![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
(Thread Starter) | Not Ranked : 0 score My story is this, I had to take apart my bpv because of 2 things, first, it needed maintenance because it has been more than 6 months since the last maintenance and cs recommends every 6 months inspection and so forth. Second, a few screws from the top cover are damage and I can't take apart the valve so in order to deal with these 2 problems I decided to take out and install back oem bpv. After installing the oem bpv, I took my car for a drive just to see everything was working fine and I noticed my car so different, more power, I could feel the car pulling harder and wheels going crazy. I'm like what is this? with the cs bpv, the car is suppose to run better than oem. I read a review on the cs site about a guy's spring was broken inside the valve. Since I can't get it apart, I'm still yet to find out if anything else is worng. I'm also having my doubts that the valve is leaking although i'll be performing a boost leak test on Tuesday. Anybody has com across with something like this???
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS |
![]() Join Date: Oct 2015
| Not Ranked : 0 score Just sounds like yours is damaged to me. Are you hitting your boost targets in your data logs? I'm running one, and it's been fine. But, I guess I haven't compared it to another bpv in a long time. I may throw the stocker back in too temporarily, just to see how it feels. Sent from my iPhone using Tapatalk |
Groans: 438
| Not Ranked : 0 score The spring inside my CS BPV broke after owning it for a year, it was purchased used from someone on here, no idea how long they had it. I hit up CS, they replaced the spring for me for free, and haven't had a problem since. I also replaced the screws on top with stainless screws, just because.
__________________ All good things must come to an end... |
| welp, i probably need to check mine. i haven't checked it in a while.
Groans: 438
| Not Ranked : 0 score I only noticed minor weird issues above 22psi on the S3, and decided to check it. Spring was was still "together" inside, still holding boost decently, but broken into 3 pieces when I turned it upside down and let it fall out.
![]() Join Date: Aug 2013 Location: Round Rock, Tx.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 85 Times in 26 Posts
| Not Ranked : 0 score I have serviced mine religiously. Went to clean and lube the valve today and found my spring broken in half. Hoping I can get a replacement quickly. |
| The Following User Says Thank You to Malbosia For This Useful Post: | dvswimer (01-02-2018) |
![]() Join Date: Jun 2014 Location: Chatsworth, CA
Rep Power: 122 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score You can add me to the list. Sent from my SPH-L720 using Tapatalk |
![]() Join Date: Apr 2014 Location: Ripley, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score Wow, I guess I need to check mine now. I hope this gets resolved.
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray |
![]() Join Date: Nov 2015 Location: Port Hope, Ontario
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Havn't had mine on for more than a summer but it was definetly more efficient than the stock BPV, I did have a sealing problem but that was due to the previous owner stripping the threads I agree I hope this is resolved!
__________________ Don't be upset with the result you didn't get with the work you didn't do '11 Speed 3 Built motor (Manley h beams mahle pistons no headwork) Gt3582r Stock intake/exhaustTr8 Cs bpv Aem meth (1000cc) Neo coils Jbr 3.5 intake Jbr trans mount cpe rmm corksport pmm Ss lines Hp+ pads Bm spec aero tuned by Nishan Let's see what it'll do build '85 Rx7 Gs Gsl rear end full exhaust, rb header vibrant reso/ muffler, fc front subframe swap in the near future, keep it classic cruiser |
| The Following User Says Thank You to Janks For This Useful Post: | dvswimer (01-02-2018) |
Groans: 438
| Not Ranked : 0 score I wonder if that's the reason they released a new kind of BPV. Hopefully nothing in that one will break, as I'll be buying that once the motor is together.
![]() Join Date: Dec 2014 Location: Puerto Rico
Rep Power: 73 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score I'm also going to do maintenance on mine. My stock BPV couldn't hold more that 18psi of boost without leaking. I had purchased a fake HKS for $120, it had everything need to do recic, but after I set everything up and closed the hood the nipple didn't clear the hood intake so it broke off and I had to return it. I got the CS because it was the cheapest real BPV option and also because of it's fast recirculating. I was able to run almost 21psi thanks to it. |
| The Following User Says Thank You to TheSixthSpeed For This Useful Post: | dvswimer (01-02-2018) |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
I had two holes strip out upon first disassembly. I found those short bolts to have very little thread engagement. I wasn't impressed. I ended up tapping all the holes out slightly and replacing the hardware with longer M4-0.7 x 12mm socket cap screws. | |
![]() Join Date: Aug 2013 Location: Ft Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
What were the symptoms of the stocker not holding? Anything other than viewing datalogs? Sent while probably pooping
__________________ CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune | |
The car just never made the power that I tuned it for. I thought I had a boost leak... well technically the BPV was leaking boost but since it recirculates, it doesn't screw over the AFR, so the ECU doesn't see anything wrong I guess. That's why your not really going to get any messed up symptoms. If you had VTA BOV, you would definately run really reach during WOT and not just while coming off the throttle. | |
Awesome thank you. Looks like I will be getting some rice for a Christmas present. Tuner said I might have a boost leak. Found one and tapped the threads of the nozzle on my TIP. Still was there. Funny though through my searching I seems like the stock one holds well up to 22psi Sent while probably pooping
All I know is that my valve was limiting my power without a doubt, because as soon as I swapped in the CS, it was boosting around 19psi and even spiked at 22psi. My stock valve never even spiked near that. | |
| Product Release!! CORKSPORT 2010+ Mazda 3 Skyactiv Air Box for CorkSport SRI | CorkSport | CorkSport | 0 | 07-11-2013 04:00 PM |
| CorkSport Announces Release of New CorkSport Stub Antenna | CorkSport | CorkSport | 5 | 10-03-2012 09:31 PM |
| CorkSport Product Release! CorkSport 2007-2009 Mazdaspeed 3 Front Mount Intercooler for SRI | CorkSport | CorkSport | 6 | 11-14-2011 03:15 PM |
| CorkSport Product Release! ? Introducing the New CorkSport Radiator Cap | CorkSport | CorkSport | 0 | 08-05-2011 06:30 PM |
| CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available | CorkSport | CorkSport | 0 | 08-05-2011 06:30 PM |
