| Banned ![]() Join Date: Jan 2016 Location: Fultondale, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Neutral : -1 score Corksport has not said anything about warranties yet but I guess we will see! Everything else I've purchased from them has been great but my turbo charger shop said this turbo can't be ran for very long in the mid to high 2.0 bar range Time to start my build thread for a 200sxe big turbo swap |
| The Following 7 Users Say Thank You to Xtrinsic1337 For This Useful Post: | Code Monkey (06-17-2016), Easter Bunny (06-23-2016), InkedInspector (06-17-2016), MD1032 (07-14-2016), mxlplx71 (06-17-2016), Neverlift (06-17-2016), [R]usty (06-17-2016) |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score That's too bad. Do you track at all?
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score That sucks man. You should come up to Huntsville for a meet sometime. I'll make a thread soon, but probably next Sunday.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| The Following User Says Thank You to nindoja For This Useful Post: | MD1032 (07-18-2016) |
(Thread Starter) | Not Ranked : 0 score I don't track her too much I'm a top speed junky. Vdyno had me at around 415 HP and 450 FT lb's of torque on the aggressive tune running 100% e85. Changed my Timing curve to drop my torque load and high boost at around 5K and eventually made a safe 375hp 350 ft lb's on smoothing 3.0 scaling. This was also a 50/50 e85 gas setup Will be selling my stock exhaust manifold, OBX (reinforced welded) long pipe with no cats, Cobb Turbo Inlet and SF Intake here soon once I tear down and get some pictures put up on the for sale forums. Also have some stock front calipers laying around. Need monies for this build. Everything custom fit and welded right down to the manifold and it's an upgraded s200sxe we will see where this takes us Last edited by Xtrinsic1337; 06-17-2016 at 11:43 AM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Mar 2013 Location: Accokeek MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 81
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score You may have a piece of history in your possession, the first ever blown CS turbo. I haven't heard of anyone else blowing theirs yet... So if they replace under warranty are you still going bigger turbo?
__________________ 2013 LSM w/tech Cobb AP V3, CBE CS Turbo tuned by PD Corksport Catted DP/HPFP Internals JBR FMIC Pipe Kit w/TR8 CP-E TIP/3.5" Intake DM OCC/TMM Forge V2 BPV Bilstein B8 w/Swift springs Wilwood 6 pot BBK EBC RedStuff rear pads Konig Hypergram 18x8.5" |
(Thread Starter) | Not Ranked : 0 score Yes and no lol ... Big turbo = 2 months downtime for part fabrication and 3 extra grand. This is my daily but I do work from home .. meaning I would love a replacement to get me by a few months so I can take my time and go for a second engine. It was a good turbo though and it drops in easily ... would I buy it again ? No .. the only advantage to this over the K04 is reduces EGT's due to bigger exhaust housing and the fact that it pulled hard until redline. I took her into the 170's & 180's a time or two |
![]() Join Date: Nov 2008 Location: Sumter, South Carolina
Rep Power: 0 ![]() Thanks: 10
Groaned at 25 Times in 7 Posts
| Not Ranked : 0 score I have had my CS turbo for about two months and im sure mine went bad. oil coming out the intake and compressor side. havent been to the track or done any high speed pulls. lately i have been driving the car between VA, SC, and GA. going 80MPH. |
![]() Join Date: Sep 2013 Location: Minneapolis, MN
| Not Ranked : 0 score Mine is like #5 or something like that and I am worried she might be toast, just blew through 3 quarts of oil in 400 miles. On a completely rebuilt engine that just got broke in.
__________________ 2008.5 Mazdaspeed3 |JBR 3 inch intake|Corksport turbo |Corksport EBC|CS injector seals|Cobb TBE| |CPE TMIC|Turbosmart BPV|Koni Yellows|FatCat BumpStops|Eiback Prokit springs|JBR OCC|SPC rear camber arms|DBA4000 rotors| Hawk HPS pads|JBR mounts x3|3 BAR MAP| |CS adjustable shifter|CS steering wheel|CS Sways, links and mid chassis brace Cobb AP v3 Autotech HPFP internals |
![]() Join Date: Jan 2010 Location: Everett, Wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Does CS have any kind of warranty on their turbo? |
| Not Ranked : 0 score Yes, though I cannot recall the specifics of what was on my warranty sheet I filled out. I think it was 1 or 2 years.
__________________ 2008.5 Mazdaspeed3 |JBR 3 inch intake|Corksport turbo |Corksport EBC|CS injector seals|Cobb TBE| |CPE TMIC|Turbosmart BPV|Koni Yellows|FatCat BumpStops|Eiback Prokit springs|JBR OCC|SPC rear camber arms|DBA4000 rotors| Hawk HPS pads|JBR mounts x3|3 BAR MAP| |CS adjustable shifter|CS steering wheel|CS Sways, links and mid chassis brace Cobb AP v3 Autotech HPFP internals | |
| Not Ranked : 0 score But were you pushing your K04 as hard as you were the cs? |
| Not Ranked : 0 score I was running stage 2 19 psi tunes on the K04 for about 3 years. I never even got my CS tuned. It was on safe mode spring pressure up until about 2 months ago. I had it tuned up to 21 psi on just a few revs and did maybe a dozen Wot logs, other than that didn't really push it much. I hit 24 psi once or twice for a millisecond in overboost, but CS says tuning to 30 psi is the limit so I don't expect that did it in. Just got it setup in 3 port and the last wot log was immaculate at 17 psi. If I had been beating it I could see it going in 1 year and about 15k miles but she's been babied. Won't know for sure what's up until I check the compressor housing out but definitely concerned.
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score Will cork sport warranty a disassembled turbo?
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
__________________ 94 M MS6 IS350 |
| The Following 3 Users Say Thank You to Pu Manchu For This Useful Post: |
| Not Ranked : 0 score That's what i was wondering as well... We will find out soon though.
I'll be curious to hear what they find for the cause of failure. I wouldn't take it apart yourself unless you are told it's out of warranty. Last edited by 08speed; 07-13-2016 at 07:14 PM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Aug 2013 Location: Ft Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score Any update on this? I'm still waiting for my TBE to be ready and am already looking for a BT next. I am pleased with Corksport so far, and would love a plug and play option as I am still learning to wrench as I go. Did they fix the problems from the earlier ones? A BNRs3 is also on my radar. Good luck nonetheless Sent from my iPhone using Tapatalk
__________________ CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune |
I see no reason not to put in a CS Turbo unless you have higher power goals.
![]() Join Date: Sep 2015 Location: Canada, Ontario, Toronto
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
| Not Ranked : 0 score ninja edit, you could always order a Td05 rebuild kit, as long as the wheels didnt touch it should be ok were you using an oil restrictor with this turbo?
__________________ 2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers Last edited by Cdnspeed6; 07-23-2016 at 01:58 AM. |
Groans: 438
| Not Ranked : 0 score Seems to be a few of these failures/problems on the CS turbo doesn't seem right. Just hope this doesn't turn out to be another "lug nut/cams/HPFP internals"-like case again.
__________________ All good things must come to an end... |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score It already is. Tons of people with CS turbos are having problems with boost creep, and the problem is inherent to the hot side design. Now on top of that we're also looking at durability issues. I think the product should be re-engineered. Sent from my A0001 using Tapatalk
__________________ 2007 Mazdaspeed3 GT |
Groans: 438
| Not Ranked : 0 score That's unfortunate to hear. I really like CS as they are one of the few to really keep supporting this platform. I was going to go with a CS turbo instead of the S3v2 initially. Only thing that stopped me was the fact that it can't be clocked so I couldn't use my HTP piping. Seems I avoided quite the headache.
![]() | | #24 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score OP is taking his 4th ban, Tyler McNutt yet again
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | Vansquish (09-01-2016) |
![]() | | #25 | ![]() |
Groans: 143
| Not Ranked : 0 score Do you think everything that's posted in the OP is legit in that case @SofaKingAwesome;? Sent from my A0001 using Tapatalk
| The Following User Says Thank You to MD1032 For This Useful Post: | KiwiFlavor (08-09-2016) |
![]() | | #26 | ![]() |
Groans: 890
| Not Ranked : 0 score Guys a known scammer, but who knows.
![]() | | #27 | ![]() |
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // | |
![]() | | #28 | ![]() |
![]() Join Date: Feb 2015 Location: Palmer, Iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
Pssh what a pussy, i push mine to 45psi all day everyday No but seriously i run 30 psi and have all year with meth and no issues at all with the turbo, its a good little snail.
__________________ 06 MS6 GT Titanium Gray II Metallic | |
![]() | | #29 | ![]() |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score He posted that he hit 180 mph, has anyone every went more than 165 on the stock tranny?
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Technically, if you run the engine out to 7k RPM in 6th you can hit over 180 even on stock-sized tires.
![]() | | #31 | ![]() |
| Not Ranked : 0 score Results are in, mine blew up but because shop tech left a chunk of metal in the turbo/exhaust mani. Somebody is paying for a new turbo and giving my labor charges back.
![]() | | #32 | ![]() |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score chunk??
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Yeah, studs on the turbo had to be ground down to fit the CPE manifold. Most likely one of those stud chunks fell into the turbo. Is probably now sitting in my cat.
![]() | | #34 | ![]() |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| I think there's a song about McNutty-butty. It's called, "The (Pussy) cat came back." That (motherfucking) cat just couldn't stay away.
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | monkey.bones.007 (09-01-2016), SofaKingAwesome (09-03-2016) |
![]() | | #35 | ![]() |
![]() Join Date: Apr 2018
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I see this thread is kinda dead but I figured I would post a reply anyway. I am currently running a CST4 @ max 20 psi that's been in my car for about 20k miles and it has started burning oil like a MF. It's a daily so I've been looking for a reliable replacement that's more fun than the stock turbo. The new CST5 is coming out and I've thought about waiting and buying that but I'm not sure if I want to buy a CST when the CST4 blew up so easily and quickly. Does anyone have any suggestions on a good turbo? |
![]() | | #36 | ![]() |
| Not Ranked : 0 score First of all, you need to know why it blow if it isn't high mileage.... Do you let it warm or cool down correctly? If you have a crank case ventilation problem, any turbo will end up the same way. If you have turbo surge, it may not last longer... I would also check compression to make sure it is your turbo. Why would you get a larger one if you was just running that one at 20psi ? I never try a CS but i think you have some room to grow above 20.... BNR got good feedback for the price. I personally prefer a Garrett ball bearing especially the new ones with extended R&D of the wheels. If you were looking for real big, Precision and Borgwarner EFR seem popular choices...
![]() | | #37 | ![]() |
![]() Join Date: Mar 2017 Location: Milwaukee
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score I am also curious as to the longevity of the CS turbo. It’s definitely appealing at $1099 with the 3bar. Have they stood up to the test of time?
__________________ 2008 MS3, Cobb AP V3, JBR 3.5 WP, CS 3.5 BAR, BNR S3 V2, JBR RMM 88 Duro, JBR TMM 70 Duro, Cobb TBE, EBCS, autotech HPFP, E85 mixed to E30, Snow Stage 2 WMI, (Stratified Tuned "Not for WMI") ITV22's, Koni yellows. |
![]() | | #38 | ![]() |
| Not Ranked : 0 score So far as I can tell one of the seals has gone bad and is leaking oil into the exhaust. The turbo builds boost well and spools fine. It's hard for me to know exactly how well the car has been taken care of because I bought it only 7k miles ago. Idk if the previous owner beat it up and then before he sold it put an easier tune on it to make it look better then it actually was. I've been under the car. There are no leaks from the engine and it's all healthy (as far as I can tell). Smoke has been coming out of the exhaust infrequently which hints at the turbo. I haven't dropped the exhaust and looked up into the turbo to see if there's oil yet but I plan to soon. The turbo is most likely rebuildable but CS don't want to sell me just the seals. They want me to pay for their entire CHRA. I have the old OEM turbo. I might just end up rebuilding that and sticking it back in. |
![]() | | #39 | ![]() |
![]() Join Date: Aug 2014 Location: Charleston, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
| Not Ranked : 0 score Daily driver - 45k miles on my CST. Running 22psi on 93 and 24psi on e25 tuned by FreekTune, burns zero oil. Only issue was some boost creep after the initial install that was solved by porting the interal wastegate outlet a bit, I have a the first version and I believe this has since been resolved with the newer ones. It's been absolutely rock solid.
__________________ 2012 MS3 - FreekTuned - 93 tune: 332/310 - E25 tune: 377/356 CS Stage II SRI/TIP // CS Turbo // CS EBCS // CS 3.5 MAP // CS HPFP // CS BPV // CS OCC // SU TMIC // ATP Catless Long DP // JBR 88 Duro RMM // Damond PMM/TMM // CS Front Strut Bar // CS Rear Sway Bar // EBC Redstuff Pads // EBC Rotors // Cobb V3 AccessPort // NGK Plugs (step colder) |
![]() | | #40 | ![]() |
IT is a bushing turbo, i would expect any good turbo shop can rebuild it and figure out the correct parts to do so. Keep in mind the CS is larger than oem, the k04 usually choke around 17-18 psi above 5000-5500rpm
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
| Blown turbo | acidhalo | 2010 MS3 - Turbo Induction | 24 | 10-16-2013 03:08 PM |
| Blown Turbo? | finalems3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 07-24-2013 09:37 AM |
| Blown Turbo | HawkNasty | MazdaSpeed 3/6 - Big Turbo Builds | 15 | 08-21-2012 04:51 PM |
| Blown Turbo????? | sacredmonkey | Mazdaspeed3/6 General Discussion | 10 | 02-15-2012 01:56 PM |
