 Old 03-26-2019, 06:13 PM   #1
Giojettson's Avatar
Posts: 6   (View Stats)
Giojettson will become famous soon enough
Default Miss match front strut question
Good day good people.
this is like my second post EVER but i come to this forum a lot reading all of the old post, how too's and what not. But recently Something happened and I wanted the opinion of this fine community.
So, i purchased from tunersport a complete set of koni str.t struts that came with eibach springs. So i get the box and take it to my local car guy to have them placed on my speed 3 2010 blue road runner. I get a call while im in class from my mechanic and he says that there is a miss match with the front strut???
after class, i hustled to the shop and low and behold, i definitely have a miss match front pair. So:
on the rear i have the Koni str.t orange
and on the front, i have 1 Koni str.t orange and 1 Koni Sport yellow...
Initially, I was like well i need to exchange them them and get the other orange one...honestly, its kinda of a hassel right now, im a student studying engineering, im leaving for a conference in like 2 days for a week. then when i get back all school hell will break loose.
my question is simply: Can i put the koni yellow and the koni orange on the front and just have this Frankenstein suspension without damaging my car?
[/B]
also, im driving my speed 1500 miles in may to add to the equation. thanks in advanced peoples.
Giojettson is offline   Reply With Quote
 Old 04-23-2019, 01:11 PM   #2
Mazda3Blog's Avatar
Posts: 35   (View Stats)
Mazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to all
Hope you didn't get these installed. Mismatched front shocks will cause your car to pull under braking and probably on the highway as well. It's a big no-no.
2010 Black MS3 (autocross/track duty)
Stratified tune, Accessport, Corksport HPFP, Corksport TMIC, Ultimate Racing test pipe, K&N intake, E-focus RMM, Corksport RSB, Corksport steering wheel + ebrake handle, solid shifter bushings, RE-71R tires
2007 Black Speed6 (daily driver)
Freektune, Accessport, Autotech HPFP, CPE TMIC, Ultimate Racing test pipe, Cobb intake + TIP, Corksport rear diff mount, CPE xflex RMM, Corksport rear brake pads, Matt Damond rear caliper bushings, solid shifter bushings, X-ice3 / AS3+ tires
Mazda3Blog is offline   Reply With Quote
 Old 04-23-2019, 03:06 PM   #3
Posts: 2,235   (View Stats)
i agree with the above, you should always use suspension parts as a set or at least as a pair.
Yellow use an adjustable valve and i think the orange didn't...
IT would be like driving with a winter 15'' tire on one side and a Z rated 18inch on the other side....you can reach destination but you better keep the oem than swaping for unbalanced one....And if you mount the yellow, it will be harder to get replacement later...
 Old 04-26-2019, 03:03 PM   #4
ThorOtheBIG's Avatar
Posts: 56   (View Stats)
ThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura about
Guys, it has been a month since his post. He has came and went from that engineering conference. He must have it sorted out by now.
You'd think being an engineering student he would've thought about it and then decided not to install it, contact the distributor and get the correct one sent out. By the time he gets back he'd have the new part.
ThorOtheBIG is offline   Reply With Quote
Help with front strut Code Monkey MazdaSpeed 3/6 - Suspension & Brakes 9 10-09-2014 09:52 AM
Front strut bar on MS6????? redboat MazdaSpeed 3/6 - Suspension & Brakes 6 01-27-2014 11:51 AM
Front Strut Bushing Spirry MazdaSpeed 3/6 - Suspension & Brakes 0 04-18-2011 08:17 AM
Page generated in 0.24871 seconds with 23 queries
