> 2010 MS3 - Dyno Sheets/Discussions
  • 1 Post By CHUNKYBOWSER
  • 1 Post By twenty5psi
 Old 11-19-2014, 07:05 PM   #1
CHUNKYBOWSER's Avatar
Posts: 209   (View Stats)
CHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the world
Default GTX3067R (not 76, 67) on E33
Goal was to take the stock block to what I think is a safe power level. Turned out nicely. Mods in signature. 60 degree ambient temperature.
Mauro_Penguin likes this.
Engine
| GTX3067R | Cobb AP | Autotech Internals | HTP 3.5" Intake | M2 Long Downpipe |
| ATP FMIC | Forge V1 | Grimmspeed EBCS | 3 BAR MAP | NGK Iridium IX |
| Damond EGR Delete | JBR OCC | E33 Self Tune | DO7 Meth |
Handling
| Damond RMM | Damond PMM | JBR 88a TMM | JBR Shift Weight & Knob |
| JBR Rear Sway Bar | Cobb Springs |
CHUNKYBOWSER is offline   Reply With Quote
The Following 13 Users Say Thank You to CHUNKYBOWSER For This Useful Post:
AlexInNS (12-09-2014), Cevaes_64 (03-10-2015), Cheapspeed (11-19-2014), Code Monkey (11-19-2014), Darth_Nuruodo (11-19-2014), Mauro_Penguin (11-26-2014), mize13 (11-26-2014), stanley0910 (11-26-2014), therapist510 (11-26-2014), Tifosi42 (09-09-2016), twenty5psi (11-26-2014), Voltwings (11-26-2014), Ziggo (11-19-2014)
 Old 11-19-2014, 07:14 PM   #2
RACER_X's Avatar
Posts: 266   (View Stats)
Wow, delivery looks super smoooooooth
ΜΟΛΩΝ ΛΑΒΕ
2015 F150 Platinum
2012 MS3 Liquid Silver
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Enkei Raijin 18x8 et45
JBR 3.0WP, RSB, RMM & SSP II
Stratified Tune
TurboSmart BOV
 Old 11-26-2014, 12:00 AM   #3
shaneski's Avatar
Posts: 505   (View Stats)
Was the Log done on a slightly up hill near the end. Curious of where your boost ramps up around 5800rpm the HP starts to drop off instead of holding or increasing the HP..Looks like a nice curve though.
 Old 11-26-2014, 05:16 AM   #4
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
Was this on the stock mazda flange and ATP hot side?
 Old 11-26-2014, 07:08 AM   #5
Plimmer's Avatar
Posts: 695   (View Stats)
Plimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the world
Mine does the same thing, power drops off even though boost is ramping up. Seems like stock block flow restriction somewhere.
Was: 2012 with GTX3071 and BF Goodrich g-Force Rivals
Now: 2015 Mustang GT 5.0, soon to be track toy
Plimmer is offline   Reply With Quote
The Following User Says Thank You to Plimmer For This Useful Post:
CHUNKYBOWSER (11-26-2014)
 Old 11-26-2014, 07:33 AM   #6
twenty5psi's Avatar
Posts: 213   (View Stats)
twenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the world
@Mauro_Penguin
This car has stock unported IM and stock exhaust manifold as well, standard ATP setup. This is an impressive turbo, the 67R GTX wheel really needs the GT30 turbine to breathe.
2013 MS3 VRM w/Tech
-unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings
FlowTuned 2 Gallon E85 blend 307whp/336wtq
twenty5psi is offline   Reply With Quote
The Following 2 Users Say Thank You to twenty5psi For This Useful Post:
CHUNKYBOWSER (11-26-2014), Mauro_Penguin (11-26-2014)
 Old 11-26-2014, 08:23 AM   #7
Voltwings's Avatar
Posts: 3,713   (View Stats)
Looks excellent, i'd be real happy with that power band.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
CHUNKYBOWSER (11-26-2014), Mauro_Penguin (11-27-2014)
 Old 11-26-2014, 08:29 AM   #8
stanley0910's Avatar
Posts: 364   (View Stats)
stanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the world
That's smooth torque. I see you self tuned, how much time did you spend on it/do you have much more room for tuning?
Need more parts.
stanley0910 is offline   Reply With Quote
The Following 2 Users Say Thank You to stanley0910 For This Useful Post:
 Old 11-26-2014, 09:13 AM   #9
I took some time with tuning... Maybe about a month to the final map. I went through about 15 revisions on the 93 tune and about 6 on the E85 map. I have room for some more timing but in this run my IDC hit 99% and I don't feel comfortable going any further until I get a meth kit. I would also like to make more than 330hp on 93 since I was knock limited.
I would also like to note that I'm basically on the stock catback, minus muffler. 2.5" piping or whatever stock is. I'm actually going to be putting the stock muffler back on.
Engine
Handling
The Following 2 Users Say Thank You to CHUNKYBOWSER For This Useful Post:
Mauro_Penguin (11-27-2014), stanley0910 (11-26-2014)
 Old 11-26-2014, 09:29 AM   #10
[QUOTE=CHUNKYBOWSER;2760652]I took some time with tuning... Maybe about a month to the final map. I went through about 15 revisions on the 93 tune and about 6 on the E85 map. [QUOTE]
Did you back off the boost and raise timing then add boost back with the E85 tune or did you leave the boost the same as the 93 map and then add timing?
Need more parts.
The Following User Says Thank You to stanley0910 For This Useful Post:
 Old 11-26-2014, 09:31 AM   #11
Voltwings's Avatar
You can PM me if you want to discuss this in more detail, but whats your timing up top? These little turbos will take a good deal of timing without acting up, so you could effectively lower your boost a tad (to free up some fuel head room) and make up the difference with timing. Though there is always a balance, might require some playing around with it.
I had a guy whose IWG 3071 was creeping to 28 psi, and would max out the fuel system even on 93 ... had to get real creative with his tune a few times to keep everything happy lol. I dont mean to come in and try to take anything from what you've done here though, like i said before, i'd be very happy with that powerband.
Past:
-Sold-
-Sold-
Current:
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
CHUNKYBOWSER (11-26-2014), Jtaylor (11-26-2014), Mauro_Penguin (11-27-2014)
 Old 11-26-2014, 10:11 AM   #12
[quote=stanley0910;2760667][QUOTE=CHUNKYBOWSER;2760652]I took some time with tuning... Maybe about a month to the final map. I went through about 15 revisions on the 93 tune and about 6 on the E85 map.
I left boost the same for my E85 map, then added timing. My goal was basically the power level I'm at now, and I feel more comfortable pushing boost rather than timing since I don't have access to a real dyno to see where I hit MBT.
Engine
Handling
The Road to an EFR 9180 Build NCspecV81 2010 MS3 - Big Turbo Builds 1465 06-02-2018 12:06 PM
Zachy Poo's GTX3067R Build Zpuhalla 2010 MS3 - Big Turbo Builds 217 12-11-2014 01:08 PM
GTX3067R NCspecV81 EdgeAutosport.com 9 03-03-2014 05:37 PM
Page generated in 0.32943 seconds with 28 queries
