 Old 08-04-2018, 06:23 PM   #1
Sierra248's Avatar
Posts: 22   (View Stats)
Sierra248 is an unknown quantity at this point
Default Strut spring perch modification? Gen1
I’ve been planning on going with Bilstein B8’s on my 07 speed 3. I’m at 70k and need new struts..but. I’ve been reading that the Bilstein and Koni FSd(not getting the FSDs) raise the front of the car, which I definetly don’t want to do. I’ll be putting these most likely on the stock springs as it’s pretty firm already but if I get a raise at work I may go swift or the mazdaspeed springs that come with the rear camber arms. For now though, say I’ll be on the stock springs.
I really don’t want to be grinding down the perch on a set of 250 dollar a piece front Bilstein struts and probably ruining the warranty and really just don’t want to have to anyway.
If I were to go with the Koni Yellows are the perch on those the correct height? I want a high quality strut, not the str.t or any sen sen stuff.
Thanks for any info, appreciate the help guys.
Sierra248 is offline   Reply With Quote
Rear Spring Perch kuraijay MazdaSpeed 3/6 - Suspension & Brakes 2 04-05-2016 06:32 PM
Shock/Strut & Spring combinations? WWP6 MazdaSpeed 3/6 - Suspension & Brakes 30 03-30-2011 05:13 PM
Gen1 vs Gen2 Stock Spring Rates Boother MazdaSpeed 3/6 - Suspension & Brakes 7 02-18-2011 09:26 PM
Page generated in 0.21582 seconds with 20 queries
