![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
(Thread Starter) | Not Ranked : 0 score I managed to successfully backrev the firmware on my AP this morning from 1.4.0.1-11124 to 1.4.0.0-10793. This may be useful for those experiencing problems with FFS running lean after the shift. Here's the method I used, but this is all at your own risk. If you brick your AP, don't come crying to me. 1. Make sure you DON'T have internet connectivity. You have to do this in offline mode with AP Updater. 2. If you look in C:\Program Files\AccessPORT\AccessPORT Updater\AP-MAZ-002, you'll see all of the firmware versions you've ever installed on your AP using your computer. Hopefully you'll have a copy of 1.4.0.0-10793, or whatever version you choose to use. Delete (or .old) the contents of the AP-MAZ-002 folder, EXCEPT for the folder containing the firmware load you choose to use. Copy the version.txt file from the firmware load folder to the AP-MAZ-002 folder. Your AP-MAZ-002 folder should now contain just the 1.4.0.0-10793 firmware folder and the version.txt file from the 1.4.0.0-10793 folder. 3. Launch AP Updater, click okay to offline mode, and click the Update button. It should proceed like normal, but will install what it thinks is the most recent version of firmware, which is indicated by the version.txt file in the AP-MAZ-002 folder, and references the actual firmware load folder located within the AP-MAZ-002 folder. I can't be certain, but I suspect that this method might even possibly let you update any AP with firmware for another platform, allowing you to convert a Subaru AP to an MS3 AP, etc. Not sure about that, but it's a theory. Again, if you brick your AP, don't complain to me. |
| The Following 5 Users Say Thank You to KoukiS14 For This Useful Post: | djuosnteisn (10-07-2009), FreeFlyFreak (10-08-2009), jayspeed3 (10-08-2009), kgb (10-10-2009), ponny135 (10-29-2009) |
![]() Join Date: Sep 2008 Location: California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
| Not Ranked : 0 score has anyone else done this, and OP how has this worked for you?? Any problems or what not???
__________________ 08.5 MS3 ![]() Cobb AP-ATR tune; AEM CAI; COBB TIP; Test Pipe; PG piping/GS FMIC; AT Internals; HKS SSQV; Denso ITV22s; SURE counter weight; Cobb RSB; Swift spec R springs; Koni Sports; SU RMM, shifter bushings; Hankook Ventus V12 EVO 2 Team Beachbody Coach, Contact me to get started GF2revolution.com |
(Thread Starter) | Not Ranked : 0 score No problems with the firmware downgrade at all. It's only partially (85%) fixed the post shift lean condition with FFS though. Last edited by KoukiS14; 10-10-2009 at 08:10 AM. |
![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 300
| Not Ranked : 0 score should be stickied
__________________ ![]() 07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107 TOTALED 11/2/09 ![]() 04 SRT4 - sold - trapped 120+ |
![]() Join Date: Dec 2008 Location: Cincinnati
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 658
Groans: 60
__________________ Performance Mods: Cobb AP, e48 Tune (22psi), Cobb SF w/ Amsoil Filter, RPMC TIP, Synapse Synchronic BOV, Custom FMIC w/ Godspeed Type C, CP-e DP, Custom CBE, KMD v2 CDFP Internals, Denso ITV-22, MattD OCC, Castrol Edge 5w30, XT-M5-QS Gear Oil, SU RMM, Cobb STS, Cobb Stage2 Suspension Kit, Bilstein HD, RX-8 Wheels, Toyo Proxes 4 Plus (235/40/18) |
(Thread Starter) | Not Ranked : 0 score As far as an FFS lean fix, in the end, increasing the MAF curve by 2 to 4 percent from 3 volts up is the best solution. It worked better than the old firmware alone, and the fix persists across new firmware versions. Last edited by KoukiS14; 10-12-2009 at 06:52 PM. Reason: typos |
| The Following User Says Thank You to KoukiS14 For This Useful Post: | djuosnteisn (10-13-2009) |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score This does not work with AP Manager 2xxx :'(
__________________ Versatune :: FMIC :: 3" SRI :: 3" TIP :: HKS SSQv4 :: 3" Turboback :: Devil's Own WMI Stg2 kit :: Autotech HPFP :: JBR EGR delete :: JBR BSD & Baffle plate :: Racing Logic coilovers :: TRZ TMM :: AWR PMM :: Poly bushes all round :: SURE RMM :: SURE Shortcut&Counter weight :: SURE g/knob :: PG PCV fix :: Aeroforce dual Interceptor gauges :: Apexi TT :: HDI Stg2 Evo boost controller :: VIBE ICE |
| New Cobb Firmware | wolverine81 | Cobb Access Port/Maps | 131 | 04-20-2009 08:55 PM |
| Latest Cobb AP firmware... | 94jedi | Cobb Access Port/Maps | 0 | 02-24-2009 08:30 PM |
| New Cobb Firmware | tagkat | Cobb Access Port/Maps | 52 | 02-14-2009 06:20 PM |
| 1.2.8 FIRMWARE UPDATE FOR MAC OX | boost_me | Cobb Access Port/Maps | 8 | 08-25-2008 06:03 PM |
| AccessPORT Firmware Update for the MS3 is Available. | Christian. | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 05-27-2008 08:22 PM |
