![]() Join Date: Oct 2009
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Feb 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score Logic would say start with a basemap as close to your spec as possible and use it as a jumping point. Each car (even with the same mods) will run different and may require different degrees of tuning. If you want to do it right, load a basemap that's close, and take it directly to a tuner and have it dialed in. You'll be happy with the results leaving it in the hands of an expert.
__________________ [SIGPIC][/SIGPIC] |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Thats a decent maps to start with. You may have to "detune" the v106sf103+tmic abit to accomodate the blow off valve and catless downpipe. I am guessing that your gonna need to reduce the load targets a bit (for the catless) and maybe reduce WGDC to reduce boost spike (for the bov) |
(Thread Starter) | Not Ranked : 0 score ya i used that map and it runs scary lean. anyone have any further advice or a map with similar mods? |
![]() Join Date: Aug 2008 Location: Red Deer, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,362
| Not Ranked : 0 score i'm working on Stage2 +SF 91 v106 right now with roughly the same mods as you (minus TMIC). if your car is reacting similar to mine (21psi and 13:1 at WOT) i would suggest adding fuel (target 10:1) drop your load down to 1.4ish and drop the WCDC by 10%. this should get you roughly into a "safe" area to start tuning back up. i also use 94 octane on a 91 map, and i havent seen any knock yet. *i am not a tuning expert in any way/shape/form. i have been using ATR for 2 weeks, and i am doing so at my own risk. if you follow my suggestions you are doing so at your own risk. its your responsibity to know what your doing and not blow up your car*
__________________ |
| GM to tap South Africa for H3 export base | Haltech | Automotive News | 0 | 05-25-2009 09:40 PM |
| What should I use as my base map | GQ_WhiteMS3 | Cobb ATR Support | 32 | 05-16-2009 05:25 PM |
| My Solution for Bad Base Bose | pdqgp | MazdaSpeed 3/6 - Car Audio & Electronics | 13 | 09-01-2008 09:20 PM |
