![]() | | #81 | ![]() |
![]() Join Date: Feb 2010 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
| Not Ranked : 0 score
__________________ SOLD on 08/2013 2010 Black Mica MazdaSpeed3 Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC |
![]() | | #82 | ![]() |
![]() Join Date: Jan 2010 Location: Pleasanton, CA
| Not Ranked : 0 score Woot! Looking forward to getting this done this weekend Can you guys please confirm whether taking down the SRI/TIP is really necessary? I don't feel like dicking with that again ![]() Thanks! |
![]() | | #83 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score It is not necessary. The only thing I removed was the TMIC. |
| The Following User Says Thank You to wolly6973 For This Useful Post: | mrFanel (05-09-2011) |
![]() | | #84 | ![]() |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
(Thread Starter) | Not Ranked : 0 score not necessary but it definitely give u a lot more space to work with. its up to u
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" |
![]() | | #85 | ![]() |
| Not Ranked : 0 score w3rd. I am heading out to my homie's this weekend to do the pump internals since i have no tools at my apt complex not to mention they don't allow you to work on cars. Probably will drop itv-22 spark plugs too since I hope to get them by that time and since the TMIC will be out |
![]() | | #86 | ![]() |
Groans: 263
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" | |
![]() | | #87 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score I only removed the TMIC shroud. Removing anything else is not necessary, and is a waste of time. Take your time and you'll be alright. |
![]() | | #88 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score great job with the write up |
![]() | | #89 | ![]() |
| Banned ![]() Join Date: Jul 2009 Location: Fremont, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 257
| Not Ranked : 0 score |
![]() | | #90 | ![]() |
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
| Not Ranked : 0 score thanks for the write-up! nicely done. did the install last night and this made it a hundred times easier.
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges |
![]() | | #91 | ![]() |
![]() Join Date: Apr 2010 Location: Kansas City, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 585
Groans: 39
| Not Ranked : 0 score I installed my internals as well...finally! I will mention that for the 19mm open wrench, it may be beneficial to find a stubby one. The normal length one is really hard to fit down in the tight space behind the fuel pump. I took off the TMIC and the hose coming from the turbo to help open up some space. Also, for those afraid to take apart the fuel pump and install KMD or Autotech internals, don't be. The hardest part by far is taking the fuel pump off and putting it back on. Once you have it off, it's easy to install the internals. Be sure you've got a vise though.
__________________ 2010 Silver Mazdaspeed3 |
![]() | | #92 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score I installed mine last week and everything went perfect. only thing i removed was the sri because I wanted some extra room.
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #93 | ![]() |
![]() Join Date: Jun 2009 Location: Alpharetta, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score quick question, how do the internals lubricate? Do they continually run in the original oil you put on them or do they maintain a thin fuel layer for lubrication? I know there's a little hole in the one piece, thought maybe that's to allow fuel or oil to lubricate it. |
![]() | | #94 | ![]() |
![]() Join Date: Nov 2009 Location: Tulsa, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 117
Groaned at 60 Times in 32 Posts
| Not Ranked : 0 score Read the thread |
![]() | | #95 | ![]() |
Groans: 731
donate you non heterosexual person
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. | |
![]() | | #96 | ![]() |
| Not Ranked : 0 score Did mine today with a buddy who did it on his GenDone a while back - here's my take on things: 1. You do not need to depressurize the system; just let it sit for 10-15 minutes to let the engine cool if you drove it; if you did not drive it - get going, it's not primed anyway. 2. Removing the Intercooler is NOT necessary... but I removed mine anyway because I changed my plugs. 3. Definitely use vice grips. Definitely. 4. You can drop your pump once - it will survive /facepalm 5. The bug nut for the bottom feeder metal hose is a bitch. I hate it. We're not talking. Other than that - it's pretty much straight forward. Oh - and as someone mentioned - make sure you bolt the pump in evenly! |
| The Following 6 Users Say Thank You to mrFanel For This Useful Post: | DingoDave (05-14-2011), indianaryan (05-16-2011), kgb (03-15-2012), Silverspec06 (11-17-2012), TRSpeed (10-12-2011), zxhoya (09-08-2011) |
![]() | | #97 | ![]() |
![]() Join Date: Jun 2008 Location: Montreal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score woodworker vice should be good?
__________________ ||Cobb AP(DJ tuned)||Cobb SRI||Cobb TIP||Cobb FMIC||Cobb SW||KMD v2.2 HPFP||Catted TBE(TurboXS DownPipe+Vibrant DPback)||TurboXS Hybrid BOV||Fortune Auto Coilovers||Powergrid Endlinks||Eibach Camber Kit||CPE RMM||Denso ITV22||STRI DSD 60mm Boost Gauge||5000K HID Fogs||Lamin-x Foglight Tints||Speedy Lite-Fin 18x7.5||General UHP 235/40/18||ADR 17x7(Winter)||Nextmod GV front Lip/spoiler Lip||AutoEXE Carbon Fiber Shifter Knob||Carbon Fiber Ebrake Cover||TWM Bushings||TWM Shift/Ebrake Boots|| |
![]() | | #98 | ![]() |
Groans: 263
(Thread Starter) | Not Ranked : 0 score as long as that motherfucker doesnt move, then yes
| The Following User Says Thank You to rghispanic88 For This Useful Post: | kgb (03-15-2012) |
![]() | | #99 | ![]() |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 62
| Not Ranked : 0 score great write up! thanks so much for this.. about to order mine in a couple of weeks i think.. just to be sure, this is the one right? Audi - A3 - 2.0T FSI - Engine - KMD Tuning - 2.0T FSI High Pressure Fuel Pump Kit - KMD Tuning |
![]() | | #100 | ![]() |
Groans: 263
(Thread Starter) | Not Ranked : 0 score yep, that or autotech. i will be doin another install with autotech internals very soon. should be the same process
![]() | | #101 | ![]() |
| Not Ranked : 0 score for all the people saying the took out the full pump without removing the TIP bull crap lol there is no way to losen that bottom plug made of metal without removing the TIP unless im missing somthing..
__________________ Cobb SRI ll Jbarone SSP ll CP-e 60 RRM ll UR Test Pipe ll Cobb Knob ll Cobb AP Running Stage 2 + SF ll Auto tech InternalsComing Soon: ll UR Cat-back ll |
![]() | | #102 | ![]() |
| 0187 ![]() Join Date: Apr 2009 Location: CT, Thompson
Rep Power: 197 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
Groaned at 9 Times in 5 Posts
Sent from my iPhone using Tapatalk | |
![]() | | #103 | ![]() |
Groans: 263
(Thread Starter) | Not Ranked : 0 score it is possible but u can take BIG risk of bending or possibly breaking the lower aluminum fuel line. All i have to say is that it is better to be safe than sorry
![]() | | #104 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 269 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 173
Groaned at 22 Times in 8 Posts
| Not Ranked : 0 score well since iam doing the cobb inlet turbo install and change the pump ill be easy on it ,
__________________ Dr_banano Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front ptp studs/seals pending mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car |
![]() | | #105 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score I did mine without removing the CS TIP... No problem at all.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() | | #106 | ![]() |
| Not Ranked : 0 score alright so went up to ace and got the 18mm deep socket and with i vice the bolt came out no problem, now that i have the stock internals out do i need to remove anything else before i put them in? I tried to slide them in from the bottom but it felt like they weren't going in and i didnt want to force them and scratch them. Here is the stage im at now.
![]() | | #107 | ![]() |
Groans: 451
| Not Ranked : 0 score Yeah put the new internals in the same way the old ones were. I think it slides in from the top, then the big part goes in from the bottom. When you put the "Hat" on, set the little shim things inside of it and make sure it will stay in place. After that, put it all back together.
![]() | | #108 | ![]() |
Also with that "hat" peice all i do is place them inside that hat and set it on top? when i did this i could pull it off easily, that correct?
__________________ Cobb SRI ll Jbarone SSP ll CP-e 60 RRM ll UR Test Pipe ll Cobb Knob ll Cobb AP Running Stage 2 + SF ll Auto tech InternalsComing Soon: ll UR Cat-back ll | |
![]() | | #109 | ![]() |
| Not Ranked : 0 score man i must be stupid i cant get the stupid Hat shaped piece with the 2 black pieces in it to snap onto the top of the piston cylinder. The directions say to not push down on the Hat piece but to push up with you thumb from the bottom of the cylinder, but when i do that it goes up into the fatter piece and i cant push no more with my thumb. im puzzled. Edit: ok figured it out end up your suppose to put the Hat peice ont he pistion first then put the 2 black pieces on... i am an idiot lol
__________________ Cobb SRI ll Jbarone SSP ll CP-e 60 RRM ll UR Test Pipe ll Cobb Knob ll Cobb AP Running Stage 2 + SF ll Auto tech InternalsComing Soon: ll UR Cat-back ll Last edited by memoriesmazda; 06-11-2011 at 01:31 PM. |
![]() | | #110 | ![]() |
Groans: 451
| Not Ranked : 0 score Sounds like you got it! No man, it took me a couple minutes to get that right... it didnt seem right just sitting in there haha.
![]() | | #111 | ![]() |
| Not Ranked : 0 score just a quick question on #15..."make sure nothing fell in the fuel pump." you mean when the parts in the gasoline? |
![]() | | #112 | ![]() |
| Banned ![]() Join Date: Feb 2010 Location: Oregon
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 544
Groans: 30
Groaned at 40 Times in 13 Posts
| Not Ranked : 0 score Great write up!! I just installed my KMD's this evening. I just removed my TMIC and had no problems with taking off and replacing the pump. Did a few logs, pump is holding up great!! I'm gonna take it easy on her for a few hundred miles... It's gonna be tough! |
![]() | | #113 | ![]() |
![]() Join Date: Jun 2010 Location: APO AE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
| Not Ranked : 0 score Removed my TMIC and my intake. I was installing sparkplugs and SRI. But it was easier then I thought. I had a little issue putting it back in but i just turned the engine over real quick and it was good. Was a little worried aobut starting it, because I worked on it. But everything turned out good |
![]() | | #114 | ![]() |
![]() Join Date: Nov 2010 Location: spring/woodlands
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 726
| Not Ranked : 0 score Thanks op for the write up, gave me just the push I needed to work on mine.
__________________ no more MS3 in the driveway ![]() but there is an EcoBoost FX2 that will be hunting on the freeways soooon!! TEAM LBN BEERS -- FYCN TEAM MEAGHAN -- FYCN |
![]() | | #115 | ![]() |
![]() Join Date: Mar 2011 Location: Bastrop, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,208
Groans: 273
| Not Ranked : 0 score subbed for doing this next month
__________________ 2011 Black Mica - Daily JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp |
![]() | | #116 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score Just did mine. Things are so much harder the first time around and for no good reason. I didn't print the directions fully but its a easy install. I was just so paranoid about making sure the internals were clean I spent most of my time on that. Redoing it and making sure everything was clean. I was stupid and when i unclipped the yellow fuel line I got fuel sprayed straight into my eyes. That was a bit scary. I wish I didn't take off the battery and tray cause when I first looked at the space I had to work with I thought there is no way I can get to that fuel bolt, but I guess you can from reading this thread again.Everything turned out well none the less and the car is running fine. I'm going to be taking it easy for a bit.. DP is next.. |
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | DingoDave (07-24-2011) |
![]() | | #117 | ![]() |
![]() Join Date: May 2009 Location: Tustin, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 365
| Not Ranked : 0 score Just finished my install. I took off my TMIC cuz i wanted to look at some stuff but it didn't have to come out. Only the shroud. I did KMD internals and everything went very smoothly. Thanks for the write up!
__________________ "If I can't fix it, it was meant to be broken" [SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey TUNED BY NISHAN POWER SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG COSMETIC AND AUDIO Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4 |
![]() | | #118 | ![]() |
| Not Ranked : 0 score any kind of motor oil will do the trick right?
![]() | | #119 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 515
| Not Ranked : 0 score Ok so im having a bit of trouble on the removal of the pump. I removed all of the lines except for the aluminum one. I unscrewed the nut but I cant seem to get the line off. I read that post about possibly kinking it so I didnt want to try to hard. Is there a trick or sumthing im missing or do I just need to man up and pull it off? Any help wiukd be appreciated. Thanks |
![]() | | #120 | ![]() |
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges | |
| KMD V2.1 Fuel Pump Internals | AllLostThings | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 05-23-2010 12:04 PM |
| oil in engine bay after pump internals install | Realgib3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 07-24-2009 05:04 PM |
| Fuel pump internals | cgburton12 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 43 | 08-11-2008 01:29 PM |
