> 2010 MS3 - Dyno Sheets/Discussions
  • 1 Post By Cevaes_64
 Old 10-16-2015, 08:21 PM   #1
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
Default BNR S3 Dyno 400WHP =)
Well, decided to stop by the Dyno today, it was 90 degrees outside (FL).. I was on my e-85 Map, did 3 runs, 1st run dyno couldn't read because car was spinning!, right after that i was already excited... 2nd time it was 394 (See pic) then i did it again and it was 402WHP.. Needless to say i was a happy camper then... it was a Mustang Dyno that usually reads low but after i saw my datalogs im pretty sure this number is accurate as accurate can be...
BNR S3 PD Tuned...
Just wanted to share my Happy Dyno day =)
Edit: Added Dyno Graphs
File Type: jpg 12077453_10205108918942225_1864022431_n.jpg (84.5 KB, 128 views)
File Type: jpg 12166151_852955834818002_1359827736_n.jpg (81.1 KB, 132 views)
File Type: jpg 12166460_852952334818352_228583274_n.jpg (82.5 KB, 126 views)
File Type: jpg 12170196_852949368151982_738485717_n.jpg (100.3 KB, 129 views)
The Following 12 Users Say Thank You to Cevaes_64 For This Useful Post:
BLKSTIG (10-17-2015), Easter Bunny (10-17-2015), g00s3y (06-15-2016), Hammology (10-17-2015), InkedInspector (10-16-2015), mxlplx71 (10-16-2015), myarbro1 (10-16-2015), speed23 (10-16-2015), speedfreak44 (10-16-2015), SpeedRebirth (10-17-2015), Thepedigree13 (10-16-2015), WAMBUSHHHH! (10-20-2015)
 Old 10-17-2015, 12:47 AM   #2
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Datalogs?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
mxlplx71 (06-15-2016)
 Old 10-17-2015, 08:39 AM   #3
Cevaes_64's Avatar
Datalogs?
I Told the guy at the Dyno to push the Log button on the car and he said he did, when i got home looking for logs there were none =(
 Old 10-17-2015, 08:43 AM   #4
mituc's Avatar
Groans: 111
Then the data logs you said have seen...
 Old 10-17-2015, 09:56 AM   #5
Cevaes_64's Avatar
I have other ones but not at the time of the dyno, not home now I'll upload later
Sent from my SM-N920T using Tapatalk
 Old 10-17-2015, 10:02 AM   #6
Police
InkedInspector's Avatar
Groans: 312
Nice numbers, but that would scare me on stock block. I plan to dyno when Rob and I wrap up mine, but I'm on the fence about ethanol, this kind of pushes me to stick with pump gas.
The Following 2 Users Say Thank You to InkedInspector For This Useful Post:
Cevaes_64 (10-20-2015), Easter Bunny (10-18-2015)
 Old 10-17-2015, 10:09 AM   #7
Voltwings's Avatar
Posts: 3,713   (View Stats)
im more interested in seeing the graph. 420 is fine on stock motor as long as you push that torque peak out nice and far.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
Cevaes_64 (10-20-2015), InkedInspector (10-17-2015), Matt H. (03-18-2016)
 Old 10-17-2015, 10:38 AM   #8
Cevaes_64's Avatar
I won't use this map as a daily, I'm very fond of my stock internals lol,
 Old 10-17-2015, 10:40 AM   #9
Cevaes_64's Avatar
Sorry if uploaded twice, only 2 graphs here... I'm on my phone and driving
The Following 2 Users Say Thank You to Cevaes_64 For This Useful Post:
Easter Bunny (10-18-2015), Voltwings (10-18-2015)
 Old 10-18-2015, 07:10 PM   #10
sheston's Avatar
Posts: 1,847   (View Stats)
I'd like to see some logs as well. It would be interesting to see boost, AFRs, timing.....
Just for comparison:-)
 Old 10-18-2015, 08:12 PM   #11
Cevaes_64's Avatar
Sorry, Logs aren't coming, but its like this timing 15.5 max, Airflow:360 to 370 G/S , Boost:24 PSI , IDC 102-103 , Bats 111, AFR 11.7
The Following User Says Thank You to Cevaes_64 For This Useful Post:
Voltwings (10-19-2015)
 Old 10-19-2015, 07:38 PM   #12
blackms3_71's Avatar
Posts: 2,250   (View Stats)
I dont like the 100+ idc. Not that its bad but i would ease up just a tad.
The Following 2 Users Say Thank You to blackms3_71 For This Useful Post:
Cevaes_64 (10-20-2015), Voltwings (10-19-2015)
 Old 10-19-2015, 07:43 PM   #13
Cevaes_64's Avatar
Yeah usually around 110 you start to have cuts, I haven experienced any yet, some even get around 115, but it's ok that was the highest number I saw, something had to be kinda out there to be able to make that power =)
ms3gt08 likes this.
 Old 10-19-2015, 11:06 PM   #14
mituc's Avatar
Groans: 111
At 110% things start not being optimal any more. IDC100-105% though it's still fine, is just a sign that you need aux fuelling.
Weird thing you have no logs. I mean, really! How did you tune without logs?!
Cevaes_64 (10-20-2015), mxlplx71 (06-15-2016)
 Old 10-20-2015, 06:16 AM   #15
Cevaes_64's Avatar
I never said i didn't had other logs
 Old 06-14-2016, 04:36 PM   #16
PRIME-B's Avatar
Posts: 27   (View Stats)
PRIME-B has a spectacular aura aboutPRIME-B has a spectacular aura aboutPRIME-B has a spectacular aura about
Nice number man. Ive got an s3 and all the supporting mods in my garage waiting to be installed, hopefully soon! Once i get it together we should link up, I'm local to Tampa as well.
"If you're not 1st, You're last"
PRIME-B is offline   Reply With Quote
 Old 06-14-2016, 05:54 PM   #17
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Not bad for S3.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 06-15-2016, 12:03 AM   #18
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
any..... logs? lol
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-15-2016, 04:40 AM   #19
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
I too would like to see logs. Seeing some actual data would be nice.
 Old 06-15-2016, 05:30 AM   #20
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
any..... logs? lol
That's a lot of logs
2012 NASA Spaceship Gray MS3
g00s3y (06-15-2016), Thor Hammer (06-15-2016)
 Old 06-15-2016, 07:21 AM   #21
JakeMS3's Avatar
Homie got mad logs!
2013 LSM w/tech
Cobb AP V3, CBE
DM OCC/TMM
Forge V2 BPV
Wilwood 6 pot BBK
The Following User Says Thank You to JakeMS3 For This Useful Post:
KiwiFlavor (06-15-2016)
 Old 06-15-2016, 11:40 AM   #22
g00s3y's Avatar
Groans: 438
Also OP, what's your mod list?
Why would you not use the map as a daily? TQ is kept around 350 it seems, which is very safe. ~400hp is safe for stock block. Unless you drive around redlining your car everywhere, in which point no tune is really safe, there shouldn't be any problems with running this daily.
 Old 06-15-2016, 06:33 PM   #23
PRIME-B's Avatar
What specs are you running for your numbers? Are you making 400whp on a daily tune? what fuel?
 Old 06-15-2016, 06:40 PM   #24
g00s3y's Avatar
Groans: 438
It says all that in my signature.
Yes I run this tune daily.
 Old 06-15-2016, 06:42 PM   #25
PRIME-B's Avatar
boost?
 Old 06-15-2016, 07:30 PM   #26
g00s3y's Avatar
Groans: 438
Over 9000psi boost.
 Old 06-15-2016, 07:53 PM   #27
KiwiFlavor's Avatar
Over 9000psi boost.
g00s3y (06-15-2016)
 Old 06-21-2016, 06:47 PM   #28
vesestilldrumming's Avatar
Posts: 50   (View Stats)
vesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of lightvesestilldrumming is a glorious beacon of light
Groaned at 6 Times in 2 Posts
You should change your info on your profile to PD tuned instead of self tuned man. Nice numbers too!!!
Sent from my SAMSUNG-SM-N920A using Tapatalk
vesestilldrumming is offline   Reply With Quote
400whp on e85 you say? btstarcher Mazdaspeed3/6 General Discussion 13 09-30-2013 12:10 PM
Another ~400WHP BNR Speed 3 Novej Stratified Automotive Controls 54 03-05-2013 07:49 PM
Ideas, possibilities, and a 400whp dyno this week phailerider MazdaSpeed 3 - Engine, Transmission & Driveline 58 04-02-2009 04:45 PM
The 400whp Club gsrtype1 MazdaSpeed 3/6 - Dyno Sheets/Discussions 16 09-26-2008 03:19 PM
Page generated in 0.46339 seconds with 32 queries
