> Cobb Tuning >
Cobb ATR Support
Like Tree4Likes
  • 4 Post By ms3blackmica
 Old 03-11-2015, 01:56 PM   #1
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Default MS6 Shift Stutter Fix - How To w/Cobb Tuning AccessTuner
As most of you may know, @Cobb Tuning; has recently released access to some BETA tables in AccessTuner build 1.9.1.0-9908 (Build Date March 3, 2015).
Of these tables, there is one in particular which relates to a Shift Timer based on actual Engine RPM and the Currently Driven Gear.
You can find access to this table by opening the "Beta Tables" Folder ---> "Shift Timer".
*Notice I
These tables are BETA for a reason. Although the MS6 vehicles have the same ROM between the years, variations in the operating system between various production dates can exist. This means that what has worked for me, might not work for you, and in that case you must alter the table data accordingly. MS6's have a different shift logic algorithm than the MS3 vehicles.
*Notice II
Do not edit this table if your MS6 vehicle does not experience any sort of post shift stutter unless you have fully tested the effects of your changes to ensure a better shift experience/response.
"If it ain't broke, don't fix it."
Below is a snapshot of this table in OEM form with stock data.
I have been doing quite a bit of BETA testing on this table in every way possible on a select few MS6 vehicles that I have access to. One of these test vehicles is plagued by the "MS6 Shift Stutter" while the other has no issue at all.
The Shift Timer is exactly as it's name suggests, a timer. This timer is a down counter or "delay" to which normal engine operation will be resumed. Based on my experience through testing and analyzing the data, I believe these values to be in units of milliseconds (ms).
Reducing the amount of time that the timer is allowed to count reduces the severity of the stutter. Increasing the amount of time that the timer is allowed to count results in an even greater delay between gear changes yielding a very undesirable driving experience.
I was able to create a severe stutter on an MS6 vehicle that had no issues at all by increasing the timer units significantly.
After testing multiple vehicles, I have found that the table structure below is best suited for entirely removing the "Shift Stutter". I would not set the entire table to 0 especially in the lower RPM range unless you have confirmed that ill effects or unwanted response between low RPM gear changes do not occur.
If you want to better understand how the timer affects the shift logic, set the table to 60 or 80 units all the way to 7000 RPM in every gear and you will discover a very massive (not harmful) stutter in between gear changes.
This will help you better understand how the timer affects engine operation during a shift event.
www.tunedbynishan.com
The Following 28 Users Say Thank You to ms3blackmica For This Useful Post:
09TrueRedGTX (03-11-2015), aaronc7 (03-11-2015), Agent_Orange (03-11-2015), ArcticSpeed3 (03-11-2015), ASHMS3 (03-11-2015), dale_gribble (03-12-2015), Dano (03-11-2015), fivefingerdeathpunch (03-11-2015), Funkster777 (03-11-2015), g00s3y (03-12-2015), ItsNox (04-27-2015), Justin@Freektune (03-11-2015), KCi (03-12-2015), Mauro_Penguin (03-11-2015), Mazdazilla6 (03-12-2015), meicalnissyen (12-20-2016), Micha (03-15-2015), mrmonk7663 (03-11-2015), ms6mil (03-11-2015), qkrthnu2 (03-14-2015), Raider (03-11-2015), Rich990 (03-11-2015), SarcasticOne (03-11-2015), snailD (03-11-2015), speed23 (03-15-2015), TiGraySpeed6 (03-11-2015), udntknw (03-11-2015), Vansquish (03-11-2015)
 Old 03-11-2015, 02:02 PM   #2
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
Thanks Nishan, and thanks Cobb!
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 03-11-2015, 02:08 PM   #3
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Nice work sir.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 03-11-2015, 02:09 PM   #4
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
Very awesome!
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
 Old 03-11-2015, 02:30 PM   #5
El Beaner's Avatar
Posts: 4,262   (View Stats)
@texas_wizard I think this was the isue for the stutter you had during our runs.
SOLD 2012 LSM Tech - 11/17/17
 Old 03-11-2015, 03:13 PM   #6
Good writeup on this. What I find quite interesting is that as you mentioned some cars experience this and some don't. Most Gen1 MS3s don't and the tables in the ROMs available from COBB have the same values.
It looks like other areas of the tune (such as the fuelling and timing) during shifting as well as modifications and driving style can exacerbate the condition or make it less noticeable.
 Old 03-15-2015, 12:36 PM   #7
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
@f15ms6;
The Following User Says Thank You to Dizzy Turbo For This Useful Post:
f15ms6 (03-15-2015)
 Old 03-15-2015, 12:44 PM   #8
f15ms6's Avatar
Posts: 1,546   (View Stats)
f15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the world
Originally Posted by Dizzy Turbo View Post
Thanks for the heads up, I am using the ots stage 1 right now, so I am going to pay attention to this numbers once I start tuning
2006 MS6 GT - Titanium Silver - #05750 -Cobb AP V2 - AT HPFP - 3" JBR Full Intake-
FidanzdaFlywheel - AWR Trilogy - Techna-Fit Brakes & Clutch SSL - Turbo XS Test Pipe - Maganaflow Catback
99 Civic Dx 5spd - DD/Backup Car
f15ms6 is offline   Reply With Quote
 Old 04-27-2015, 11:38 AM   #9
ItsNox's Avatar
Posts: 3,076   (View Stats)
OH MY GOD THANK YOU @ms3blackmica; & @Cobb Tuning;
Sent via Tapafail
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 04-27-2015, 06:36 PM   #10
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
nice to see Cobb still actively working on this program. Hadn't seen an update(non beta) in a year so I figured it was not being developed anymore.
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
 Old 04-27-2015, 06:37 PM   #11
udntknw's Avatar
This was the last, for a long while.
**Old Motor**
**New Motor**
The Following User Says Thank You to udntknw For This Useful Post:
Micha (05-09-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f418/mazdaspeed-6-shift-stutter-fix-how-w-185571/
Cobb Accessport/Accesstuner Update - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-07-2015 06:38 AM
Shift stutter fix for 6mps for ATR This thread Pingback 03-11-2015 02:28 PM
COBB Tuning AccessTUNER Race Tuning Software for ADM Mazda3 and Mazda6 MPS and More Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 7 07-01-2012 12:42 PM
COBB Tuning AccessTUNER Race Tuning Software for ADM Mazda3 and Mazda6 MPS and More Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 06-20-2012 04:46 PM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning 2010 MS3 - ECU Computer Tuning 111 07-18-2011 10:46 AM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 18 07-07-2011 05:22 PM
COBB Tuning AccessPORT and AccessTUNER BETA Updates for MAZDASPEED3 and MAZDASPEED6 Cobb Tuning Cobb Tuning 0 06-30-2011 03:32 PM
Page generated in 0.34115 seconds with 29 queries
