> Cobb Tuning >
Cobb ATR Support
 Old 05-30-2009, 02:59 PM   #1
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Default MS6 Closed Loop changes
Per request, here's a separate thread for MS6's.
Exit Delay A
Code:
15
Exit Delay B
Code:
40
Exit Delay C
Code:
40
Closed Loop - Max Load C
Code:
2.00    2.00    2.00    1.20    1.55    1.57    1.57    1.40    1.30    0.40    0.33    0.00    0.00    0.00
Closed Loop - Max Throttle B
Code:
75.00    75.00    75.00    75.00    60.00    60.00    60.00    60.00    60.00    60.00    60.00    60.00    60.00    60.00
Closed Loop - Max Throttle C
Code:
Closed Loop - Max Throttle E
Code:
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 05-30-2009, 04:10 PM   #2
anubis-mzd6's Avatar
Posts: 7   (View Stats)
anubis-mzd6 is an unknown quantity at this point
Thank you very much. Sorry if this caused any difficulties but I did not want to get this mixed up with the MS3 guy's tuning. Thanks
anubis-mzd6 is offline   Reply With Quote
 Old 05-30-2009, 04:14 PM   #3
SLS MS3's Avatar
No trouble. I'll have some more MS6 specific stuff soon.
 Old 05-30-2009, 04:15 PM   #4
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
I think you should post the FYCN map!
 Old 05-30-2009, 05:10 PM   #5
How many Speed6's have fixed their PT knk?
 Old 05-30-2009, 07:06 PM   #6
SLS MS3's Avatar
Lol! I won't make that publically available until at least version 5.
 Old 06-01-2009, 09:08 AM   #7
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
FYCN?
btw, good job on helping the MS6 guys too!
-- Mario Andretti --
 Old 06-01-2009, 04:39 PM   #8
MS6 Alan's Avatar
Posts: 453   (View Stats)
MS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the world
Wheres the link to the original?
I guess I'll have to thank myself for posting that one!
MS6 Alan is offline   Reply With Quote
 Old 06-01-2009, 06:29 PM   #9
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i basically fixed mine, but i'm still testing it out. i just changed the low load portion of all 4 timing tables in the 2000-3000 rpm range where there was a hump. reason for doing all 4 is that after watching my dashhawk a while back i noticed when on the highway if you just blip the throttle or anytime you first get on the throttle it goes to open loop then back to closed, so if you don't change all 4 then you'll have some different timing problems in those areas.
The Following User Says Thank You to bova For This Useful Post:
MS6 Alan (06-03-2009)
Closed Loop Tables SLS MS3
Cobb ATR Support
29 05-09-2011 10:06 AM
Closed Loop, Open Loop FreeFlyFreak
Cobb ATR Support
8 05-19-2009 11:28 PM
open and closed loop Doc MazdaSpeed 3/6 - ECU Computer Tuning 4 11-14-2008 03:04 PM
Closed and open loop booya620 MazdaSpeed 3/6 - ECU Computer Tuning 39 09-23-2008 03:06 PM
Open/Closed Loop Transition, Some New Observations superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 1 07-18-2008 11:35 AM
Page generated in 0.32628 seconds with 25 queries
