> Cobb Tuning >
Cobb ATR Support
 Old 03-25-2013, 07:16 AM   #1
lpugfan2004's Avatar
Posts: 771   (View Stats)
lpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the worldlpugfan2004 is the leader of the world
Default AP unable to do datalog
I am able to download new maps, install them and run them just fine through ATR. But when I try to data log (everything from the car seems to go fine) and go home to plug it up. The log either doesn't exist or does exist but will not transfer and continues to fail the transfer every time.
Any advice?
2012 Velocity Red Mazdaspeed3
- CP-E Stage 1 RMM - Autotech HPFP Internals - COBB AP v3 - Corksport 3inch Intake - Corksport Turbo - Corksport BPV -
- JBR Shift Plate & Shift Weight - JBR Solid Bushings - cp-e Catted TBE - NGK 1 step colder plugs - COBB 3 Port EBCS -
- ETS TMIC - Michelin Pilot Super Sport 235/40-18 - JBR OCC Stage 2 - JBR EGR Delete - CorkSport Boost Tubes -
- JBR IM and TB gaskets w/ coolant bypass - Damond Motosports PMM - Corksport PMM Bushing Insert -
Tune in progress
lpugfan2004 is offline   Reply With Quote
 Old 03-25-2013, 07:27 AM   #2
DTKII's Avatar
Posts: 247   (View Stats)
DTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the world
In access manager there should be a little box above your maps click on that and choose data logs. That may be your problem.
Stay away from RD Motorsportz
DTKII is offline   Reply With Quote
 Old 03-25-2013, 07:31 AM   #3
Thanks for the reply, but I am aware of the drop down for the datalogs. As previously mentioned sometimes the logs show on the list but then fail to export to my pc and most of the time the datalog won't even show on the list.
Tune in progress
The Following User Says Thank You to lpugfan2004 For This Useful Post:
DTKII (03-25-2013)
 Old 03-25-2013, 07:54 AM   #4
chuckms6's Avatar
Posts: 1,618   (View Stats)
chuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the world
When you take the log do you still have numbers on the screen or is it just lines with a grey not logging icon in the corner?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's
SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's)
chuckms6 is offline   Reply With Quote
 Old 03-25-2013, 07:56 AM   #5
Open the data logging option, gives me the warning screen to hit OK to start and cancel or ok to end logging. Hit ok and it opens the live data list and after a few seconds it defaults to the first available parameter. It then says "Logging"
Tune in progress
 Old 03-25-2013, 08:05 AM   #6
chuckms6's Avatar
...you are not logging unless you press the center button while viewing the parameter. The screen should say"not logging"at the point you get to.
 Old 03-25-2013, 08:17 AM   #7
I fail. I still had trouble transferring logs. When I get home I will re attempt.
Thanks for the help.
Sent from my Galaxy Nexus using magic.
Tune in progress
Anyone else unable to clear a CEL w/ AP? Boatcop1 2010 MS3 - Troubleshoot/Diagnostics 14 01-09-2013 11:17 AM
AccessPORT unable to update Shooter445 Cobb Tuning 9 07-02-2012 02:36 PM
Study: AAA says one in four Americans unable to afford major car repair Haltech Automotive News 0 08-04-2011 02:10 PM
Report: Lotus unable to secure local government money Haltech Automotive News 0 04-14-2011 06:20 PM
Page generated in 0.28973 seconds with 22 queries
