> 2010 MS3 - Turbo Induction
  • 1 Post By MS3Shadow
  • 1 Post By Fstrnyou
 Old 08-18-2017, 10:05 AM   #1
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
Default Cobb TIP vs Corksport TIP
So I ended up with 2 TIP's since I bought several groups of used parts.
Corksport TIP --- Cobb TIP
Neither are installed as I need to do hpfp before installing a bunch of stuff I have waiting.
I have an uninstalled Corksport intake, thinking I should pair CS parts with CS parts.
But if the Cobb TIP and CS intake work together better for some reason I'll do that since I'll have both?
Y'alls thoughts?
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 08-18-2017, 10:16 AM   #2
speed23's Avatar
Posts: 1,480   (View Stats)
Sometimes similar brand parts match up better. Years ago I bought a corksport tip and it only worked with the corksport intake, which I did not have...they have since made their parts more universal though I believe.
As long as they match up together though, it doesnt really matter what brand you use. For intake purposes wider is better though
The Following User Says Thank You to speed23 For This Useful Post:
Bexar (08-18-2017)
 Old 08-18-2017, 09:03 PM   #3
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
Sell both and buy a 3" or bigger intake.
If you don't want to do that, use the Cobb it is silicone and gives you 167 more horsepower than the metal CS one.
You know due to heat and what not.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
Thepedigree13 is offline   Reply With Quote
 Old 08-19-2017, 02:08 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Silicone will give you a false sense of pride.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 08-19-2017, 09:06 PM   #5
Groans: 64
It was sarcasm
Topic has been beat to death, then resurrected, just to be beat to death again, hence 167 more horsepower.
All factory sized intakes, really just come down to brand preference. They fit/function basically the same.
~2013 BLACK MS3~
 Old 08-19-2017, 09:38 PM   #6
Fstrnyou's Avatar
I was making a rather strange correlation to how silicone implants make you think you're better.
Other rides:
History:
Thepedigree13 (08-20-2017)
 Old 08-19-2017, 09:58 PM   #7
What you really need is titanium intakes
Bexar likes this.
Code Monkey (08-22-2017), Thepedigree13 (08-20-2017)
 Old 08-21-2017, 10:26 AM   #8
Bexar's Avatar
Okay I ended up mating the Cobb TIP to Corksport Intake. They fit fine together and work as expected.
I'm getting the Corksport TIP 24k gold plated for better electrical conductivity, should provide more horsetorques
JBR:
The Following User Says Thank You to Bexar For This Useful Post:
speed23 (08-21-2017)
 Old 08-21-2017, 11:12 AM   #9
Fstrnyou's Avatar
Copper mesh inside the tube purifies the air for more torquepowers. Exhaust will smell great too.
Other rides:
History:
 Old 08-21-2017, 11:20 AM   #10
darkmx-6's Avatar
Posts: 126   (View Stats)
darkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nice
Ebays for da win! unless you like spending money, at the end of the day it is just a pipe. shoot, some home depot fabulous PVC would probably work just as well.
darkmx-6 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to darkmx-6 For This Un-useful Post:
g00s3y (08-25-2017), Thepedigree13 (08-21-2017)
 Old 08-22-2017, 06:48 AM   #11
drive_sideways's Avatar
Posts: 120   (View Stats)
drive_sideways is just really nicedrive_sideways is just really nicedrive_sideways is just really nicedrive_sideways is just really nice
Are u looking to sell the other TIP? Do the Speed6 and speed3 share the same TIP?
drive_sideways is offline   Reply With Quote
 Old 08-22-2017, 08:33 AM   #12
Bexar's Avatar
I do not know if they would share the same TIP, I would be looking to sell it
in the future possibly
JBR:
 Old 08-22-2017, 08:47 AM   #13
speed23's Avatar
Same tip.
 Old 08-22-2017, 08:57 AM   #14
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
Intakes are the same between MS3/6
Genpoo stuff
 Old 08-22-2017, 09:51 AM   #15
speed23's Avatar
Different mounting locations (mounts holding up intake) between 6 and 3 though depending on intake brand.
 Old 08-22-2017, 05:46 PM   #16
If it's fits I'm certainly interested, bought a 07 Speed6 a few weeks ago and looking to start modifying it. Wanna do a intake, TIP, HPFP, and Cobb APV3 all in one shot. If I'm not mistaken the TIP dosent have any mounting brackets it's just the intake itself correct?
 Old 08-22-2017, 05:54 PM   #17
Fstrnyou's Avatar
CS part number for the TIP is the same for 3, 6, and CX7.
drive_sideways likes this.
Other rides:
History:
Bexar (08-23-2017), drive_sideways (08-22-2017)
 Old 08-25-2017, 09:26 AM   #18
Bexar's Avatar
Update: I now have a CP-E turbo inlet pipe which appears to be bigger than the Cobb
Maybe I'll do a side-by-side of my turbo inlet pipes to comparison
JBR:
 Old 08-25-2017, 09:56 AM   #19
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
It doesn't matter what one you use, unless you have an actual tune on there, you aren't gaining anything.
Why do you have so many TIP's?
Thepedigree13 (08-26-2017)
 Old 08-25-2017, 02:22 PM   #20
If u are interested in selling the CS PM me. I'm located in upstate NY
The Following User Says NO Thank You to drive_sideways For This Un-useful Post:
 Old 08-26-2017, 10:42 AM   #21
Groans: 64
This thread is full of fail.
Why so many TIPS? Either you have no idea wtf you're doing, or you are stealing parts. Either way this thread is dumber than antifa!!
~2013 BLACK MS3~
 Old 08-26-2017, 02:18 PM   #22
He probs wanted just the TIPS.
Would have been easier to go full.
Thepedigree13 (08-27-2017)
 Old 08-28-2017, 09:56 AM   #23
Bexar's Avatar
I buy and sell parts. Many times I will offer to buy out all parts they're selling as a package deal and then I sell what I don't need.
JBR:
 Old 08-28-2017, 10:08 AM   #24
Groans: 126
Trump level?
Genpoo stuff
 Old 08-30-2017, 11:23 AM   #25
darkmx-6's Avatar
If you actualy read the thread you would know this.
What makes this thread dumb? It's a legitimate question. Why wouldn't it be possible for 2 parts made by 2 different companies give different results. that happens all the time.
The Following User Says Thank You to darkmx-6 For This Useful Post:
Bexar (08-30-2017)
Page generated in 0.42006 seconds with 28 queries
