![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS |
| Valve Spring Question on CS Cams | eliwwjd | 2010 MS3 - Engine, Transmission & Driveline | 1 | 10-11-2019 06:35 AM |
| PT-P regrind cams story -- need Web weld & regrind cams | MazdaGaragePat | MazdaSpeed 6 - Engine, Transmission & Driveline | 30 | 08-10-2016 03:46 PM |
| Hot cams | TJSpeed6 | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 06-14-2013 05:28 AM |
| What Do Cams Do? | kingpin748 | MazdaSpeed 3 - Engine, Transmission & Driveline | 37 | 02-16-2009 08:25 PM |
