![]() Join Date: Apr 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score I have gone through testing ebcs and wastegate and both are functional, i did a boost leak test though the intake pre-maf. Details can be found in this thread. I uploaded the tune and a 4th gear log, only thing that changed is i routed my catch can differently which i explain in the linked thread above.
__________________ JBR 88d RMM~CorkSport 3" CBE~CNT 3" DP Catted~JBR True 3" Intake~JBR EBCS~CX Racing FMIC/ Pipes~CorkSport Injector Seals~JBR TIG~BNR S4~EGR Delete~Synapse Synchronic DV~Cobb AP~Koni Str.t Struts Last edited by CleverOne; 05-27-2018 at 12:09 AM. |
| Not Ranked : 0 score If you aren't hitting boost targets, then you have some load targets in place that are getting referenced. Your WGDC decreases throughout the run. Can't open your tune on this computer.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
(Thread Starter) | Not Ranked : 0 score I thought that might be the case as well but I have gone over any load problems. I linked to another thread where I was asking is my catch can could cause a boost leak, I did a leak down premaf and had sent air coming from the catch can. I have a new one in order from jbr, I'll update after I install it Thurs or Friday.
__________________ JBR 88d RMM~CorkSport 3" CBE~CNT 3" DP Catted~JBR True 3" Intake~JBR EBCS~CX Racing FMIC/ Pipes~CorkSport Injector Seals~JBR TIG~BNR S4~EGR Delete~Synapse Synchronic DV~Cobb AP~Koni Str.t Struts |
| Not Ranked : 0 score Your ECU is trying to lower your boost. Catch can isn't going to fix that. Post up screenshots of your Wastegate Duty Load Dynamics and Wastegate Duty Load Error Comp tables.
(Thread Starter) | Not Ranked : 0 score So I checked for leaks after changing the can, it doesn't leak from the can anymore but still not boosting over 20lb. I'm at a loss and don't know what else to check hardware wise. I powered the ebcs and it clicked and air passed through the correct outlet. I've done a compression test which was good, I've done a boost leak test, no leaks, I've pressed air into the wastegate actuator and heard and saw the lever move. If it's the tune I'm just going to get a freaktune most likely, I just want to get everything good before that.
| Not hitting boost targets, not boost leak | ADHDAdditiv | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 28 | 07-18-2014 02:18 PM |
| Boost Targets | pawlwawl06 | 2010 MS3 - ECU Computer Tuning | 31 | 01-13-2013 06:37 AM |
| boost tuning, not hitting easy boost targets? | Caldazar | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 05-18-2012 06:09 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| ideally whats the best boost targets for custom tune from full boost to redline? | Wenis Prinkle | Cobb ATR Support | 26 | 08-24-2009 06:36 PM |
