> Cobb Tuning >
Cobb ATR Support
 Old 04-20-2010, 05:17 PM   #1
08Anamoly's Avatar
Posts: 151   (View Stats)
08Anamoly has much to be proud of08Anamoly has much to be proud of08Anamoly has much to be proud of08Anamoly has much to be proud of08Anamoly has much to be proud of08Anamoly has much to be proud of08Anamoly has much to be proud of08Anamoly has much to be proud of08Anamoly has much to be proud of
Default Highest attainable boost in 1st?
So, based on engine load capabilities, whats the highest anyone is getting in 1st gear for boost? I'm not worried about torque steer since I have a somewhat smooth ramp up and the car really rocks and rolls. I'm getting about 13-14 max (holding in 1st) to 5000 rpm.
What are you getting?
(Mods: intake/inlet/tp)
08.5 MGM Mazdaspeed3 Sport
- VQ37VHR Conversion
- RWD Conversion
- Custom 2.5" X-Pipe
- Weldina Catback
Motordyne A.R.T. pipes coming shortly
08Anamoly is offline   Reply With Quote
 Old 04-20-2010, 05:19 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
52psi if i recall correctly
aaronc7 (04-20-2010)
 Old 04-20-2010, 05:20 PM   #3
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
how do u hold boost in such a short gear. it should wind out in one second
The Following User Says Thank You to For This Useful Post:
FreeFlyFreak (04-20-2010)
 Old 04-20-2010, 05:25 PM   #4
felt's Avatar
Posts: 1,504   (View Stats)
felt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the world
Groans: 1,364
Groaned at 589 Times in 386 Posts
Lol, this is a trick question right?
1st and 2nd and 3rd gear are very short gears.
felt is offline   Reply With Quote
 Old 04-20-2010, 05:32 PM   #5
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I cant get enough traction to hold boost, plus trying to keep the car going straight I cant read the gauge, plus if I log it, first gear is over in like 0.5 seconds as it wheel spins to 7000 rpm.
I say the question is bullshit.
Better question, what have you reduced your load to in first gear using ATR to give you maximum acceleration and minimum wheel spin, would need tire type and width also.
Suspension:
The Following 3 Users Say Thank You to FreeFlyFreak For This Useful Post:
Blackspeed (04-21-2010), Dano (04-20-2010), flyrevs2 (04-20-2010)
 Old 04-20-2010, 05:33 PM   #6
Stockturbo_Ms3's Avatar
Posts: 120   (View Stats)
Stockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to behold
^^good question. id like to know aswell.
cpe sri, cpe tip, cpe fmic, cpe catted dp, cp-e towplate, deso 2 step colder plugs,cp-e rmm(75) cobb ap atr
Stockturbo_Ms3 is offline   Reply With Quote
 Old 04-20-2010, 07:27 PM   #7
Qtip's Avatar
Posts: 410   (View Stats)
Qtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond repute
1st gear takes 1.14 seconds to run out at 13psi. I find anything more than stock boost (11psi??)and you just spin.
Qtip is offline   Reply With Quote
 Old 04-20-2010, 07:37 PM   #8
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
weld your wastegate shut.
AFcadet is offline   Reply With Quote
 Old 04-20-2010, 07:58 PM   #9
OP avatar fail
 Old 04-20-2010, 08:02 PM   #10
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
With the standback you can see 20psi no prob. of course just for and instant before your spinning you tires.
 Old 04-20-2010, 08:22 PM   #11
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
if your not running drag slicks, what is the point of upping boost in 1st and second ??
both of these are nothing but spin city even at stock boost levels if you have just a few mods
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline   Reply With Quote
The Following User Says Thank You to flyrevs2 For This Useful Post:
 Old 04-20-2010, 09:41 PM   #12
phillyb's Avatar
Groans: 1,940
this thread is also a mind fuck
 Old 04-20-2010, 10:05 PM   #13
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Exactly!
I run TRL in the .30-.40 range for 1st = 8PSI [throttle closes to achieve lower than spring pressure boost]
Then TRL in the .50-.80 range for 2nd = 12PSI
very little spin in 2nd but still get plenty in first
 Old 04-21-2010, 05:58 AM   #14
08Anamoly's Avatar
I thought it would be an interesting question, not a trick one, but just a fun one to ask. I do hold boost in 1st, but only for a second and a half max. Fun responses!
- RWD Conversion
- Weldina Catback
 Old 04-21-2010, 09:11 PM   #15
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Exactly!
Can you post a pic of your gear tables?
 Old 04-21-2010, 09:48 PM   #16
Trail of Fail
Dano's Avatar
i'll get them up here tomorrow.
 Old 04-21-2010, 10:04 PM   #17
Trail of Fail
Dano's Avatar
k here they are...1st had higher values than I thought but the PSI is correct.
1 important note: I have a negetavie scaled MAF to combat the load cap per my thread so the exact numbers will not work for everyone.
ECU Load cap shattered!
1st
Code:
0.60	0.67	0.74	0.81	0.84	0.87	0.80	0.80	0.75	0.75	0.75	0.85	0.85	0.94	0.92
2nd
Code:
0.60	0.67	0.74	0.81	0.84	0.87	0.94	0.96	0.96	0.96	0.98	0.98	0.96	0.94	0.92
3rd
Code:
0.76	0.88	1.02	1.18	1.25	1.32	1.47	1.60	1.69	1.75	1.83	1.90	1.88	1.63	1.45
4th
Code:
0.72	0.84	0.97	1.12	1.19	1.25	1.43	1.54	1.54	1.56	1.65	1.74	1.76	1.55	1.38
5th
Code:
0.69	0.75	0.83	0.99	1.06	1.14	1.25	1.35	1.43	1.47	1.52	1.58	1.56	1.48	1.35
Highest redline? Mizzle MazdaSpeed 3 - Engine, Transmission & Driveline 57 04-12-2010 08:51 PM
highest psi with standback and meth? gsrtype1 MazdaSpeed 3/6 - ECU Computer Tuning 24 01-24-2009 04:43 PM
Cheap, stylish ride: Oxymoron or attainable dream? Haltech Automotive News 1 08-26-2008 05:22 PM
Page generated in 0.35348 seconds with 31 queries
