![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
(Thread Starter) | Not Ranked : 0 score Dano thread for gen1: http://www.mazdaspeedforum.org/forum/foru...disable-90739/ This how-to is an extension of the one done by @harryclay so props to him. Heres his thread: SWAS on 2010 1st step: Disconnect negative battery terminal. Pump the brakes a few times to drain all remaining power from the system. Heres the view on approach. I only undid the 2 screws underneath the steering wheel and bent them far enough out of the way to get to shit. Use the tilt/telescope and bring the wheel out as far as it will go. This allows the two peices to come farther apart and give you more than enough room to work to get it done. Heres the area you will be working around. Undo the little thingy for that holds up the wires. This is to give you more room to work. I found it to be necessary and since it takes 3 seconds...wtf not? There it is disconnected. Also notice i kept the white harness underneath the yellow harness disconnected to allow more room to work. This probably was unnecessary but fuck it. This is Harryclay's picture. Shows what the connector looks like disconnected. It is almost impossible to take a good picture of it. But heres the best description i can give you to disconnect it: 1) Use the flathead to undo the latch that keeps it connected. You will come from the left side(engine side) and get it at just the right angle to unlatch it. 2) Use needle nose pliers to grip the connector with your right hand. 3) Simultaneously unlatch the connector with the left hand and wiggle it downward with the right hand. it will pop out pretty easily. Note the two yellow lights on the dash that will now be permanantly illuminated. TC/DSC can not be toggled on or off. It is permanantly off. Do this mod at your own discretion. Tools used. 10mm wrench was to disconnect the negative battery terminal. Then tuck it back under and button everything up. Afterwards I went for a drive. Upon returning into my hood i turned the wheel and launched it. It spun...a lot...so there you go. No more traction control and no more SWAS nanny.
__________________ Last edited by Monotonous ONE; 09-06-2011 at 12:04 PM. |
| The Following 4 Users Say Thank You to Monotonous ONE For This Useful Post: |
![]() Join Date: Apr 2010 Location: BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,102
| Not Ranked : 0 score I'm gonna go out and do this now. I disconnected it a while back but put it back, but I think I'll try running it for a little longer after reading Dano's post.
__________________ Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Die, You are forgiven. If I Live, I will kill you." Such is the Rule of Honor Last edited by bcmountainspeed; 09-05-2011 at 11:48 AM. Reason: add info |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score Waitin on driving impressions.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
Groans: 819
(Thread Starter) | Not Ranked : 0 score Something aint quite right I would hold off until i figure out wtf is wrong. As of right now my steering wheel buttons are not functioning. So im thinking shit is different on gen2. Goin to work now ao i wont be able to figure shit out til tomorrow. Car is driving fine tho.
__________________ |
| The Following User Says Thank You to Monotonous ONE For This Useful Post: | G26 (09-05-2011) |
![]() Join Date: Nov 2010 Location: Nashville,TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score That white plug is NOT THE SWAS. You disconnected the wrong plug dummy.
__________________ 2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD 2004 Corvette Z06 SCCA Bowling Green Match Tour - GS 1st place SCCA Wilmington Champ Tour - GS 2nd place SCCA National Championship - GS 3rd place SCCA Grenada Match Tour - AS 1st place |
![]() Join Date: Nov 2009 Location: PLAINEDGE, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 364
| Not Ranked : 0 score in before random airbag deployment. thanks for looking into it for gen2s. im sure theres an easy enough way to provide constant voltage to the sensor so it thinks the wheel is straight all the time, i just dont have the skillz to do it. yet.
__________________ 2010 Black Mica Mazdaspeed3 2009 Black Cherry CX-9 AWD 1997 Classic Red Miata [SIGPIC][/SIGPIC] |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Not Ranked : 0 score Swear there was a thread on this somewhere.. guy disconnected the angLe sensor on his gen2, and lost his power steering also.. yup heres the thread: SWAS on 2010 Last edited by Spoofmastafly; 09-05-2011 at 03:36 PM. |
Groans: 819
(Thread Starter) | Not Ranked : 0 score SO WTF DID I DO TO MY CAR BRO Lol...looks like it was just the harness for steering wheel shit. Cruise/volume/etc. Hopefully i plug it in and its all good. Lol. Genpu fail for life bro
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
![]() Join Date: Feb 2011 Location: Seattle
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
Groaned at 9 Times in 7 Posts
| Neutral : -1 score your poo is trying to commit suicide |
| Not Ranked : 0 score |
| The Following User Says Thank You to Spoofmastafly For This Useful Post: | Bucker (09-05-2011) |
__________________ 2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD 2004 Corvette Z06 SCCA Bowling Green Match Tour - GS 1st place SCCA Wilmington Champ Tour - GS 2nd place SCCA National Championship - GS 3rd place SCCA Grenada Match Tour - AS 1st place | |
| The Following 4 Users Say Thank You to ztnedman1 For This Useful Post: |
Groans: 819
(Thread Starter) | Not Ranked : 0 score Fuck my life I was way off. Kinda. Atleast i didnt catch an airbag to the face. Yet. I guess i know how to get the fucker now.
| The Following User Says Thank You to Monotonous ONE For This Useful Post: | Bucker (09-05-2011) |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score LOL@airbag to the face.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score This is a very simple how to: 1) look around and find two screws on the bottom of the steering wheel column (remove them and never put them back in so you can help some fool in like 2 seconds on msf) 2) pick a wire and pull it out (don't start with the big scary green harness) 3) check how car behaves and if your turn signals or controls don't act normally, choose again 4) when you get two warning lights and your traction control button no longer functions (it is just off now, at least for me) you are done but, if you want to do it right the first time, pull the wire in the pic below... use the bottom set of wires in that wire bundle for a guide |
| The Following 4 Users Say Thank You to Ckmazdaspeed3 For This Useful Post: |
Groans: 451
| Not Ranked : 0 score The one with an orange clip. Check. Thanks!
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score If you own a genpu, just go ahead and pull the white one ![]()
Groans: 819
(Thread Starter) | Not Ranked : 0 score bump for shit being fixed and being all good
![]() Join Date: May 2011 Location: Chicago Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 508
| Not Ranked : 0 score So there's no way to disable the lights in the dash for this mod, cuz personally that would piss me off. I wonder if this will allow my 2011 to brake boost
__________________ 2013 Velocity red Mazdaspeed 3 tech. BT 2011 Velocity red Mazdaspeed 3-SOLD. FreeKtuned fitty fitty |
Groans: 819
(Thread Starter) | Not Ranked : 0 score I dunno about those lights but i dont give a fuck as long as its not a CEL And its worth a shot to see if you can brake boost. Although I would bet they are separate systems. But give it a shot and report back
Groans: 134
| Not Ranked : 0 score I tOtally thought that the lights would piss me off, but after a couple of days I no longer noticed them. Lol at all of the tools! I brought a Phillips head w me to work and pulled over half way to an account and just started pulling shit out w my hands until I got it right. Last edited by Ckmazdaspeed3; 09-11-2011 at 11:15 AM. Reason: MSF Database - Automerged Doublepost |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Neutral : -1 score |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | TheStig1989 (10-12-2011) |
Because sushi roll
__________________ 2013 Velocity red Mazdaspeed 3 tech. BT 2011 Velocity red Mazdaspeed 3-SOLD. FreeKtuned fitty fitty | |
| The Following 3 Users Say Thank You to 2011speed For This Useful Post: |
![]() | | #24 | ![]() |
![]() Join Date: Nov 2010 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 106
| Not Ranked : 0 score There might be a better way to fix this coming soon... I have been testing a fix from Cobb this weekend trying to eliminate the SWAS rich condition through tuning instead of unplugging the sensor. Prior to the fix I was randomly seeing WOT AFRs in the 9s for the entire run and now its gone. I do not know what they changed I'll try to find out more. From what I gathered it's a table exposed in the latest version of ATR but not visible to the end user. I'm hoping this makes it into the next beta release as it seems to have cured my problems. Next up is testing the display and logging of boost > 22PSI on a 3 bar MAP for Gen2s.
__________________ 2010 Black Mica MS3 (Daily Driver) - self-tuned with the help of Lex www.mazdaspeedforum.org/forum/forum/f426/k06-log-86437/K04 Hybrid, Nitto NT01s, JMF Manifold, 4 Port Meth, 100% E85, 3 Bar MAP, HTP 3.5, Cobb DP, ETS TMIC, KMD Internals, PTP RV, OCC, Forge BPV, CP-E Mounts, JBR Thermal Intake & Throttle Body Gaskets, JBR Shifter Plate & Bushings 2006 Mustang GT - www.vortechsuperchargers.com/global_item.php?gik=348 Built Motor, 675 RWHP 560 lb/ft T-Trim 21PSI Non-Intercooled 1993 Mustang LX - www.youtube.com/watch?v=WiCCvodp6CU Budget 349 Stroker |
| The Following 9 Users Say Thank You to khopwood77 For This Useful Post: | bewsted (09-11-2011), Broxer (10-03-2011), Bucker (09-11-2011), Ckmazdaspeed3 (09-11-2011), josurr (11-15-2011), Monotonous ONE (09-11-2011), rfinkle2 (09-12-2011), SLOWHATCH (10-21-2011), wolly6973 (09-12-2011) |
![]() | | #25 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 57
| Not Ranked : 0 score ^^^I like this option much better. keep us updated.^^^ |
![]() | | #26 | ![]() |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Needs to be an option like turning off cels....
![]() | | #28 | ![]() |
| Not Ranked : 0 score I'm not 100% positive but I think it's more like the commanded max enrichment table giving you the ability to set AFR during certain conditions. I'll keep digging and let you guys know.
| The Following User Says Thank You to khopwood77 For This Useful Post: | wolly6973 (09-12-2011) |
![]() | | #29 | ![]() |
Groans: 134
I'll be turnig up boost on Wednesday the second my new clutch is in. My 2871 has 3 bar and I'll be pretty annoyed if i still can't go past the current limits | |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | rfinkle2 (09-12-2011) |
![]() | | #30 | ![]() |
Groans: 451
| Not Ranked : 0 score I NEED THE BOOST DISPLAY/ LOG!!! You can not log over ~22.6 PSI using the AP. I know. I have a 3 BAR MAP, but it didn't change that.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot Last edited by Bucker; 09-11-2011 at 05:17 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Bucker For This Useful Post: | rfinkle2 (09-12-2011) |
![]() | | #31 | ![]() |
Groans: 134
| Not Ranked : 0 score God damn it! That is fucking annoying! I hope they fix this soon! You can on gendone right? |
![]() | | #32 | ![]() |
Groans: 451
| Not Ranked : 0 score I'm a Gen 2
![]() | | #33 | ![]() |
Groans: 134
| Not Ranked : 0 score No, I know, I was just trying to get confirmation that gendone has this capability |
![]() | | #34 | ![]() |
Groans: 451
| Not Ranked : 0 score Reading fail on my part... I honestly don't have your answer.
![]() | | #35 | ![]() |
| Not Ranked : 0 score So i cant tell you lil niglets one thing for sure.... This ANGLE sensor will effect your AFR's more than you know.. My shit is SPOT on now...Just think of it like this....How hard does your car pull....The harder it pulls the more the angle sensor acknowledges angle and the more bull shit the ecu does to pull full or whatever the fuck it does.
![]() | | #36 | ![]() |
| Not Ranked : 0 score Hey guys try this out and see if it helps with your rich condition. The guys at Cobb let me know what they changed in ATR. I thought the tables were not exposed in ATR but they are available. Below is what they sent me when I was asking about what they did to correct my issue. In the latest release of ATR (Shifting Control Tables): Set Ignition Timing Limit (Min) (Throttle Closed) and (Throttle Open) to -3.0 (Stutter Fix) Set all Load Based and Load/RPM Based Fuel Compensations to 1.0 (Post Shift Fueling Fix) I have been running my car all weekend without a single rich condition. Attached is what prompted me to contact them. The "WOT 9s" file would occur randomly once every 10-15 WOT runs. I will update you guys in a few days on the Boost > 22. Waiting on the Alpha fix...
![]() | | #37 | ![]() |
| Not Ranked : 0 score Damn son....ko4 hybrid = what? LOL
![]() | | #38 | ![]() |
Groans: 451
| Not Ranked : 0 score K06 wheel.
![]() | | #39 | ![]() |
| Not Ranked : 0 score port comp housing thats it?
![]() | | #40 | ![]() |
Groans: 451
| Not Ranked : 0 score Pretty sure that and a new wastegate actuator. It looks like it flows, though.
| I need SWAS pictures! | mexicant | MazdaSpeed 3/6 - ECU Computer Tuning | 33 | 10-26-2016 07:23 PM |
| SWAS on 2010 | harryclay | 2010 MS3 - ECU Computer Tuning | 20 | 03-21-2016 04:11 PM |
| The disconnect of connected cars | Haltech | Automotive News | 0 | 05-03-2010 07:20 AM |
| Toyota's U.S.-Japan disconnect | Haltech | Automotive News | 0 | 03-01-2010 10:10 PM |
| swas sensor help! | madvillain | Mazdaspeed3/6 General Discussion | 1 | 01-20-2009 04:15 PM |
