-15-2011, 11:38 AM   #28
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Made this change using the Genpu ATR beta and holy cow it made a HUGE difference!
Increased the fun driving factor by atleast 10.
I'll get some logs after work.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following User Says Thank You to Broxer For This Useful Post:
R.MS3 (03-18-2011)
 Old 04-17-2011, 12:23 PM   #29
SPEEDRAC3R's Avatar
Posts: 399   (View Stats)
SPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the world
sub for reference...
2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint
SPEEDRAC3R is offline   Reply With Quote
 Old 05-09-2011, 10:06 AM   #30
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Did this the other night, subtle but noticeable I know what you mean when you say more "eager".
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f418/closed-loop-tables-26373/
AP Maps - Which one? This thread Refback 11-20-2012 11:26 AM
How ECUs Use Closed-Loop Controls to Make Fueling Corrections v1.02 94jedi MazdaSpeed 3/6 - ECU Computer Tuning 22 05-13-2014 08:45 PM
open and closed loop Doc MazdaSpeed 3/6 - ECU Computer Tuning 4 11-14-2008 03:04 PM
Closed and open loop booya620 MazdaSpeed 3/6 - ECU Computer Tuning 39 09-23-2008 03:06 PM
Open/Closed Loop Transition, Some New Observations superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 1 07-18-2008 11:35 AM
Trunk Storage Tables (Set of 2) - $174.99 Haltech Hot Deals Section 0 03-28-2008 03:30 PM
Page generated in 0.49584 seconds with 37 queries
